Question about Intercure Resperate to Lower Blood Pressure
After 2 yrs, my resperate has stopped functioning. the batteries are fine, the unit works, but the chest sensor doesn't appear to be communicating. What can I do?I have checked the connections at both end, as well as the continuity of the wires. All I get is a loose band symbol, with occasional startup tones when I fiddle with the sensor. Please help, haven't got much hair left!
The sensor belt on my resperate machine appears to be faulty. Constantly tells me that belt is loose.
I think you could
use this manual method instead.. My nephew used it to repair my car and it's perfectly fine now. Here's the website he bought it from. www.reliable-store.com
Mar 06, 2018 | Cars & Trucks
Faulty sensor belt
http://manuals.harborfreight.com/manuals/67000-67999/67212.pdf
Jul 20, 2013 | Intercure RESPeRATE Ultra Duo User
Oregon scientific model no rar186 how to set up outdoors sensor
I have had this Oregon Scientific model RAR186 unit for years and it works great. The only issue I ever have is when the batteries need to be changed in the remote sensor unit (Oregon scientific model #THN122). It never fails that once I change the batteries that the unit does not send a signal to the base unit. I will often hit the reset button and change the channels on the remote sensor before I finally remember that you need to do the following to get the sensor to talk to the RAR186 base unit:
On the base unit (RAR186), hold down the CHANNEL and MEM buttons for at least two seconds.
You will then see a graphic appear above the channel number that shows that it is searching for the sensor.
Within a minute, you will then see the temperature displayed for the sensor showing that they are communicating.
This is buried in the manual that you probably discarded as did I.
Apparently, if your sensor is broken, you can either search to find a new sensor of the same model or also use the following sensors: THC138, THGR122NX, or THN132N
I have not needed to replace the sensor as once I found the instructions to reset the communication between the sensor and base unit, all was fine. Hope this helps someone. I wrote this instruction using a Sharpie on the inside cover of the sensor since you have to remove 3 screws to replace the AAA batteries (2) in hopes I will remember next time and not waste my time searching the internet and not find the answer. Good luck!
Apr 02, 2013 | Oregon Scientific Measuring Tools &...
Remote sensor (thn122) not working, batteries changed, terminals cleaned
Mar 05, 2013 | Oregon Scientific Measuring Tools &...
My freezer has quit working....everything else is fine
A chest freezer is great for storing additional food that may not fit in your fridge freezer. If your chest freezer stops working, it's important to be able to troubleshoot it quickly so that food waste is kept to a minimum. Keep the following tips in mind if your chest freezer stops working.
Check the Electricity
If your chest freezer doesn't seem to be working at all, check the outlet that the freezer is plugged into. Unplug the chest freezer from the wall and plug something else in such as a lamp or digital clock. If the new appliance doesn't work either, you know the problem is with your outlet and not your freezer. If the appliance does work, you will need to refer to other troubleshooting methods.
Inspect the Relay
The relay is a component that helps power the compressor. It is housed in a plastic box with the motor terminals and the overload protector and is connected to the Compressor; the relay is the largest component in the box. Closely inspect the relay and make sure it is not burned out. The relay can also be tested using a multimeter. If you see any signs that the relay has shorted out, you'll will need to replace it. If the relay makes a rattling sound when shaken, this is also a sign that it has shorted out.
Examine the Compressor
The compressor is essential to the performance of your chest freezer. It is the motor that powers the entire cooling system and if your freezer has ceased to work, you need to check it. This unit is located at the back of the freezer and sits in plastic housing; it can be identified by its football shape.
You can tell that the compressor is broken if your relay is fine or if you hear a light hum followed by a clicking sound and silence. If your freezer is relatively new, it might still be under warranty and you could get a replacement compressor for free. If not, your compressor will need to be replaced by a professional.
Investigate the Thermostat
The fact that your chest freezer is not working could be down to the thermostat. This is the unit that regulates the temperature inside the freezer. To test your thermostat, remove the access panel on the side of the freezer. Next, use a screwdriver to remove the actual thermostat from the inside wall but do not disconnect the tube that runs from the unit into the freezer.
Set the range scale on Rx1 on your multimeter to test for continuity. If your multi-tester reads continuity, your freezer problem lies in another spot. If your multi-tester does not read continuity, it means your thermostat is not working and you will need to replace it. Remove the tube from the old thermostat and attach it to the new one. Screw the new unit into place on the freezer wall and make sure the tube is not coiled or kinked as this will prevent the new thermostat from working properly.
I hope this will help in solving the issues.....
Sep 09, 2011 | Maytag Refrigerators
My chest freeze just stopped working. Have checked
Your start relay or overload relay must have gone out. What is the model number of your unit?
Jul 30, 2011 | Frigidaire Freezers
How do i reset and work my polar t31? I have lost instructions and it is 2 years since I last used it
There is no reset on the T-31 chest straps and transmitters. If the battery is functioning then you simply put it around your chest (make sure the contacts are wet) and turn on the watch. A heart rate signal should appear automatically.
If this doesn't work, I have solutions in my tips and tricks page as well as Manuals for Polar products. The T-31 battery may also be dead, in which case you will need to replace.
The picture you have showing is for a S-Series Speed sensor for the Bike. If this is something you are having a problem with feel free to send me a note related to the problem.
Dec 14, 2010 | Polar T31 Transmitter and Belt Set
How do I enable my EFX 544 to give my heart rate while wearing my polar heart rate chest strap?
If the EFX 544 has polar Heart Rate attach to the upper electronics your chest strap should be transmitting and the unit should be receiving. If your chest strap is more than 3 yrs old usually the battery will die and needs to be replaced or you have a defective receiver and will have to be replaced
May 17, 2010 | Precor C956i Treadmills with HR /...
Intercure Resperate to Lower Blood Pressure Logo
Top Intercure Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you an Intercure Health and Beauty Expert? Answer questions, earn points and help others
