How do you ''blow out the drain line''? That was the suggestion on FixYa for dripping AC units.
  • 83 Answers
You can place a water hose and blow the drain with water. pressure from the house will declogg the drain. you can also see if there's a leak.
I hope this helps.
Posted on Jun 26, 2009
Coleman Mach 48000 series roof top A/C in my camper & recently it's been dripping heavily inside the camper. We looked at the top & inside for a clogged line & can't find anything, suggestions?
I had the same problem but it wasn't a clogged drain line, it was the gasket between the roof of the camper and the AC unit. The gasket had shrunk and pulled apart allowing rain water in. To make sure you don't have a clogged drain line when using the AC do you notice water dripping off the camper anywhere besides inside? You should have some drips somewhere on the outside.
Jul 18, 2017 | RVs
After switching on the ac unit water start dripping
I assume inside the air handler closet, underneath the unit, or wherever unit is located.
Sounds like condensate line is stopped up.
You need to blow out with compressed air. You must make sure that you block air from exiting from open end of line. I use a plastic shopping sack. May have to remove cover to evaporator and insert hose in condensate drain connection in drain pan. Stuff the bag in around hose and opening to seal and blast air into line. Be sure that if there is a "T" fitting with riser and cap on the end, that it is secure, otherwise you may get a shower. You also may use the riser with the cap remove to blow out. insert hose past opening leading back to evaporator drain push bag down past opening leading back to evap drain, then seal around inserted hose and blast. The riser with the cap is where you would pour some bleach every couple of months to keep line clear.
Aug 24, 2013 | Hitachi Heating & Cooling
WATER LEAK BOTTOM OF UNIT
If this is a central AC, the
condensation drips off the cooling coils into a pan. From the pan, it is suppose to either go into a drain directly or into a sump, which in turn pumps it into a drain. Dirt or mold frequently plug the drain out of the pan or the drain line itself. You need to clear the drain with a wire or forced air. If there is a trap in the drain line, it may be plugged. If there is a trap and the line is not draining from the trap into a sewer, then I suggest you remove the trap, which is intended to block sewer gas from coming up the drain line. If it doesn't drain into a sewer, there is no sewer gas to block and the trap is unnecessary. The credulous building code requires the trap, regardless of whether or not the unit drains into a sewer.
If you are talking about a window unit, the problem is similar - the water is being blocked from where it is supposed to drain. With a window unit the water is usually picked up by the fan that cools the
condenser (hot coils) on the outside of the unit. The fan sprays the water on the hot coils and evaporates it so it doesn't drip out of the unit.
Oct 04, 2012 | Goodman CKL49AR49 Air Conditioner
2003 Toyota Landcruiser - dripping water from AC unit inside car, passenger floor board...AC works fine...clogged drain line ???
yes the drain line is clogged,, its located along the firewall and is a bear to see,, if you get under the vehicle, and look along the edge you'll see it don't blow air into it , that will just make the clog worse, take a wire, and gently ease it up into the tube, working slowly , be ready to get wet,, once you loosen the clog the water behind it will flush it out, and sometimes there is quite a lot
Sep 18, 2011 | Toyota Land Cruiser Cars & Trucks
Portable haier air conditioner drainage. Cannot find drain hole and unable to tilt ac. Water is building up in the bottom of unit.
Here is a thought, received by me from a AC mechanic recently. Window ACs no longer actually drain concensate. Rather, the water is caught in a pan with the idea it will evaporate back into the outside air. The reason for this is the dripping water frequently resulted in the growth of algae below the unit resulting is unsightly stains and sometimes, slippery conditions. Evidently, there were a lot of complaints about being 'dripped on' also. So, AC manufacturers don't put drain holes in the bottom any more. If the pan over fills, it will spill out of many makes. If you want yours to drain, put a hole in the bottom.
Like I said, just a thought.
Thanks for your question @ FixYa.com
Aug 08, 2011 | Haier hwr10xc6 Air Conditioner
Water in the drip pan- what is causing it?
I assume you are talking about the indoor unit. One function of the a/c system is to dehumidify the air. Condensation forms on the cooling coil and runs to the drip pan. There should be a drain line on the drip pan that drains the pan outside. These sometimes become clogged causing the water level in the pan to rise. Try some mild drain cleaner to open the line. Hope this helps. Let me know what you find.
May 21, 2010 | Carrier 38CKC036 Air Conditioner
I have a Weather King AC/Furnace in the attic that's dripping water into the drain pan. When we purchased our new house it came with this unit and it never dripped ater. Now, the water is dripping towards...
I assume it is dripping water when the AC is running. If you look at the attic unit, there should be a PVC pipe running from the unit - probably an insulated PVC pipe. This pipe probably goes across the attic to the edge of the house and drains outside. The drain pan may also have a drain pipe, but the one on the AC unit is the issue, and is probably plugged. Go outside and see if you can locate the AC drain pipe. See if the ground is wet below the pipe and if water is steadily dripping from the pipe (with AC running). If the pipe and ground are dry, the pipe is plugged. If you have a wet/dry vac, try connecting it to the drain pipe outside to see if you can **** the pluggage out. If you can get it clear, water should start dripping out of the pipe. This same thing happened at our house. I decided to cut the pipe in the attic, and add in a PVC isolation valve, tee, and water hose connection with plug, so I can valve out the AC unit from the pipe, remove hose connection plug, and hook up a water hose and flush the line to outside. Lowe's sells all of the PVC pipe fittings. The water pressure from the hose will always flush out the algae and crud to the outside of the house. I can also remove the plug and pour a cup of bleach down the drain pipe every couple of months to keep algae growth in check. I also cut out the trap (u-leg) from pipe in the attic and purchased a ready made trap a Lowes (the contractor who built our house had made a lousy homemade trap). I purchased a few PVC elbows and installed the trap on the drain pipe outside. By the way, our AC drain pipe comes out of our wall outside and drains near our outside unit. Our secondary drain pan drain pipe comes out outside from an eave on the side of the house. I don't know what you drain line looks like (it may have a port to add bleach, or some cleanout provisions, maybe not). If you choose to modify/improve it, then make a sketch of it, go to Lowe's and get the PVC parts you need + PVC pipe primer and cement. PVC cement dries fast. Remember, the pipe must flow downhill from you AC attic unit. You can use a regular wood saw to cut the pipe. I hope this helps you. You need to keep the drain line clear as algae will continue to grow in it. Pouring bleach in the line every month or two helps. You also need to check maybe once a month that the line is draining properly (check to see if dripping outside). You can get some serious water damage to your ceilings if the water backs up and overflows. I discovered that our drain line was plugged just in time as our drain pan drain line was also partially plugged and drain pan was about to overflow.
May 08, 2010 | Weather King 12AJA4201AH Air Conditioner
Excessive water dripping from Central A/C drian line
sounds like the overflow drain is picking up the water that means the main drain is clogged.you need to find the main drain pipe if lookin at the air handler in attic there should be 2 drains from unit one higher than other follow it and blow out drain they put the other overflow drain out the eve so if it stars leaking someone notices it and it doesnt damage cieling but it sound like it needs imediate attention befor it does go to the overflow pan and damage your cieling. i hope this helps and good luck
Sep 29, 2009 | Amana PTC153B35AJ Air Conditioner
I have a carrier split unit model#38HDL024311. It's dripping out the front of the unit. When I turn it off, There's a stream of water out the front also.
Where is water dripping? Out the outside unit or inside? Evap. Coils (indoor coils) condense when cooling so it is necessary to have a condensate drain hooked up. If the unit is leaking out of something besides the drain like out of the coil case then you have a blockage in your condesate line either in the drain pan under the coil or somewhere in the line that leads to your drain. blow the line both ways with nitrogen or pull the line out and clean it with a hose.
Jul 29, 2009 | Heating & Cooling
Water is dripping on the floor not going into drip pan at bottom of coils on inside unit could coils be dirty
Yes coils could be dirty, but your drain is clogged. To clean the drain cut the pvc line and blow the drain line out. You can put bleach in the drain pan every 6 months to keep it clean.
Sep 25, 2008 | GE Heating & Cooling
Heating & Cooling Logo
41 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
