I have a Seagate 2.5" SATA Mobile HDD. How do I back up all of my word document files
    President:
  • 2,777 Answers
You will need to attach it to your computer somehow, is it an external drive? Is it USB / Firewire? Once you connect it you can format the drive (it may come pre-formatted) and it will then show up as a drive letter in My Computer (E: drive for example). Then you can just copy and paste your word documents onto the drive.
Which version of Windows are you using?
Posted on Jun 26, 2009
Accidentally i plug different adapter. It is not working now.
you might have fried the voltage regulator on the board chances are the hdd is okay its a sata or ide open housing and go to tiger direct and buy whichever style hdd it is adapter to usb i.e ide to usb or sata to usb ot a new enclosure like nexstar cx once you got it hooked up if its still good you can get to your files
Mar 26, 2014 | Seagate 160GB 3.5" External USB Drive 160...
I had four broken DVRs of same type, I want to use their HDD in raid strip in PC, but they are DVR HDDs (Seagate Pipeline HD.2, ST3250312CS) and they are not initiable in PC. Is there any way to use them? ...
The SATA RAID interface needs to be compatible with SATA revision V2.0. Check the drives with the Seagate diagnostic tool (download it from Seagate) for correct operation. This will also check / test the SATA interface. Connect the drives directly to a PC with SATA interface to do this. If proven OK then use the RAID board.
Possibly there's a way to downgrade to SATA-1 using a Seagate tool.
Jul 05, 2011 | Seagate Barracuda 7200.10 ST3250310AS SATA...
My HDD Seagate Momentus 5400.6 500GB is not recognized by win7. I have connected it like a ex USD HDD, but there is no USB devices in Device manager. The hdd is clicking -1sec click, 0,5sec off. Thanks,...
Hi, it might be a file system error.
You could try removing the hdd from the usb enclosure and connect it directly to your pc via SATA.
(power off both of them before doing so)
If it really is the file system then scan disk should repair it automatically when turning on the pc.
Then if the pc recognizes it you can put it back in the usb enclosure.
Jun 30, 2011 | Seagate Momentus 5400.6 500GB Hard Disk...
Trying to make my seagate barracuda 7200.9 slave
1) Open your computer case
2) On the back of the drive where the connectors are, you have jumpers. These small plastic tabs change the function of your hard drive. All hard drives have a special setup procedure. The information about jumper settings is on the top of the hard drive.
3) Remove plastic tabs and put them according to "Slave" instructions.
4) Connect drive to middle connector of the cord.
5) Connect power supply cord.
6) Secure the drive in place and close computer case.
Also make sure that the main drive is not set as slave.
Apr 10, 2011 | Seagate Barracuda 7200.9 80 GB Hard Drive
Problem with DG31PR board while loading windows 2003 server.
check HDD and RAM, make sure your HDD new formated
Sep 03, 2009 | Intel DG31PR Motherboard
Brand new Seagate barracuda 500GB SATA hdd not detected
http://www.seagate.com/staticfiles/support/downloads/firmware/ http://atulchitnis.net/files/seagate.pdf
Jun 20, 2009 | MSI Mother Board (MSM865PEN2V) Motherboard
Sata drive not detected
just no other solution except upgrading BIOS properly
Sep 24, 2008 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Sata hdd detected but problem with booting&installation
i have sata hdd 160 gb of seagate and hdd detected in raid channelbut when start installing window it shows message press enter for fresh installation "no hdd found please check power card,bios configuration
Jun 30, 2008 | ASUS P5RD1-VM Motherboard
Can't open HDD drive
Hi
1. Start > Run > type in cmd then click OK to get a command prompt.
2. Type in chkdsk e: /r (replace e: with the drive letter of your external hard drive).
This won't do any harm, it will fix errors on the disk and try to recover data from bad sectors. It might not solve the problem but it's worth a try. Jyo
Jun 19, 2008 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Sata driver
check for the website of your HDD vendor.eg-www.seagate.com for seagate hdd.
make sure you format using fat32 file system.
Jan 28, 2008 | ASUS K8V-MX Motherboard
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
