Question about Bosch 24 in. SHU43 Built-in Dishwasher
Mine is humming too but cycle not starting
What else can i do b4 i call some one out?
    Sergeant:
  • 228 Answers
THERE IS A SMALL INSPECTION COVER OVER THE PUMP UNDERNEATH THE FILTERS IT IS REMOVED BY UNSCREWING A TORK 20 SCREW HOLDING IT IN PLACE THIS WHEN REMOVED WILL REVEAL DRAIN PUMP IMPELLOR SOMETHING IS JAMMING IT PROBABLY A PIECE OF BROKEN GLASS REMOVE PUMP SHOULD RUN AND APPLIANCE WORK.
HOPE THIS HELPS
Posted on Aug 01, 2009
Washing machine switches on and then hums and clicks the dial but does not operate just hums and clicks
Mind does the same thing, I'm not sure if it has to do with age or if it is time for new timer! mine does finish it's cycle, and wash's and rinses the cloths, does Yours? and it only does this in between wash and rinse cycle! The noise You hear is the timer making it's way through cycle, as I said I think it has to do with age, and in the future, hopefully a long ways into the future, the timer will need replaced! If This does this when You first start wash, then You may not be getting water into Your washer, Do you use city water or well?
Apr 03, 2017 | Washing Machines
LG Invertor Direct drive dishwasher - how to stop a cycle before it is finished and drain the machine
just turn power off and back on hit start it will drain first b4 new cycle starts
Nov 29, 2016 | LG Dishwashers
Dishwasher starts then pauses and drains.
Fixed! I had the issue where the cycle would start, the KUDS30IXBL8 would hum 4-5 times and then drain. Plastic folk pieces jammed in the disposer. These instructions took a few minutes (only 5 screws and a couple clips) to figure out how to take it apart, and it only took 60 seconds to put back together. How To Repair Dishwashers KitchenAid Repair Chopper Replacement
Apr 25, 2012 | KitchenAid Dishwashers
Hot point washer hums
it shouldn't do any damage unless the spinning washer is broken. mine hums and rocks from side to side. should not be a problem.just check that nothing is blocking the spinning washer. because that could be a cause for the problem. if it isn't blocking and the humming gets worse i is probably a fault in the actual unit. u should probably call an expert.
Mar 08, 2012 | Washing Machines
Basscube 15 hums only in "Auto" mode?
There is a guy on ebay (edwards electronics) that can repair this amp for around 150.00
Feb 20, 2012 | Cambridge Soundworks BassCube 12 Speaker
Washing machine hums
your washer hums but does not start. do you have the water turned on? mine did the same thing and i forgot to turn on the water, the hum sound was the pump
Jan 15, 2012 | Kenmore HE2 Plus Front Load Washer
Make a humming noise and spins very slowly
MINE DOES THE SAME. HOUSING IS CRACKED THAT ATTATCHES TO DRUM. WHITE METAL CANNOT BE REPAIRED.
Jul 25, 2010 | GE WPXH214A Front Load Washer
My gateway gt5056 is turn on it just idle for ever it dosen't turn on to a cycle
mine did that do you hear the hum of the fan or processor noise mines processor burnt up put a new one in worked fine
Jul 03, 2010 | Gateway GT5056 PC Desktop
Humming or buzzing during wash and spin cycles.
it's the motor that makes the humming sound..it may have difficulty in starting..when starting like this the motor draws more current and this may cause the windings to burn out..try reducing the load..if the sound disappears then indeed the capacity of the motor is deteriorating...take out motor and clean bushing and lubricate.. also realign belt ..
Jun 20, 2009 | Maytag PAV2300 Top Load Washer
Hum in sound
the tv is picking up a 60 cycle hum from the bond wire.they did not filter the main audio board.to fix it buy a 3 wire to 2 wire ac plug without the bond wire. plug it into the wall socket an it should fix the hum. it fixed mine an now no hum. fletchb321.
Jul 24, 2008 | Polaroid FLM-3734B 37 in. LCD HDTV
Bosch 24 in. SHU43 Built-in Dishwasher Logo
197 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
