Question about LG Prada KE850 Cellular Phone
Calling 1 800 numbers
Whenever I call a 1-800 number, when it says "push 1 for ____" .. I can't push anything to select the option I want... and does anyone know how I can get my hands on an ENGLISH user's manual?? mine is all in Korean. : (
  • zebu Nov 06, 2007
    when i dial the number and get an automated service and have to select options by pressing a single number, i cannot do that as the key pad seems not to respond
Press the button on the side which u swap profiles with whilst ur call is connected this then unlocks the screen and shows u the keypad
Posted on Nov 30, 2007
How do i access my reject list samsung GT-E1270
try this: (A complete guide on how to block/unblock a number)
1. From the home screen, press Menu.
2. Scroll to Settings, then press Select.
3. Scroll to Applications, then press Select.
4. Scroll to Call, then press Select.
5. Scroll to All calls, then press Select.
6. Scroll to Auto reject, then press Select.
7. Press Options.
8. Scroll to Create, then press Select.
9. Press OK.
10. Scroll to the required option (e.g. Contact list), then press Select.
11. Scroll to the required number, then press OK.
12. Press Options.
13. Scroll to Save, then press Select.
14. The number has now been blocked. Click Next to continue.
15. To unblock a number scroll to the required number, then press OK.
16. Press Options.
17. Scroll to Save, then press Select.
18. The number has now been unblocked.
Aug 18, 2016 | Samsung Cell Phones
Need instruction how to call forward?
You can now divert important calls to another mobile phone or landline if you are unable to take a call in case: you miss a call, are busy, are out of reach or phone switched of.
  • Go to the 'Call Divert' menu on your mobile phone
  • Select 'Divert if out of reach' option
  • Select 'Activate', followed by to other number option
  • Enter the number in the to other number section
  • Your Call Divert service will now be selected
Deactivate To deactivate go to 'Call Divert' menu and select deactivate / cancel option.
To forward all calls:
  • to start, enter **21*number #
  • to stop, enter ##21#
To forward calls while you´re speaking to someone else:
  • to start, enter **67*number #
  • to stop, enter ##67#
To forward calls if you don´t answer the incoming caller within 30 seconds:
  • to start, enter **61*number #
  • to stop, enter ##61#
To forward calls if your cell phone is switched off or is out of reach
  • to start, enter **62*number #
  • to stop, enter ##62#
To cancel all preset conditions:
  • enter ##002#
Jul 23, 2011 | Cell Phones
Using my Nokia C6 phone , How i can delete a single entry from my call leg rather than delete the whole entries. for example how delete a single number from the recieved or dialed numbers?
Its easy. Just go to that call log. For instance, you want to delete XYZ's number from the received calls log, go to you recieved calls, scroll to XYZ, select 'options'. In the options, select 'delete'. You would be asked if you actually want to delete the number XYZ from the received calls log. Selecting 'yes' deletes the number.
You can do the same for your dialled and missed calls.
Hope that helped you?
Have a wonderful day.
Jun 20, 2011 | Nokia C6 Smartphone
I want to dirvert calls to another handset plerase help
go to the call settings then click on the call divert option then click divert all voice calls then on that select the option as divert to another number then feed the number inside the tab now click ok check the status now if it says activate then its ok. If not activated then contact your service provider to activate the call divert for your number . because they may block divert optoin for your number
Jun 15, 2011 | Cell Phones
How do I print the fax confirmation page on the x4270? Are the instructions printed anywhere? How to set the time?
here's the solution to enabling fax confirmation: press the fax button on the printer front panel,the press option 16 or until advanced fax appears.(you can also press the right arrow to get to that option). press select push options twice.fax confirmation menu will come on the front panel display.push the right arrow button. The following options are displayed: Off - Select this option to receive no confirmation. Print for all - Select this option to receive confirmation whenever a fax has been sent, whether successfully or not. Print for errors - Select this option to receive confirmation (an error page) only when a fax has not been sent/received successfully.
***************************** here's the solution for setting time on printer display on the printer control panel,push fax push options until EDIT DATE/TIME: appears on the printer display to change the date: - press select - use the keypad buttons to enter the date. Note: If you make an error entering the date, you can use the left arrow button to navigate to the number you entered incorrectly, and then enter your correction. - press select
To change the time: Press the right arrow once, and then press Select. Press 1 for 12-hour time or 2 for 24-hour time. Use the keypad buttons to enter the time you want your All-In-One to display. Note: If you make an error entering the time, you can use the left arrow button to navigate to the number you entered incorrectly, and then enter your correction.
Press Select. If you are using 12-hour time, press 1 for AM or 2 for PM. Note: If the time is entered incorrectly, the time shown will be the default.
************************************************** i will also put in the link for the manual for additional assistance:
Jun 12, 2011 | Lexmark X4270 All-In-One InkJet Printer
Hi trsampson,
To clear recent calls, here are the steps to follow:
1. Go to the 'Menu' option.
2. Scroll, till you get to call register.
3. Select it, then scroll to 'delete recent call list'.
4. After you have selected it, you would be provided with the options to delete,
i. 'All calls', selecting it would entirely wipe off your entire call log.
ii. 'Missed call', selecting it would delete your entire missed call on the call log.
iii. 'Received calls', selecting this deletes all your received calls.
iv. 'Dialled calls', selecting this deletes all your dialled calls on d log.
You could also perform selective deleting. You might want to delete a/some paticular number(s) that is on the log, not the entire log.
To effect this, after step 2 above, you can scroll to either of 'missed calls', 'received calls', or 'dialled calls'. Select the one which pertains to the number you want to delete, scroll through till you get to the particular number(s), select 'options', scroll till you get to 'delete', then select delete, and the number is deleted. Do it for as many numbers as you want to be deleted.
To clear messages,
1. Select the menu option, scroll till you get to 'messages'.
2. Select 'messages', scroll for either 'inbox' or 'sent messages'.
3. Select whichever you want to delete from, scroll to the particular message, and select 'options', sroll again, and select 'delete'.
Hope that helped?
May 09, 2011 | Motorola Cell Phones
How in the world do you set up voice mail on the e71
Hello Debb,
Please visit the link provide below :
Apr 15, 2011 | Nokia E71 Smartphone
My samsung handset is of basic model. its samsung Guru. til yesterday i was able to make calls and send messages. today all of a sudden, whenever i dial a number, it says >> CALL BARRED and...
simple don't do anything in your phone .. just contact to your service provider they ll tell you what are changes you have to do it..
If it's useful for you means plz rate me the 4 Thumbs ....
Feb 08, 2011 | Samsung Cell Phones
Intercom use
We have the 25414RE, so I can tell you how ours works and hope it helps solve your problem...
You first have to assign each phone a "number". Push the menu button, and go to phone options (you scroll by pushing the review button to the left or right), choose set phone id (once you are on that option push the select/save button just above the review button) - I started with the first phone I plugged in and made it number one, and so on (we have a total of 5). Once the phone ids are established, simply push the intercom button and the corresponding number on the right speed dial/intercom numbers - it should dial the phone you want. It also has an option (again we have the 25414RE) to have the phone auto answer the intercom - so if you are paging someone in a room that isn't near the phone, or the phone is shared by several users, it picks up without anyone having to push anything. Otherwise, the phone that you are calling has to either have the handset picked up or the speaker button pushed. Hope that helps you!!
Mar 10, 2009 | RCA 25404RE3 Corded Phone
Blackberry Pearl 8100- Contact picture/name does not show when certain contacts call.
You might try performing a backup in the Desktop Manager, then performing a device wipe. You can wipe the device by going to Options > Security Options > General Settings. Press the menu key, then select Wipe Handheld.
After the device is wiped, then use the BlackBerry Desktop Manager to restore the data back to the BlackBerry. Then test it out and have someone contact you.
Oct 01, 2008 | RIM BlackBerry Pearl 8100
LG Prada KE850 Cellular Phone Logo
50 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
