Question about HP Photosmart 8150 InkJet Printer
I am trying to print invitations 5.7 X 7.7 and it won't except the paper. what do I do?
  • 1,555 Answers
In the printers property first you have to define the paper type wether you are using photo print or whatever type of paper you are using select the nearest option card type of photo paper type then only printer will be able to accept the paper
Kindly rate my solution
Posted on Jun 26, 2009
SOURCE: paper mismatch
you have to load the printer driver for HP Deskjet 990c. This worked for me perfectly and I'm sitting here printing my wedding invites right now! Good luck!
Posted on Jun 15, 2008
Inky
  • 691 Answers
SOURCE: printing heavy weight invitation stock on Epson R200
The card is probably too thick. Try cleaning the feed roller in the Sheet feeder to improve its grip. Check the GSM of the paper is within the spec of the printer.
Posted on Nov 09, 2008
  • 6 Answers
SOURCE: Can't Print Invitations
There is a workaround for this problem by tricking the printer.
The paper sensor, on my printer model hp4500 seems to only sense the paper at the beggining of the print job.
What I did to trick the printer to print on odd size paper is slide the paper adjuster to 8.5 and put a regular white sheet in. Then put your odd size paper under it. When you print your document set the number of copies to 2 and print. The printer is going to sense that the paper is correct, and start the job.
Here is the tricky part... once the first 8.5x11 sheet is almost all the way through quickly slide the paper adjuster over to match the size of your odd width paper. The printer should pick up the odd paper and print the second copy. Fool you printa! You should be able to do batches of odd paper size under the first 8.5X11. I hope this helps.
Deny
Posted on Jun 27, 2009
  • 8404 Answers
SOURCE: Why won't my printer print on vellum paper?
Im guessing ...
I had a similar experience with a different brand ...
Your printer thinks it grabbed two sheets of paper.
Open your priter program (in the control panel) and see if there is a setting for Vellum
I hope this works for you
a
Posted on Oct 13, 2009
SOURCE: How to print 5 X 8 invitations on an HP Photosmart C309a printer
I think it's more or less the same on Mac or PC. Hit Print in your software, then when the dialogue box comes up you should see several options settings. There will be a pull-down menu that lets you choose paper size. (This menu is sometimes buried in another sub menu called "printer options" or something similar. It can be tricky to find this in some apps like Photoshop). Just select your 5x8 size and then at the top of the dialogue box you should be able to save it all as a preset. Pull down the "preset" tab and select "Save As..." then you can name it and pull it up each time later.
Hope this works.
Posted on Mar 28, 2010
I am trying to print a wedding invitation on 5.5" x 8.5" paper and I keep getting paper size problem.can the HPC5180 print that size paper
3 in x 5 in (min) - Legal (8.5 in x 14 in) (max) is the spec per HP. Have you tried to set up the paper size as "custom" in both the driver and the program? This may help if the size you want is not listed in the properties dropdown.
Jun 17, 2010 | Office Equipment & Supplies
Paper size
Okay, go to your printer folder Start/Printers Right click on your printer (Officejet 6310) and click on Properties. You will see a button near the bottom called Printing Preferences. Here is where you choose your paper. You can make your choice here and choose to make it your default settings (click Apply to make the new paper your default to print your invitations...you will have to change back after). You may change the quality of print and paper type as well since the default setting won't provide the quality of print you desire. From here it's pretty straight forward. Feed your invitations into the paper tray as you would normal paper and try a test print for quality control. Once you've got the desired output, print the rest of your invitations.
Apr 16, 2009 | HP Officejet 6310 All-In-One InkJet...
Printer says to re-insert paper face down.
You must have the default printer settings changed to "double-sided" printingor "print on Both sides".
Check in your printer properties: 'Right click' the printer icon. Select "properties", "Printing preferences", "finishing", un-check "print on both sides" (these options vary slightly by printer model, so just check around on the different buttons).
That's my best guess. :)
Mar 21, 2009 | HP Photosmart C5180 All-In-One InkJet...
Print 5 x 7 invitations on 3100
You need to adjust the paper size in page setup of the program that you are using to create the invitation. What program are you using?
May 19, 2008 | Dell 3100cn Laser Printer
Paper mismatch
Hi kingwa55,
I have an hp photosmart c4480 and was having the same problem printing wedding invitations. Same size 5.5"x8.5'. Im not sure if this will work on your printer, but this is what I had to do.
Click on Print, then Properties, then features.
About half way down there is a drop down box under sizing options.
Click on custom
Create a name, and put your width and height in.
Click Save and then OK
Completely X out of the print options.
Then Click
File, print, properties,features, click the drop down box under sizing options.
Click more and scroll to the bottom and it should be there.
If your options are different then mine, I'm sorry for wasting your time.
Apr 23, 2008 | HP Officejet 6310 All-In-One InkJet...
Print Size
you have to choose the paper type in the printer driver option wheather envelope or A4 paper see the preview before printing
Mar 22, 2008 | HP Deskjet 3915 InkJet Printer
HP Photosmart 8150 InkJet Printer Logo
83 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
