Question about Hotpoint NVL333GY Gas Dryer
Need replacement part for front dryer door sensor - broken
Front door sensor and holds the front door closed, plastic parts broken after much use. Need a replacement part, where can I order this?
  • 351 Answers
I sell parts online you can visit whirlpoolpartssurplus.com and get the phone number off there and i can order it for you
Posted on Jun 26, 2009
Door will not lock light stays on
Usually this is caused by the door being bent, the hinges being bent, or a worn out door strike/catch not holding the door tightly closed. Lol, got kids?? Mommy's little helpers love to lean on the doors(the ones that open/close vertically). Also, slamming the dryer door can break the little plastic arm attached to the door switch--I see MANY switches with the arms broken in-half or the strikes/catches damaged from slamming. Usually a relatively simple repair to replace the strike/catch.
Aug 13, 2015 | Kenmore Dryers
The door will not close it is on the dryer looks like the clip that the door connects to has snapped as the door part is not broken
An exact make and model number is needed on all dryers, or any appliance for that matter, for an answer.
Every make/model of appliance uses different style parts to hold the door closed. Some are a simple spring clip inside the front panel, while some models can range up to complex electrical-activated locking mechanisms. A make/model will pinpoint your exact defective part.
Nov 05, 2014 | Dryers
The dryer door won't stay closed on my 90-series electric. Doesn't matter if the dryer is running or not. Have to keep the door closed by propping a weight bar against it. Any suggestions to get this...
There is a door catch made of plastic that holds the pin thats sort of arrow shaped on the door... The plastic catch is located on the front of the panel and can be easily replaced....Call the local repair shop/man to get the part....very cheap part maybe a couple of dollars at most... You should be able to remove the broken one with just a set of pliers and a screw driver...doesn't matter anyways its already broken right!! the new one will push and snap right in....Good Luck
Apr 20, 2010 | Kenmore Dryers
Loud humming sound while drying, need instructions on disassembly to properly diagnose
Disconnect power to dryer. Open door, remove phillips screw from 4 and 8 O'Clock positions, close door. Use putty knife (preferably a plastic one to prevent scratching) to push in the two clips holding the top to the front panel, then swing the top back, revealing the phillips screws holding the front panel onto the body of the dryer. Remove them and un-hook door switch and drum light connections, allowing total removal of dryer front panel. Remove 4 phillips head screws retaining front drum support and lift it up just a bit to remove it. Reach back under drum to the left side to release belt, allowing drum to come out of dryer.
Jan 29, 2010 | LG DLE2532W Electric Dryer
Broken catch
what has happened is that the ridiculously flimsy plastic that the catch spring pushes against has snapped off. I tried getting it plastic welded but still too weak finaly I took off the door unscrewed the transparent central part(remembering to keep the little black plastic rod at the top that operates the microswich when the door closes then snapped off a piece of hacksaw blade about15 mm long and put it where the plastic had been. I carefully lifted the end of the spring over the blade and while holding it screwed back the transparent part so that it held the blade in place. Works really well!
Jan 14, 2010 | Smeg WDI12 Front Load Washer / Dryer
Clothes getting stuck in door seal when drying.
the plastic that you see overlapping the metal on the sides of the opening is in two parts, top and bottom, you can see the seem. the top is the smaller part, this plastic is also the drum support on the front. There are some glides on the top section that wear with time, after a few years they may need replacement. Perhaps these are worn out dropping the drum creating an uneven gap and catching. there is also a felt strip in there between the front of the dryer and the drum, keeping it back.
To view this remove the top by removing the 2 screws inside upper door opening holding top down. then lift top and if plastic console slide to left then pull away, metal -just pull straight. remove 2 screws holding front to cabinet sides. pull front forward. glides are visible on top. if not there or worn thru plastic replace upper plastic support
May 05, 2009 | GE DBXR463EDWW Electric Dryer
Broken door switch
on the corners of unit console ,,are plastic end caps,,pull them of with your hand ,,grasp it and tug hard,,now you see 2 a scew under each cap..remove screws ,,than flip the console back...now under the console theres three screws holding lid dowb,,remove them slide lid forward ,,,but screw for door switch are on the bottom of front door panel..always unplug first...onthejob
Jan 15, 2009 | Kenmore 63942 Dryer
NVLR333ETOWB HOTPOINT DRYER EATING CLOTHES
I have the same dryer doing the same thing. Open the door and take the two screws out and lift the top. Remove the two screws that hold the front on. Remove the front. On mine both the plastic parts that stay on the front when it is removed are cracked and needing replaced. I found over 20 buttons that the dryer had pulled off clothes stuck in the front door. I'm sure if it will be cost effective to buy both these parts or not.
Jan 13, 2009 | GE DBXR453EV Dryer
LG Dryer DLG7188RM LP conversion back to NG
Disconnect power. Open dryer door and remove 2 phillips screws near lint filter. Remove three phillips screws at very back of dryer top which go through an L shaped part into the back of the dryer. (the L shaped part remains attached to the dryer top) Push the dryer top back about 2 inches and lift off. Remove one screw at each top front corner holding front control panel on to dryer. Remove control panel by carefully releasing plastic tabs which are holding front control panel onto metal support. (Watch out for sharp edges !) You can unplug all electrical plugs, or just swing it up on top of the dryer. (careful not to scratch the plastic control panel) Remove the four phillip screws now assessable at the top of the dryer's front panel / door panel. Tilt forward, unplug door switch and drum light, and lift front panel off . Now set the panel aside. At this point, you may be able to continue with the conversion, but it is easier to do and see if you remove the drum.
To remove drum, Unplug the sensor wire at the bottom of the drum support and remove four phillips screws (going into sides of dryer) holding front drum support and lift up and remove front drum support. Reach in under the drum to unhook the belt. Take drum out.
Take two phillip screws out of flame spreader and push flame spreader back off brass orifice into the burner cone a bit to remove it. Unscrew brass orifice and replace with the Natural Gas orifice. Turn the brass slot headed regulator blocker screw on the front top of the gas valve all the way up. Reassemble.
Sounds complicated but it's not real bad.
A FixYa rating is expected with this much help. Thanks.
Nov 20, 2008 | LG DLG5932W Gas Dryer
Closing the dryer door
you need a part number 5366021400 latch kit I think take your model and serial number to you local appliance dealer and they will probably have one on the shelf and its so easy to install just pull the old broken part out and replace with new one
Nov 15, 2007 | Frigidaire Affinity ATF7000ES Front Load...
Hotpoint NVL333GY Gas Dryer Logo
240 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
