Question about Kenmore Washing Machines
The washer timer gets to the drain part of the timer before rinse cycle and stops it never emptys the water out the washer and the timer stops. I think it might the time delay switch knob just guessing here. does this sound right?
  • robert_ritch Jun 26, 2009
    dont the lid switch stop all functions when the lid is up except FILL. So no dumb people hurt them selves. when the washer is agitating?
  • 351 Answers
I think its the lid switch.... pop the timer consol up and locate the wire harness connected to the housing take it off and put a jumper wire there and see if it goes then .... whirlpoolpartssurplus.com i can send you this part free shipping if you call me
Posted on Jun 26, 2009
It will fill but once full the motor will only spin for a few seconds then stop
IT MAY BE DUE TO A RINSE PROBLEM?
WASHER WILL NOT RINSE:
If your washer doesn't go through the washer rinse cycle, the most likely cause is the water valve. What happens is the water valve will stop letting cold water into the washer; therefore, once the washer gets to rinse it will either stop or not do anything during the whole rinse cycle.
This is because when you selected your water temperature, you selected warm/cold or hot/cold. The hot water came in and you didn't notice any problems. When it got to rinse, the cold water the cold water won't come in. Therefore, the washer does nothing.
To check the water valve, first cut the water off and remove the hoses off the back of the washer. Then one at a time point the hoses inside the washer tub and turn the water back on. If you don't have good water pressure, turn the water back off and remove the strainer that should be in one end of the hose. Inspect the strainer to see if it is stopped up, clean it and reinstall it. Now repeat this test. If you have good water pressure now, reinstall hose and your problem is fixed.
If you still don't have good water pressure, the problem is in your house plumbing and you need to call a plumber. If you had good water pressure the first time you performed the test, the water valve is bad and needs replacing.
TIMER
If your washer doesn't go through the washer rinse cycle the timer may be the problem. Sometimes the timer gets stuck in the middle of the cycle or won't turn at all. If the washer runs, but the timer doesn't turn, the timer is bad and needs replacing.
Do you have anti-flood hoses leading to the machine. If you do there is probably a loose tube in the back causing a small leak. When the hoses detect that water is still flowing after a certain amount of time due to the leak it shuts down and causes the machine to turn off during the rinse/spin cycle
Apr 19, 2015 | Washing Machines
My washing machine mentioned above wont drain the water or preform the spin cycle process once it gets to the usual 7 minute mark. No leakage, just not drain or spin. How can I fix it?
TIMER
Mar 26, 2015 | Washing Machines
Cold water won't stop before rinse cycle
if it fails to stop running only at the rinse part of the cycle it is probably in the timer as the solenoid valve has to cut the water off when the washer fills for the wash cycle too. fills for wash cycle and cuts off water, washes and drains, refills for rinse cycle and water just keeps running? does this every time you run it? that's in the timer. bad solenoid (water inlet valve) would keep running even on wash fill up. hope this helps.
Feb 25, 2014 | LG WM2688H Front Load Washer
Moffatt washer is washing and draining but not spinning out the clothes
All content © 2000 © 2009 Washerhelp
> Home / Repairs DIY washing machine advice (part 8) Washing machine sticks or stops mid-cycle repairs-sm.gif A very common fault on washing machines is when the program timer fails to complete the cycle and stops part way through. Many people blame the program timer for this but although it is a possible cause, there are many more likely causes for this fault. The program will stick if the heater isn't working, if the thermostat fails, if it can't fill up with cold water for the rinses, if it can't empty the water etc. There are too many possible causes of this fault to be able to give anything other than rudimentary advice. However, the common causes of a washing machine sticking that can easily be fixed are filling and emptying problems.
Check that the cold water supply is available to the washing machine, which is a common cause for sticking on rinses. If the washing machine appears to stop mid-cycle and isn't filling with water on rinses then see Washing machine won't fill with water (or no water goes into washing machine) before calling an engineer. If the washing machine can't drain the water out then it will stick on the rinses, or it will abort with an error code. If you can see water still inside the washing machine then check the following advice Washing machine won't empty water
Dec 03, 2009 | Washing Machines
Washer stop in middle of rinse cycle
Dec 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have a Frig. Gallery washer and it will fill up and drain but not spin. What could be wrong and how can I fix it??
Dec 02, 2009 | Frigidaire Affinity ATF7000E Front Load...
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Washing Machines Logo
27 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
