Question about Hobart 24 in. LXIH-3 Built-in Dishwasher
MY FATHER IS WORKING ON A LXIH HOBART. THE UNIT IS SHOWING ERROR CODE E173. IS THERE A WAY I CAN FIX THIS PROBLEM OR A WAY TO GET THE ERROR CODES.
    Brigadier General:
  • 3,917 Answers
This is what I found in the manual...and on a couple of other sites....
Machine won't fill or won't fill high enough(LX18, LX30 display shows "E0," "E2," "E3," or "E4")
1.Low water pressure — check for clogged hose strainer; check that site water pressure meets minimum flow pressures.
2.Make sure probes are clean.
3.No water pressure — main water supply valves may not be working.
4.Drain valve open - turn machine off to drain machine, then on. Repeat twice (this assists in clearing any drain valve obstructions). Wait for machine to reach READY mode and press WASH. Slowly open door several seconds later and note water level. Close door; 30 seconds later, open door slowly and check that water level is the same as it was. If not, repeat the
OFF-ON procedure.
5. Delime machine.
Thanks for contacting Fixya
Posted on Jun 26, 2009
E3 Error code on hobart lx30 dishwasher.
my dishwasher Hobart LX 30 will not shut off and displays 30
Jan 21, 2011 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Error code "p3" appears in the digital panel with a little tool diagram. The rinse cycle doesn't work..
That code is for the booster . probably the thermistor .. if there is a hobart service center in your area, you could get one there and instructions on how to replace.
Please vote!
May 12, 2010 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Lx30h P2 ERROR CODE? WON'T DRAIN COMPLETELY - HELP
the p2 err. is on open or shorted rinse thermistor which is located on the back of the mach next to the vac. brkr. as for draining ck the drain valve for debris, and the end of the drain hose where it connects to the building drain
Dec 25, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
P1 error code on LX30 Hobart
This is a bad sump temperature probe. The unit will function, but will not heat nor display the wash water temperature.
This is a very easy fix. Order Hobart part number 328994 from your nearest Hobart parts dept.
Turn off and drain the unit. Kill the power to the unit at the circuit breaker. Remove the lower front cover. Locate the screw-in temperature probe at the front of the sump. Unplug the sensor from the wiring harness, remove with a 7/16" open end wrench. Screw in the new probe, using teflon tape of the threads, snuggly. It does not need to be super tight. Plug it into the harness, reinstall the front cover, turn the breaker back on, and start up the unit.
TURN THE BREAKER OFF AS EVEN WITH THE UNIT "OFF" THERE WILL BE 120 VOLTS PRESENT AT THE SUMP HEATER (yellow wires) DUE TO ONLY ONE LEG OF POWER BEING SWITCHED OFF!
Sep 04, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Temperature Problem
Whats the model?lxih,lx30h,lx18,lx40?What temps are low,wash or rinse?Im a hobart tech and service these units.Let me know.
Jan 19, 2009 | Hobart 24 in. LXIC-5 Built-in Dishwasher
Hobart LX 30 P2 Error and unit overflowing!
Hi drogers77,
I'm not a Hobart technician, but here what I founded in my manual for the LX30 error message:
LX18 / LX30 display shows E0, E2, E3 or E4
1. Low water pressure - check for clogged hose strainer; check that site water pressure meets minimum flow pressures.
2. Make sure probes are clean
3. No water pressure - main water supply valves may not be working
4. Drain valve open - turn machine OFF to drain machine, then ON. Repeat twice (this assists in clearing any drain valve obstructions). Wait for machine to reach READY mode and press WASH. Slowly open door several seconds later and note water level. Close door; 30 seconds later, open door slowly and check that water level is the same as it was. If not, repeat the OFF-ON procedure. If problem persists, call your local Hobart Service Office.
5. Delime machine.
Hope it will help you.
pepsicrazy
Dec 27, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Wrench and code p3 display
this is a probe booster error your probe failed replace it
Dec 09, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart 24 in. LXIH-3 Built-in Dishwasher Logo
104 people viewed this question
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
