Question about Nokia N72 Cellular Phone
Display not working
My display connector wire in broken....how much it ll cost me 2 buy a new display.......
  • 157 Answers
I do at 35 euro dropship !
Best Regards
Posted on Jun 26, 2009
  • Ozgur Oz Jun 26, 2009
    and also you can contact at : omniarepair at gmail dot com
Recently, I changed the altenator of Toyota camry 2007 because the alternator is bad and the alternator harness connector was taped because it was broken already. The mechanics was trying to open the tape...
Costly, indeed. And dealerships don't like to fix broken things, they like to sell new parts. Guess you are stuck if you stay there. Do you know any good independent mechanics? One could probably repair it, or another alternative is a used engine harness, for less than half the cost of new.
Jan 16, 2013 | 2007 Toyota Camry
89 Camry passenger power window not working
I just solved this same problem on my 1989 Camry. The problem was a broken wire somewhere in the door or rubber boot, running between the master switch in the drivers door and the connector (E1, 10-pin blue connector) in the left kick panel. Put one lead of your ohm meter on the pin with the GRN/WHT wire (green with a white stripe) on connector E1, and the other lead of your meter on the same color wire at the master switch connector. If your problem is the same as mine you'll find this wire is broken (no continuity). Try some of the other wires in the same way to ensure you have the right wire bundle. The fun part was fishing a new 16 gauge wire through the boot. I used a fiberglass wire pulling rod from Harbor Freight tools, pulled a heavy string through, tied the new wire to it, and pulled it through. Tip: Pull in some extra wires at the same time; I found another broken wire that stopped my left rear window from working also. I cut the wires near each connector and crimped on **** connectors to splice in my new wires. Works great. Good luck -- Mark
Jun 20, 2012 | 1989 Toyota Camry
I want to change the radio over whith a CD player, but i need to know which wire is which?
Most radios are fitter with an ISO connector. A universal connector that will alow any aftermartket radio to be easily connected to your cars wiring loom. I.e. you unplug your existing radio and simply connect the new one.
However, quite often you'll need to buy ISO adaptor to interface between the new radio and your car. Unless you fancy cutting and stripping the cables and attempting to manually connect the wires together, but you'll need to know what wire does what and all cars are different...unfortunatley...
You'll need the specific ISO adaptor for your cars, so seek out a specialist car audio dealer for this.
Jun 10, 2011 | Car Audio & Video
Dear Experts! My laptop (VGN FW30B sony) has the display problem, there is a red display on the screen. The red colour is very annoying me. Some technician said some Wire is broken, if we change the...
The display panel appears to be your problem but i would replace the video inverter too when you replace it.Replacing just the display panel should do the trick though.
Jan 26, 2011 | Computers & Internet
The power adapter that plugs into the laptop HP DV4000 is broken, and I can't use the charger. where can I find a new one to replace the broken one, or will I have to buy a whold new charger? thanks
Do you mean only the power cable that linked the power brick with laptop was broken? Of course if you are 100% sure that's the only part that fail, you may only buy a cable. Check this link blow:
http://www.chargerbuy.com/cable-connector/power-cord.html
But if you are not that sure, i'll suggest you buying a whole new charger:
HP Pavilion DV4000 AC Adapter
Aug 03, 2010 | HP Pavilion dv4000 Notebook
ACS295 speaker cable to subwoofer, one of the pins of the connector is broken, how can I fix it or get a new connector?
if connector is broken, you need to buy a new connector, but it takes a little handwork and some tools a screw driver some electric iron and solder.
u need to open subwoofer case and check for the connector is soldered in a board is 2 jack 3,5mm female connector and one red mini-DIN connector. replace the connector take a attention on soldering the connector, dont damage the board wires and pins, if the iron above 300ºC.
take a special attention on electrostatic discharge, normaly burns sensitive boards.
Jan 30, 2010 | Altec Lansing ACS 295 Computer Speakers
Brake lights???
cut the wires use the wire connector and reconnect to each other its a simple walmart has a set for 10 bucks to do this and put electrical tape around the wiring 2 seperate wire 2 seperate connectors/ Please rate my response thank you very much
Jan 16, 2009 | 2000 Chevrolet Tahoe
My TV has a broken cable port. It looks like I can buy a new F-Type connector and solder it back on but I cannot find wher the ground goes. Since the part costs about a buck is it worth it to try and fix...
very trickey repair. ground is any metel of cover.  center connector is problem. remove cover on rf converter tuner. find where connection was. easier way buy rf converter with wire. sheeided part to cover.conductor to point where orig connection mount same to back
Dec 13, 2008 | Televison & Video
Texas Instruments TI-30XA Calculator Problem
Either battery is dying, or circuit board has gone, or connector cable loose.
You can replace battery by removing 6 screws at back of calculator, but cost of battery is around 40% of buying new TI-30XA for $10 from Amazon, Staples or elsewhere.
I've used TI-30XA's for years, batteries usually last 2-3 years, then I buy new calculator. The one time I tried to replace battery, fading display still problem, so circuit board had gone bad.
So you could try battery replace and may be OK, but also may be waste of time and $$
Nov 04, 2008 | Texas Instruments TI-30XA Calculator
Broken screen
THE SCREEN IS A COSTLIEAST ONE , SO IT HANDLE CAREFULLY.FIRST TO OPEN SCREEN TO UNSCREW AND THEN REMOVE DISPLAY WIRE(STRIP).BUY NEW ONE FIX ON THE SAME TYPE OF MANNER . THE COST OF DISPLAY AROUND 300$.
Jun 26, 2008 | HP Pavilion dv6000z Notebook
Nokia N72 Cellular Phone Logo
52 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
