Question about Jandy Aqualink Rs4 One Touch Control System Control System
My pool "power box" states that there is a temporary error
It says "Open water sensor" How do I close the water sensor or do I even need to at all?
    Champion:
  • 246 Answers
LOL you do not close the water sensor . it must be replace and this sensor control the heater and the solar if any check for a wire on the plumbing after the pump thats is the one
Posted on Oct 16, 2009
I have a vita spa hot tub i've replaced the circuit board,heater, preasure switch,check the pump reset the top board but keep getting a flashing flo error and will not heat up.Tested current have 115
I believe with some of manufacturers spas, Vita included, the error will occur if the system is reading that the pressure switch has a "CLOSED" circuit. Bypassing the pressure switch, will still be creating this! What this means to the system: The circuit board does a quick system check. If the board says to itself: "Why does the pressure switch tell me the water is flowing (thats what happens when the pump is on and moves water; pressure is created in the plumbing and the switch then closes) when I haven't even sent power to the pump yet?" Then it will send the error message.
Your switch may need to be calibrated to only close when there is water flowing, and then open within a second of the pump or water flow stopping.
Oct 30, 2014 | Pool & Spa
Hayward Pool Heater H200fdn
open safety circuit, most likely the pressure switch
Aug 17, 2014 | Pool & Spa
How do an intex pump to a non intex pool?
this question has come up before too me , what i respond with is it to be perminate or temporary ? , the reason i ask if its to be perminate then i suggest purchasing the correct filter for the pool, but on temporary situation (to just finish out season) then yes even though the pipe sizes are different , the use of std plumbing home DWV rubber soft connections available at any good hardware/homecenter would work , but heres the temporary part of it , saltwater pool water degrades the rubber making it brittle , but will last a month or so
May 30, 2012 | Intex Salt Water Saltwater System Chlorine...
Freeze protection is activated on aqualink. Air sensor says 3deg but pool temp says 83deg. Want to know how to adjust air sensor so pool doesn't cycle all night
You don't adjust this. You will need to replace the air sensor. You can get the sensor at or through any pool shop and it is simple to replace. You will find it hanging under your box by the equiptment, or somewhere close in the shade. Follow the wire into the box and find the terminal block it screws into. You will need a tiny flat screwdriver for this. Remove the old one and install the new one, close the box and your done.
Sep 04, 2010 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
My salt water system is saying low water flow. I've checked all connections, nothing is clogged. What do I do? Also, my water is cloudy, what do I need to do?
If you are still looking for some solutions, here they are.
Start by plugging both your out put and input in the pool
or simply close the plungers
If you are uncertain the flow sensor is ok then blast it out with the garden hose. Make sure it swings freely
now take out your cartridge and blast it too
now remove your hose from the inlet to the pump
even though you may be skimming and things go in the basket hair still gets through and cloggs up in front of the filter
this also will happen with out a skimmer
Put it all back together and now open the top bleeder on the cartridge cover
open outlet side hose first
when water starts comong out the bleeder open the inlet hose
now turn on pump for 30 seconds and then close the bleeder
This should do it
As for the cloudy it could be as simple as your filter not performing as it should or even maybe high salt with out an alarm
you need to have your salt as close to 3000ppm as possible below 2800ppm and you will not produce enough chlorine and above 3500ppm and you could get cloudy water
Intex pumps do not do a sufficient job
A pool needs turned over 304 times minimum in a cycle
since I do not know your pool or pump I will use generic #'s
If you have a 5000gl pool and a 1500gl ph pump you need to run it at least 10 hours or so to work for you.
use your #'s to calculate filtering for your situation
At this point I would get the filter working and shock the pool with 1 gl
of liquid chlorine to start you out
I would even use a non foaming algaecide every 5-7 days Just follow directions for your gallons of water
hope this helps
Please remeber to rate this solution
Jul 17, 2010 | Intex Automatic Salt Water System for ...
Water flow error
Water Flow should be like this
Pool Water-
May 22, 2010 | Intex Automatic Salt Water System for ...
Motherboard fried. need to pull out of control box have located a tech who can repair, and I need to ship him the part.. Is there any other items that are needed. Notice other "relays"? What is the...
sensor read the temp on the water relay open and close the problems is not here.... read ...why the mother board fried is greenish on the back? this is due to water damage and board cannot be repair . what is happend on the control what do you read
Jul 02, 2009 | Jandy Aqualink Rs4 One Touch Control...
No LED
In the manual it states that depending on what type of salt you use, you may have a yellowish tint to the water. What kind of water are you using for the pool? If it's well water you may even more of a discoloration to the water. I'd call Intex directly and see about getting the unit fixed, even if you didn't buy it direct from them they should still be able to help you. Good luck!
Jun 09, 2009 | Intex Automatic Salt Water System for ...
Alarm will not clear "Supply Rec. Paper Tray: LTR, their are no jams and the cartridge is installed properly. MF5550
Check paper size
If it is ok go to print job cancel and cancel all jobs
if the error comes while computer connected printing
before click ok go to peinter properties and change input paper size to A4 and out put as match paper size then click ok .
Mar 07, 2008 | Canon imageCLASS MF5550 All-In-One Laser...
Jandy Aqualink Rs4 One Touch Control System Control System Logo
455 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
jhalston
Level 1 Expert
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
