Question about Sharp AR-M550N Copier
CLicking noise when you try to copy
When you try to copy it makes a sound similiar to a card in the spoke of a bicycle. The copy is still made and the quality doesnt seem to be affected. Is there a failsafe that would make this sound, when service is needed? Thanks to anyone that can help
  • trustee1 Nov 06, 2007
    I did as you suggested and it stills seems to be an issue. I took the rear panel off and the sound seems to be coming from the area around the end of two rotating pieces. They both move around in clockwise motion. I just cant seem to find the problem without taking more apart and before I do I wanted to see if there was an easier solution that I may be overlooking. Thanks so much for your time in responding, its much appreciated.
  • trustee1 Nov 13, 2007
    Jules, I looked into the copier further to try to find the noise and it appears to be coming from the end of the drum. When I removed the drum I also removed the back cover of the copier and followed where the drum was attatched. I located two plastic wheels that move gears that connect to the drum as well as other rotating parts. The wheel nearest the finisher when you spin it and the drum is put back in, it makes the clicking noise. When the drum is out the wheel can spin freely without any noise. Does this lead me to buying a new drum unit? Or ? I also noted after making some copies today it came up with an ERROR Code F2-37 maitnence required. I appreciate any guidance you are able to provide
  • 69 Answers
Hi im jules_09.have you check the transfer unit?may there is a piece of paper stock inside that the sensor doesnt seem to see,if no try try to see were its coming from it may be coming from the fuser unit or drum unit,any if you want to know where.full out the drum unit then try to rotate the drum gently to 360 degrees.check the gear at the where the drum gear is connected,sometimes there are plastic gear that are easily worn out also the drum gear.and at the fuser just full it out then see the fusing gear also the hot roller or upper fuser.rty lobricating the busing with oil just be carefull not to put oil in the opc drum
Posted on Nov 06, 2007
There is a clicking sound when the magnet and sensor meet when I pedal my bike. If I adjust the clicking sound, the magnet and sensor do not recognize each other and no mileage is recorded. Please help!!
the "Clicking Sound..." you hear..is them making contact, You need to re-adjust it until it stops,
or try a different set of spokes... You'll figure it out.
Nov 01, 2013 | Bell Sports Bell F12 Bike Computer
How do you level this refrigerator? Also has
Here is a tip that I wrote about refrigerators and the fan noisethat they develop sometimes...
RefrigeratorFan Noise
heatman101
Jun 15, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
1987 el camino makes clicking noise while running. clicks faster as I accelerate. sounds like somebody put a playing card in the spokes of a bicycle...
Being 24 years old it could be a number of things:It may be a exhaust manifold gasket. It could be a noisy lifter.It may even be a spark jumping from a faulty spark plug wire.
Jun 14, 2011 | 1987 Chevrolet El Camino
I have a ticking noise that sounds like it is coming from the tires; as if you put a baseball card on a bicycle tire to make it sound like it was clicking, that is what it sounds like.
Sounds like you may have a nail or 2 in your tire (perhaps gravel). As it goes around it taps the ground making click noise.. However.. since you said - sounds like a card on a bicycle - means to me to be fast clicking, it may be a broken wheel bearing. If so it should be addressed immediately as it could destroy the whole bearing assembly.
Nov 13, 2010 | Dodge Dakota Cars & Trucks
My Samsung VRT washer model WF410 makes a clicking noise when it is spinning. It sounds like the noise you hear when you put a playing card in the spokes of a bicycle. It is brand new and has made this...
I'm trying to figure this out also. I think its coming from an air vent located on the top right of the machine (facing front.) It was blowing on a tag...still investigating. Also dances on initial spin up. I'm on concrete and travertine and I think the plastic feet are sliding on the marble. Am cleaning dust and putting rubber pad down to see if that fixya. I'll post back.
Aug 16, 2010 | Samsung Washing Machines
Fisher and Paykel clicking sound
it sounds like the bearings are going out as it spins faster the noise quietens down because the bearings are more spread out and as it slows they fall lower leaving an area that it causing "friction" of a kind
Dec 27, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Clicking noise, 2004 Toyota 5-speed
Check your CV joints - usually you'll hear them clicking the most when you turn a corner while pressing on the gas, but they can make noise like that while you're driving straight. Given that it's most prominent above 35mph, I'm not sure that this is going to be the issue, but it's worth checking - if it is a CV joint, and it breaks, your car will coast to a stop and you won't be going anywhere except on the back of a flatbed.
Aug 26, 2008 | 2004 Toyota Corolla
Sharp AR-M550N Copier Logo
135 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
