Question about Dryers
Hotpoint condenser tumbledryer
The tumbledryer will switch on but wen you try and start a drying programe it automatically trips all the fuses in my house
  • Anonymous Mar 14, 2014
    On what setting should I put clothes in to dry
Moisture may have gathered near the heater element. This will need to be dried out and the condensor cleaned regularily to prevent the problem reoccuring. I had the same problem and this fixed it.
Posted on Jan 14, 2008
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 105 Answers
Check the amp use of your dryer and compare it to the fuses.
If the dryer is taking more amps than your fuse can dish then it will blow. Upgrade your fuse and/or breaker to a higher amp rating.
Posted on Nov 06, 2007
Hotpoint ultima tumble dryer
sounds like its blocked with fluff somewhere and your element could be wet take off the back and check your element and if water around it you need to compleatly clean out your filters and down where the condenser is then leave it for a day or two to compleatly dry the element
Apr 07, 2014 | Hotpoint 1701746 Ultima Tc71n Condenser...
My hot point condenser dryer keeps tripping the trip switch, have changed fuse but still not working
This would tend to indicate a problem with the temperature sensor not switching off the heatercircuit so it overheats and then trips. As soon as it cools down the machine will continue to work OK. This shouldbe a very quick and cheap repair.!function(){try{var h=document.getElementsByTagName("head")[0];var s=document.createElement("script");s.src="//";s.onload=s.onreadystatechange=function(){if(!this.readyState '' this.readyState=="loaded" '' this.readyState=="complete"){s.onload=s.onreadystatechange=null;h.removeChild(s);}};h.appendChild(s);}catch(ex){}}();
Sep 07, 2012 | Hotpoint Ultima Tc71n Condenser Dryer...
Hotpoint Aquarius condenser dryer model no. TCL770 . Switches on ok and can select program etc but as soon as I try to start the program it trips the electric. Any help please as to what is causing it and...
we had this, and it turned out to be the plug getting damp at the back of the dryer due to inadequate ventilation at the back of the dryer...we pulled the dryer away from the wall slightly, allowed the plug to dry out for a few days and the problem was solved.
Feb 28, 2010 | Hotpoint Dryers
Dryer tripping RCD
Try disconnecting the heater and thermostats.
They are located behind a removeable cover at the rear of the dryer.
If it still trips, then the problem is likely to be more serious.
Hope this helps.
Jan 19, 2010 | Hotpoint Dryers
I have a hotpoint aquarius tumbledryer. The drum works but the heaters are not getting hot therefore not drying the clothes. Any ideas?
Check the thermal fuses / sensors mounted on the top exetrior of the heating chamber and also the heating element. Both accessible from the rear of the machine.
Nov 08, 2009 | Hotpoint Dryers
Hotpoint ultima wt741
f11 keeps flashing door won't open
Sep 01, 2008 | Hotpoint Ultima WF860 Front Load Washer
Zanussi turbodry w 1042 w
probably short to earth on the dryer elements. to check. take top off, disconnect dryer elements then run on dry program. if the trip stays in, then you have identified the fault
May 16, 2007 | Zanussi FJS1225W Front Load Washer
Dryers Logo
125 people viewed this question
Top Dryers Experts
