Question about Samsung Eternity Cell Phone
Moisture problem? Discovered that as my phone was connected to charger, a blinking large battery "icon" came on. I took it to my local store, and customer rep said that the phone hand moisture in it, which could have happened due to answering the phone with sweaty hands a couple of times. I have opened the battery cover and removed battery and chips. After four days, no luck yet on being able to turn phone on. The model is a SGH A867 Eternity.
  • 389 Answers
For moisture problem it only means that it causes corrosion to the phone's mother board. you can still get a local service center to have it checked if they can still repair the phone for you.
Posted on Jul 03, 2009
TC4400
How do you know the battery is good? does the multimeter really read more than the battery should give, according to what is printed on it?
A 3,7 volt battery, should give at least 3,8, wham not connected. A 7,2 at least 7,4. Because the printed voltage should be on the connector, when you are discharging the battery.
When your charger is blinking, it could indicate the battery is not well. The Ri can be to high or something else, is wrong, and that is ht the charger won't or can't charge.
Jun 09, 2014 | Compaq tc4400 Tablet PC
My LG Viper phone just stopped working,
Mine does this often. Sometimes it's so dead that it has to blink for a little while before being able to boot back up.
Sep 23, 2012 | Sprint LG Viper 4G LTE GSM Smartphone -...
Getting very hot after connected for 20-30 minutes
hi there!
are you using original battery for your cellphone? and original charger too? local batteries have that overheat issue. if you are using battery and charger thats both original (if your phone is nokia, your batt and charger should be original nokia aswell), bring the phone to your local technician before you overheat it. if its still in warranty, they can replace either the battery or the unit for you. cellphones do heat up when being charged but if you say its very hot then have it checked by the store or a technician.
Apr 08, 2011 | Cell Phones
My laptop HP PRESARIO V1000 won't start without charger plug in. When push on, the charge led blinking for eight times then nothing happen. it start normally when I turn on with charger plug in, after...
It sounds like the Battery is Dead or not charging. You might try a local pc shop and see if they have any laptop batteries for you laptop. Or have them test to see if the battery is charging.
Dec 11, 2010 | Compaq Presario M2000 V1000 V2000 V3000...
Had phone almost a year, no problems. Couldn't get it to turn off, so removed battery, now won't go on, tried all advise, cept battery out for 6 hours, will leave it out, but have you heard of this? Can...
It could be that moisture got into the battery terminals. Take a Qtip and wipe the battery terminals inside the phone and also on your battery.
Then try installing the battery again and then hook up the AC charger. Try booting up. I had a cell phone once, it was a Nokia and it did something similar. I had plugged the car charger in while I was in the car and I heard a noise like it shorted. I took the phone to trade it in when I purchased a new Nokia and I noticed that the store clerk had taken my phone that would not boot up and hooked it to an AC charger. It powered up. I still purchased the new phone, but try the AC charger and see what happens. If it powers up, it might be the battery. Let the battery charge for about 4 hours, don't keep it charged overnight. Overnight charging will ruin the battery. If the phone still doesn't work, I'd say bring it in and see if you can get it looked at.
Mar 27, 2010 | Nokia 5800 XpressMusic Smartphone
Blackberry Pearl will not turn on but light keeps blinking red
Do not turn on the phone again before taking out all trapped moisture. Take out the battery, sim card, etc. You will need to wrap each piece in newspaper, the phone and battery and then put in a rice container and wait at least 24 hrs. The newspaper and rice will eventually absorb the moisture. I hope this helps!
Apr 17, 2009 | RIM BlackBerry Pearl 8100
Charging
Go to your local carrier store and bring your phone/sim card/battery/and charger...at the store they should have test phones/batteries/chargers...test everything with the agent to determine if you need to replace the phone, battery, or the charger.
Feb 10, 2009 | Samsung SGH-E900 Cellular Phone
Unable to charge
you need a new batt.
go to any local phone store to get one.
Jan 18, 2009 | Motorola Mobility RAZR V3
Inquiry
Try to switch it on connected to an AC charger, if it switches on , then it is a battery problem. If not, it may be the AC charger, or oxide in the charger contact.
I sugggest also going to a local phone repair shop, and eventually testing a different battery and a charger.
If the battery works, replace it, if it is not the battery or the AC charger, then ask the fee for repair. Usually it is the charger or the battery.
Oct 14, 2008 | Sony Ericsson P910i Cellular Phone
Phone will not charge up
Common problem, I've had countless charging problems with Sony-Ericsson.
Is this USB or Mains charger? Mains charger seems to be more effective. I had a problem with my K800i where it ran-out of battery completely, then when I charged it, the screen would stay white. I would have to keep it there for an hour or so, then take it off, turn it on, then charge it again and it would charge fine.
Another problem I had was with a K750i - the phone would state it was charging, but when you took it off charge, the battery would be low. I think the battery was just old in that one. A new one may have sorted it. I took it to my nearest operator store and they sent it off for repair. It took around 2 weeks and it still wasn't fixed, so I got a W810i as a kind of 'Sorry your phone sucks' free replacement.
So, how old is the phone? the battery may need replacing with new, they're around £10.
You may be able to send it off for repair.
Try a different charger from a friend or local store - just ask!
Try the method I explained for my K800i.
Jan 07, 2008 | Sony Ericsson W850i Cellular Phone
Samsung Eternity  Cell Phone Logo
95 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
