Question about Mongoose 20-Inch Gravity Games BMX Freestyle Bike
When im riding my BMX,a loud clicking noise comes from my peddles
Every time the click happens, the peddles move slightly backwards but i just keed peddling.(FBM Heathen)
  • steven199685 Jun 26, 2009
    I just checked all the chain links and they are all moving freely and are lubricated.The only thing wrong with my chain is that it is loose but i am going to tighten it.
  • George Fischer May 11, 2010
    your chain is not adjust properly or there is a two link stick together, make sure all links move freely from each other and lubricate them with oil. when you find the 2 that are stuck, work them so they get unstuck
  • 31 Answers
Might be something to do with the postioning of the sprockets?
Posted on Jul 23, 2009
Huffy boys bike makes clicking noise
does it make the "clicking" noise when coasting, pedaling or both? If it is only when pedaling, check to make sure the cranks are not rubbing on a chain guard or hitting the frame, if not then the chain is probably too tight and it is the gear cog teeth meshing with the tight chain. Loosen the rear axle nuts and slide the rear wheel forward slightly, this should take care of it. If the noise happens while coasting then one of the wheels could be rubbing on the frame intermittently, or the hub bearings could be too tight (also making it difficult for small legs to pedal) and the bearings are crushed and flattening making the "clicking" noise as they are being ground up.
Apr 21, 2014 | Huffy Pro Thunder Boys 16-Inch BMX Bike
2009 superglide starter maybe?
whats your oil pressure at when warm ???
May 26, 2013 | Motorcycles
Hi, i have a problem with my BMX bike. This problem has been occuring for quite a long period of time now. The problem im experiencing is that when i land a jump of some sort my bike would make a lound...
Please check your headset if its not loosen, chain if not loose, or your front rim and spokes if still intact. http://en.wikipedia.org/wiki/File:Bicycle_diagram-en.svg
Jun 27, 2011 | Cycling
When the bike is peddled there is a clicking sound. Is this normal? The bike hasn't been used for about a year.
I think the clicking noise is caused by one of two common issues. The easiest is that the little black computer pickup is too close to the magnet located on the right plastic piece on the right side of the wheel and everytime the wheel makes a full circuit while peddling, that little black piece clicks as it actually hits the magnet. If that's the case, then pull the black magnet sensor away just 1/16 of an inch aways so it will not hit the magnet everytime it passes the magnet. You can tell what's causing the clicking noise by getting on the floor and pushing the pedal around with one hand slowly and looking closely at the tow places I will mention to determine where the clicking noise comes from and then making the adjustment to stop it. the other place the clicking can come from is the chain rubbing against the metal on the left side. It might be hitting the TOP of the metal cage when cycling OR the BOTTOM of the metal shield which covers the pedal assembly. Look closely at the left side of the bike while peddling the bike slowly to see if the noise is metal against metal. You can shift the cage slightly to take the pressure of the cage from scrapping the chain by sitting down in front of the bike facing the cage and placing both feet onto the left & right supports (they're what hold the bike up) and you grab the little black wheels on both sides with your hands and push down slightly but firmly to shift the cage a bit and it will move up or down depending on where the chain is scrapping it when you cycle. That cage will shift slightly over time and it can make a loud noise when it scrapes the chain. I hope this helps. If not, give me a reply with more details and I'd be glad to help you isolate and fix the problem. Leave postive comment on fixya if you like my solution. Luke terpcafe@yahoo.com
Jan 16, 2011 | Schwinn Original Airdyne
I have a 2006 Pride Maxima. Problem comes and goes.
Hi Alex. Does this problem happen when you first turn on the scooter, or does it happen while you are riding the scooter.
It might possibly be that the speed lever ( wig wag ), is not correctly adjusted, or is worn.
Test the lever is correctly adjusted by sitting on the machine with the key on. Slowly move the lever in the forward direction, until you hear the brake click. Take note of how far the lever moved. Now move the lever in the reverse direction until you hear the brake unit click. The distance the lever moved, should be the same in both cases.
Also while you are driving your machine try moving the ends of the lever slowly up and down. If this makes the machine change speed erratically, then you probably need a new throttle pot, or speed lever assembly.
Does your machine show any fault codes or flashing LED's.
Hope this helps. Neil.
Jul 09, 2010 | Pride Luxury Line Maxima Scooter - 4 Wheel...
Loud screeching noise from dryer.
sounds to me like the nylon pieces that isolate the drum from the front of the door are gone, you may want to open it up and take a look at it. Is it an old dryer? Its either that or I suppose it could be the bearing in the middle of the back but I dont think it would be in only certain parts of a rotation, it would be all. Im sure the drum probably just ate through the nylon seperator.Theres not much else that only makes noise part of the time.. and theres not many moving parts.
Im not sure if there are replacement pieces for this but you can google it.
Apr 13, 2009 | LG DLE2532W Electric Dryer
Mongoose 20-Inch Gravity Games BMX Freestyle Bike  Logo
390 people viewed this question
Top Mongoose Cycling Experts
Michial Gueffroy
Jim Goldsmith
Jim Goldsmith
Rommel Balcita
Are you a Mongoose Cycling Expert? Answer questions, earn points and help others
