Question about Nikon D40 Digital Camera with G-II 18-55mm Lens
I had the same problem... Error. Press shutter release button ...
I took the lens off as recommended, then pushed the shutter release button 25-30 times and the error message went away, then I put the lens on an it works fine so far.
  • 159 Answers
No image was shown on screen while i still can take photo.
According to ehow:
Turn off your Canon 1000D and remove the memory card, lens, battery and time/date secondary battery. The secondary battery is a small, round battery about the size of a dime found in the same compartment as the main battery. It is located in a vertical slot. Slide out the secondary battery by pressing your finger on the battery and pulling it toward you.
  • Place the body cap on your camera to keep dust out. Attach the front and back lens caps on your lens to prevent scratches and other damage.
  • Let the camera sit for 20 minutes. This will clear the camera's memory.
  • Place the date/time secondary battery and a fully charged primary battery in the camera and turn it on.
  • Press the shutter release button (the button you push to take a picture). If you are still receiving an Error 99, the problem is most likely caused by the camera body itself. The camera body must be serviced by a professional camera technician.
  • Turn off the camera and insert the memory card. Turn the camera back on and press the shutter release button. If you are receiving an Error 99, the error is most likely caused by the memory card. Turn off your camera and insert a different memory card. Turn the camera back on and press the shutter release again.
  • Turn off the camera and reattach the lens. Turn on the camera and press the shutter release button. If you receive an Error 99, turn the camera off and remove the lens.
  • Turn the camera so that it is face down, and gently clean the lens contacts on the camera body with a number 2 pencil eraser or soft cloth. The lens contacts are the eight small, gold pieces on the bottom of the lens mount. Be careful not to let any of the eraser scraps fall into the camera body.
  • Turn the lens so that the side that attaches to the camera is upside down. Use the eraser or soft cloth to clean the lens contacts on the lens, being careful not to let any eraser scraps fall into the lens.
  • Reattach the lens to the camera. Turn on the camera and press the shutter release button. If you are receiving an Error 99, the error is most likely caused by the lens. Take the lens to a professional camera technician for repair.
  • May 11, 2011 | Panasonic Lumix DMC-FS4 Digital Camera
    Every time I turn on the camera it sais Error 99 could anyone explain it to me .thanks chris
    According to ehow:
    Turn off your camera and remove the memory card, lens, battery and time/date secondary battery. The secondary battery is a small, round battery about the size of a dime found in the same compartment as the main battery. It is located in a vertical slot. Slide out the secondary battery by pressing your finger on the battery and pulling it toward you.
  • 6 Turn off the camera and insert the memory card. Turn the camera back on and press the shutter release button. If you are receiving an Error 99, the error is most likely caused by the memory card. Turn off your camera and insert a different memory card. Turn the camera back on and press the shutter release again.
  • May 11, 2011 | Cameras
    D40 Nikon
    i have the same problem..only it seems mine has been caused by a piece of plastic off my lens somehow falling behind the shutter and impeding its use.I wouldn't recommend you poking around the shutter but you could remove the lens to have a look if the optics is damaged.Bringing it to an authorized dealer might be the best way to go !
    Feb 21, 2010 | Nikon D40 Digital Camera with G-II 18-55mm...
    Error code says press shutter release button again
    I e-mailed nikon for this same problem. Their solution was to take out the memory card and press the shutter release button in the demo mode. To get to the demo mode you first need to go to custom menu/controls/no memory card?/press ok/ arrow down to enable release and press ok. Now you are ready to try solving this problem. Press the shutter release button to see if it will reset the shutter release button. I haven't tried it yet but it is worth a try.
    Aug 25, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
    When i take a pic,it says error press shutter release button again
    Aug 24, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
    Error. Press shuter release button again
    I was taking pictures, then when I pressed the shutter release button, it took a long time. Then the error message came up. I tried pressing the shutter release button again, nothing happens. Still the error message. Please help me
    Sep 08, 2008 | Nikon D40x Digital Camera
    Error message...Press shutter release button again.
    Perhaps the memory card is corrupt. Try using another memory card, and always formatting them in the camera before use. (note this erases all pictures from the card.)
    If this doesn't work, try using the camera's reset function. I believe this is done by holding down two particular buttons, which may be marked with green dots. If not, check the manual.
    Also try taking out the battery, waiting 5 mins and replacing it.
    If the lens has an aperture ring, make sure it is set to the smallest aperture (biggest number).
    Try a different lens to see if it's the camera or lens.
    Otherwise I fear it may be a repair job. :(
    Aug 31, 2008 | Nikon D40x Digital Camera
    Nikon d40
    Take the lens off and continue pressing the shutter untill it doesn't react anymore, you should then have a normal menu without the error message.Put your lens on and you're all sorted.Cheaper and less hassle than sending it to Nikon.
    olly
    Apr 15, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
    Stuck shutter D100 Nikon
    The R06 is the buffer indication, not part of the error. It would appear more work is required. Other components may have failed, or the shutter itself may be bad.
    I'm afraid this one is not a DIY. Nikon is pricey on repairs, you may fair better checking the repair service search here on Fixya.
    Mar 31, 2008 | Nikon D100 Digital Camera
    Nikon D40 Digital Camera with G-II 18-55mm Lens Logo
    182 people viewed this question
    Top Nikon Cameras Experts
    Steve
    Jeff Marcus
    Are you a Nikon Camera Expert? Answer questions, earn points and help others
