Question about Amana ACEX186E Wall/Window Air Conditioner
AIR CONDITIONER DOES NOT WORK PROPERLY
WILL NOT CUT OFF ENERGY SAVER DOES NOT CUT DOWN
  • 659 Answers
SOURCE: how can i disable the energy saver of my amana air
I don't think it is possible but if it is.........follow this link for acquiring the manual for it. If you can't find the manual on-line, give them a call or email them and they will get back to you.
http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=AMA
Posted on Apr 06, 2009
daddyo742001
  • 70 Answers
SOURCE: This goldstar air conditioner model is WG2405RY7
Doe's the temp reach the set point? If not then it will run until it doe's. If you set the stat warmer and the fan keeps running after compressor shuts off check to make sure it is in power saver mode. Most AC units keep more even temp when fan is left on.
Posted on Jun 30, 2009
relaga58
  • 158 Answers
SOURCE: air conditioner not working
have you tried turning off and on power from the plug ?
Posted on Aug 17, 2009
  • 905 Answers
SOURCE: E1 Flashing on display, air cut off
There are steps listed in the user manual which can be downloaded from:
http://www.sharpusa.com/...
/air_man_AFS60FX_S80FX_S85FX_R80FX.pdf
You also need to hold the power button when plugged back in. If that doesn't work, there is another step as well.
Posted on Aug 25, 2009
lambocar
  • 31 Answers
SOURCE: My air conditioner will not turn on.
AC has a relay, it sounds like it failed on ya. If the unit was on all the time, was it that hot where you were or do you mean switched from AC to fan on all day? From what you said, it sounds like the unit burned its relay out for overheating, meaning thermostat may have originally failed keeping unit on until relay popped. Careful of fire hazard.
Posted on Jul 07, 2010
My Dometic AC on my travel trailer cools well but I cannot set the fan to stay on when the compressor cycles off. Can a different switch or board be installed to allow the fan to stay on?
An energy saver setting is what it sounds like. Turn off energy saver feature and fan should run 100% and compressor cycle on-off separately.If not familiar with energy saver setting .make sure it has one or not before disregarding this.
Feb 28, 2012 | Dometic Rooftop RV Air Conditioner
How can I turn on the energy saver on my LWHD2400HR air conditioner? There is no switch on the A/C, only an indicator light that says "Energy Saver"?
The Energy Saver mode is activated by using the hand held remote control, that comes with the unit. Pressing the Energy Saver button activates it. Once activated the fan will shut OFF when the the compressor does. After which, about every 3 minutes the fan will turn ON to check the room air to determine if cooling is needed.
It sounds like, you're missing the hand held remote control?
Jul 19, 2011 | LG LWHD2400HR Wall/Window Air Conditioner
Energy saver rocker switch may have a short; sometimes it will continue running non-stop instead of cutting on and off with thermostat as intended.
I doubt your problem lies within a rocker switch. Typically when a system will not shut off as you are describing, its due to either a bad thermostat or a stuck relay or contactor.
A stuck relay or contactor is the most likely culprit. Check your relays for proper operation and replace as necessary.
Jan 09, 2010 | Friedrich TwinTemp ES12J33B Air...
Aug 23, 2009 | Sharp AF-S85FX Wall/Window Air Conditioner
Model number HBLG 12303r how does the energy saver setting work bought this model used.
The energy saver setting will turn the blower fan off when the thermostat reaches the desired room temperature (with the compressor). Other non energy savers only cycle the compressor to regulate the room temp. so their fans will operate continusously using more electricity.
Aug 04, 2009 | Heating & Cooling
I set ac at energy saver 71 degrees. The ac goes
yeah you have to be carfull the only thing that does is shut the inside fan off it does not mean anything. it is a selling thing
How to disable the energy saver of the amana ptac unit. Once the AC reach the lowest temp on the room , the unit turn off, then when room temp raise it turn on.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=PTH153B50AJ&siteCd=AMA
This is the link to find the manual for your unit. Make sure the model number is correct. You should be able to find the info you are looking for if it is possible to disable the energy saver. Hopefully this will help.
Mar 20, 2009 | Amana PTH153B50AJ Heat Pump Air...
Shutting off
I would try the same solution as the E1 error code, Not sure if it will work, but it seems to be the same issue
1. Power down the air conditioner using the "power" button on the front
panel.
2. Unplug the air conditioner from the wall socket.
3. Hold the front panel "power" button down and plug the air
conditioner in. Continue to hold the power button down as the machine
goes through a brief test sequence (fan & compressor each come on
briefly, etc). There is a "beep" sound at the end of the test sequence,
and the machine will be off. At this point, you can release the power
button.
4. Unplug the air conditioner.
5. Plug the air conditioner back in.
6. Congratulations! You should now be able to operate the air
conditioner normally for another 720 hours, but only if you followed
the instructions above EXACTLY.
Sep 10, 2008 | Sharp AF-S120FX Air Conditioner
Can't get the air conditioner to cut off and on
Check to see if it has energy saver option on unit or timer. If you have, and you have tried to use it you may need to call the manufacturer. If it does and you haven't used it yet, try setting energy saver. It also helps the A/C last longer by preventing unit from freezing up from overuse.Note- make sure you set the temperature for a setting that is comfortable for you for day and night.
Aug 05, 2008 | Haier hwr10xc6 Air Conditioner
Amana ACEX186E Wall/Window Air Conditioner Logo
64 people viewed this question
Top Amana Heating & Cooling Experts
Bill Long
Pete Norton
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
