Question about Jl Audio 300/4 Car Audio Amplifier
How can i contact Mark Skinner ?
Could i please get your business phone#? i have 2 of these amps. wondering if you can help me make 1 good amp out of the 2.
3 Suggested Answers
SOURCE:
  • 84 Answers
SOURCE: 1 10 jl jl 250/1 mono block amp cuts off an on help
your subwoofer is wired incorrectly to your amplifier. Figure out which ohm load of subs you have and then what ohm load options your amp is stable at. Next go to either the Crutchfield website. find their learning center. go to subwoofer wiring diagrams. or go to www.the12volt.com and find their section on it
Posted on Jun 14, 2009
  • 5 Answers
SOURCE: i have 2 12 inch jlw6's and need a amp but dont
yea the jl either setup will be good for those woofers but for the money an to get the power i would try a hifonics 2000 or the 2600 brutis or mtx or2 poweraqustic 4000 planet audio they will work great or give me a call there are a lot of amps to choose for the money an the power
Posted on Jul 25, 2010
How do I reset the message indicator light?
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Dec 18, 2012 | GE Rca 25414re3-a Executive Series 4 Lines...
How can i contact dell ? if its via email it would be much help .i want dell costumer service email ,,,can someone help me please !!!?? or can i get their international phone number to call them...
Contact Dell Support or Customer Service by phone. Please have your system service tag or an order number ready to enter upon calling.
Product Support:
General Number:
1-800-624-9896
Employee Purchase Program:
1-800-274-1410
Student, Faculty & Staff Purchase Program:
1-800-274-1410
Customer Service:
Order Status:
1-800-433-9014
Dell Preferred Account / Dell Financial Services:
1-800-283-2210
Home & Office:
1-800-624-9897
Small Business:
1-800-456-3355
Medium Business:
1-877-671-3355
1-800-274-1410
1-800-274-1410
Sep 01, 2011 | Computers & Internet
I'm having the same problem as Mark did on Aug 8,2008..was wondering what the solution was? Thanks, Ron
Dear friend! You would have mentioned exact problem of your fridge. But as you mentioned, I search for the complaint of Mr.Mark and understand the problem. Please follow my advise step by step.
Once you get hum noise or any strange nise in compressor, don't switch on until you get proper advise or repairman.
1.Power on.
2. Check compressor is working by amps meter clamping in phase or neutral wire.
3. Compressor starts but off with clicking sound. It means compressor taking high amps and overloard protector cuts off. It may happens due to defective relay also. Replace relay and check. If still compressor high amps, you have to replace compressor.
Normally 5 to 7 years warranty for the compressor. If no response over phone with your supplier,bring invoice to supplier personally and demand for replacement. It's your rights. Hope, write more with full details, if you require any more suggestion.
Jan 27, 2011 | Jenn-Air JBL2086HES Bottom Freezer...
Nokia 2320c-2b unlock code please imei:011975003866993. email:[email protected] . thanks in advance.
You can get the unlock code through online..........give your IMEI number and get the unlock code for ur mobile.... i will suggest the website Unlock-Zone.com which is doing good service .....you can approach this website.
This site is nearly perfect and they were recommended highly in the cell phone forums. I used them to unlock my cell phone. contacted them and within 30 mins i had my unlock code and my phone was unlocked.
Hope this helps.
Dec 07, 2010 | Cell Phones
How do you time a 1995 600 ninja
Turn the engine over by using a 17mm socket or spanner on the crank until the no.1 inlet valve goes down & then comes back up; continue turning until the T mark for cylinders 1:4 lines up with the rear mating surface of the 2 crankcases, number 1 cylinder is now at top dead center on the compression stroke.
The cams are marked 117 IN & 117 EX so they don't get mixed up, align the IN & EX marks on each sprocket with the the cylinder head surface so that the IN marks face to the rear & the EX marks face to the front.
Next check the no of roller pins in the cam-chain between the inlet cams IN mark & the Exhaust cams EX marks, make sure that all the slack is taken up on the rear run & that there is none at the front or between the camshafts: There must be 30 pins in between the 2 marks (including the ones next to each mark)
If everything is still the same when you have the camshafts bolted down you are OK
Ride safe
Bike-Doc
Please mark this as very helpful (if it has been!!) - it helps my ratings
May 08, 2010 | 1995 kawasaki ZX-6R Ninja
How do i save all my contacts to the sim card?
Contact move to SIM.
1. GO in Contact. ( All person name you viewing now)
2. Select OPTION> select MARK/UNMARK> select
MARK all.
3. select OPTION again> select COPY> select TO SIM CARD. its done.
Thanks & waiting for your further quarry.
Feb 05, 2010 | Samsung SGH-G600 Cellular Phone
Dropped phone in toilet. please please please help. i need my ph.
http://www.fixya.com/support/r3771170-phone_water_damage
Apr 24, 2009 | Motorola Mobility RAZR V3
Jl Audio 300/4 Car Audio Amplifier Logo
Top Jl Audio Car Audio & Video Experts
Mark Skinner
matthew walsh
Level 1 Expert
Dalynn Turner
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
