Question about Dryers
Clothes only warm and damp after an hour
Dryer will run as much as an hour and clothes still not dry. They are warm but damp. It is a SG1000 Maytag.
  • 3,600 Answers
Try checking to see if the vent is plugged up, this includes the lent catcher the hose and the outside ait vent.
Posted on Jun 26, 2009
MAYTAG NEPTUNE DC MOD# MCE8000AYW
Your exhaust is gettting restricted and not able to remove the moisture from the clothes. Also check lint screen with very slow flow of water. If water rolls off wash filter good .. If water can't pass through smoothly then air is also having problem being pulled through as well.
Nov 15, 2016 | Maytag Dryers
Clothes coming out wrinkled after drying
Is the dryer heating? If so try using dryer sheets and allow a bit more on the timer, if the clothes are still damp..If the dryer is running properly I see no other way to solve this.
Jun 07, 2014 | Maytag Atlantis MDE7400AY Electric Dryer
No matter what settin the dryer is on my clothes will only get a little warm, but won't dry. It won't heat up as usual.Had a load in there for a few hours yesterday. They are still damp. When dry clothes...
You vent could be the problem. Snow blocking the vent can cause the dryer heat to shut down rapidly. Make sure your vent is open to the outside. Get some windex and clean them moisture sensors inside the machine. If a film developes on them then moisture cannot be detected by the control. It might think the clothes are dry and shut her down. Maytag Bravos Dryer service Manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 03, 2011 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Have a whirlpool cabrio gas dryer. It takes several hours to dry one load of clothes. The clothes seem to stay damp towels may take all day... what could be the problem
Have you opened the door while its running to see if its warm inside (heater working) If its getting warm and still not drying the clothes properly you likley have a air circulation concern. With the unit running check the exhaust vent outside from dryer it should have a good flow of warm air, if not you have a restriction sowher between the unit and outside. Heat alone will take forever to dry clothing,you need good air circulation to remove the moisture from the clothes otherwise all you will end up with is warm moist clothing.This generaly happens over a long period of time and then all of a sudden you realize the dryer is not working like it use to..Hope this helps you with your concern.....
Aug 09, 2010 | Whirlpool Dryers
Clothes dont dry no heat Maytag gas dryer runs well but no heat clothes are damp
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
May 15, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Dryer is not drying clothes very well
check your wall vent,if it is clogged it will not dry right-mike
Jan 24, 2010 | General Electric DHDSR46EGWW Dryer
The Dryer runs forever and the clothes dont dry
there are two elements on the back wall of the dryer and if one goes it will still get warm but not to dry all the way and will not trigger the heat sensor to finish
Dec 12, 2009 | GE 5.8 Cu. Ft. Extra-Large Capacity...
Not drying clothes still getting warm and turning but despite leaving it for hours the clothes never become dry just warm and damp
sounds like your clothes are not spun dry enough try spinning on maximum speed alternatively check your water pump is not partially blocked maybe you need to clean filter let me know how you went
Nov 12, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
Dryer not dring clothes completely
need to check your vent duct. if clogged it won't let the air flow through the dryer needed to dry your clothes.
Jun 24, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
The vent may be stopped up, or the vent hose crimped so the air cannot escape, you can check the air flow at the vent on the outside of the house while the dryer is running.
try cleaning the vent and the lint screen with a vacuum cleaner, you may need to replace the vent hose, this should solve the problem
Jun 02, 2009 | Roper REX4634KQ Electric Dryer
Dryers Logo
168 people viewed this question
Top Dryers Experts
