Question about Hampton Bay 36 In. San Marino in Brushed Nickel Fan
Removing fan from ceiling
Hi i'm trying to remove my old hampton fan that my wife broke and replace with new one. I'm having a really hard time removing it from the ceiling can you help???
  • chig159 Nov 06, 2007
    thanks...But i can't seem to find any screws holding this thing up! the cup thing turns about 3/4's of the way in both directions then nothing!!!! i'm ready to rip this thing down....
  • Anonymous Feb 09, 2008
    trying to remove ceiling fan so I can paint the ceiling
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 105 Answers
If there is a bowl looking thing that is attached to the ceiling, that should be unscrewed (PLEASE NOTE WHEN DOING THIS TURN OFF THE POWER TO THE FAN VIA BREAKER!) It'll come down and you will see the wiring, un-do the wiring (it is color coded so you can put in a new one pretty easy). there will be a cup and a socket that is holding the fan in place, gently lift the fan up and out of the socket. there you go.
Posted on Nov 06, 2007
Replace a hampton bay ceiling fan light switch
buy hampton bay single pole fan switch for light pull three screws out pull cover off remove old switch replace with new switch
Jan 30, 2011 | Hampton Bay 24002 Ceiling Fan
I am unable to remove an old hampton bay ceiling fan it is a flush mount about 10 years old. I have taken everything off but i unable to get the motor part off
There are 4 screws on the canopy which is the part that is mounted to the ceiling box . Just remove those screws it will come down . Hope this helps.
Nov 06, 2010 | Hampton Bay (261025) Dual Mount Ceiling...
Is it easy to change our the receiver for Hampton Bay fans
Yes it is not that hard to replace an existing receiver with a new one. Caution: Turn off the power to the fan at the service panel. Remove the cover next to the ceiling which normally will have screws on the side or on the bottom under a plastic cover you remove by turning or pulling off. Inside the mounting bracket you will see the receiver. Carefully pull it out and take notice of how the wires from the receiver are connected and how the receiver was placed inside the mount. Look at the dip settings on the old receiver and set the new receiver exactly the same. The transmitter and receiver dip settings must be the same or it will not work so it is critical the new receiver settings are set exactly as the one you are removing. Now, remove one wire nut at a time and connect the new receiver exactly as the old one was connected. Make sure to tighten the wire nut securely with no bare wires showing. Slightly pull on the wires to make sure they are secure. Tape this up with electrical tape as a security measure. Once you get all the wires connected put the receiver back inside the mount just like it was. Replace the cover and then go turn the power back on. You are done.
Nov 07, 2009 | Hampton Bay 13087 70450 Carousel II...
Replacing pull chain for hampton bay ceiling fan
Buy the new switch before you remove the old switch. Then remove and replace one wire at a time, they will be labeled L-1-2-3
Aug 05, 2009 | Dryers
Do you want to sell your Covington Ceiling fans? I may be interested in purchasing them. If you live in Atlanta, I could remove the old ceiling fans and install your new ones if you need.
email me at:
Aug 02, 2009 | Hampton Bay 54 In. Flemish Pewter Ceiling...
Hampton bay glass shade broke model no. 640-658
good luck cutrite , Hampton Bays importer King of Fans in Fl prob wont even know what your talking about they don't speak English very good. If you speak Chinese you might have a chance but if the part is over a year old..'forget about it' as we would say... they don't stock old parts (over a year) and everything is manufactured in China. Try a local lighting store you'll save yourself a lot of aggravation. And don't patronize Hampton Bay it only encourages them to push garbage on us all.
Feb 23, 2009 | Hampton Bay 24002 Ceiling Fan
Ceiling fun
home depot and lowes carry hampton bay products, go to ceiling fan area and replacement blades and hardware are sold in packs of four and five. cheaper than buying a new fan. hope this helps.)
Oct 28, 2008 | Hampton Bay 24750 Huntington III Ceiling...
3-speed switch replaced with hampton bay switch. Only low speed works.
The cause to the problem was replacing a HUNTER fan switch with a Hampton Bay switch. Before removing the old switch, I noted and marked the color and position of the 4 wires. I then duplicated the connections to the new switch.
But the wire positions of Hampton Bay vs Hunter are not identical, therefore 2 wires
were crossed.
The correct way is to note the color of the wires with the corresponding NUMBER
marked on the switches, then duplicate this on the new one.
Jul 23, 2008 | Hunter 23852 Classic Original Ceiling Fan
Fan switch chain broke.
There are two types of switch for Hampton Bay fans.
One is a single-layer switch, which has all four holes on one level.
The other is a double-layer switch, which has holes in two circles, one on a higher level, and one on a lower level.
Whichever type your fans has, is the type you need to get as a replacement. Be sure to mark the old wires before removing them from the old switch, so you'll know where they go in the new switch.
I hope this helps! If you have any other questions, please feel free to ask!
Apr 27, 2008 | Hampton Bay 24002 Ceiling Fan
Hampton Bay 36 In. San Marino in Brushed Nickel Fan Logo
Top Hampton Bay Dryers Experts
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
