Question about Cuisinart DCC-1200 Coffee Maker
Switch went out in one year, my neighbors went out a day later
Defective switch?
  • 85 Answers
Hello staun1,
The unit won't turn on when there is a plugged up filter or plumbing problem. See the following, it may be a simple fix.
I recently had this similar problem. If you still have you machine try the following.
Your described problem may be one of two problems. Let's start with the easier solution first. In the DCC 1200 there is a filter "stick or column" in the left rear. Pull it out and remove the clogged carbon filter(s) that are in there. Shine a light into the receptacle and remove the debris in the bottom. It is likely that this is causing the problem with you machine needing to be started on multiple times. See if this solution works. If it does, you might run 8 cups of water and 4 cups of vinegar through to help decalcify the units plumbing. Do this once or twice and then rinse with at least one pot run-through of clean water. If this works then you are good to go.
Next, if this does not solve your problem we can do the following: unplug the unit and lay it on its back. You will need a #10 torx driver (hardware store if you don't have one) to remove the bottom cover plate. There are 4 torx screws holding it on. When removed, you will find 2 orange hoses. Carefully attempt to remove the left hose without splitting. I used a eyeglas screwdriver to loosen it up. If it splits, just cut off the split and stretch it to reconnect when time comes. As you look into the hose you will find a little black valve inside as well a some gunk. Clean it all out with a fine wire as best you can. Rinse well. Attempt to reconnect the hose back onto the pipe. Slip the pipe clamp back into place. Replace the cover and screws and you should be good to go again. This is not as daunting as it may seem. You can do it. :o) Good luck! If this answer helps, please leave positive feedback for me. Much appreciated. Regards, NormanZ
Posted on Jul 09, 2009
How can I disengage alarm so not going off at all hours of the day and night?
one would have to think it would . a quick disconnect would make it a lot easier . Search results for disconnect switch
Mar 31, 2015 | 1999 Honda Accord EX
Why wouldlight work for couple days then not work, after couple hours it works
If you have a remote, change the frequencies in the receiver & transmitter. One of your neighbors must have a remote fan with the same frequency. Also, make sure the wattage in the bulbs are correct.
Oct 01, 2014 | Hampton Bay Dryers
Gateway 6920
The dying hdd cause some problems. Replace the hdd.
Feb 21, 2014 | Computers & Internet
Have a 2002 ion that sometimes wont start but if left for 10 mins will start up.
I have 2003 Saturn Ion. I had this problem over and over 2006 - 2008. IT IS THE IGNITION SWITCH. IT IS DEFECTIVE IN ALL ION'S.The replacement may be defective also, not sure. Mine was driving fine, went ino store for 1 hr came out stone cold dead, would not start and key **** in. Had to have towed to Saturn. They said it was battery and replaced battery.I said this did not make sense. 6 yr battery only 3 yr old , never weak start, never run down, in summer? It happened again 2 mo later. They tried to say battery , I said no. They checked battery. It was fine. Could not find problem. They did total electrical check. It happened again 1 mo later. drove into feed store. Went in came out it happened again. I got jump from someone 30 min later and started right up. 2 wks later same, I got jump 20 min later started. 1 mo late same. Sometimes it would just start up. Took to another Saturn place. They said Ignition switch, saturn was having big problem with this on Ions. Got changed and no problems for 1 yr. I was talking to repesentative at Saturn Headquarters. I told the problem. They said the ignition switch has an electrical component, or it is hooked to electrical component. THEY SAID IF I HAD JUST SAT THERE 20 MIN WITH KEY OFF, THE COMPUTER CHIP FOR IT WOULD HAVE RESET ITSELF WHEN IT COOLED DOWN AND I COULD HAVE STARTED IT EACH TIME. IT WAS BEST TO GET REPLACED AND NOT WORRY, BUT THIS WILL HELP YOU IN A STRESSFUL PINCH, UNTIL YOU CAN GET THE IGNITION SWITCH REPLACED. NOTE: Go to Auto Zone , O 'Reilleys, Pep Boys etc, get a repair manuel , CHILTON $ 23- $ 25 , for your year , make, model car. CHILTON IS MUCH BETTER THAN HAYES MANUEL. It is wonderful and many things you can do yourself.
Feb 09, 2010 | 2003 Saturn ION
No power to dishwasher
Do the following:
  1. Check the power from the wall outlet or the branch circuit itself.
  2. Check for a blown fuse or a tripped circuit breaker.
  3. Check the wiring connections of the dishwasher from the house wiring.
  4. Check the door switch. Remove the control panel cover or the interior liner of the door whenever it is applicable. Replace if defective.
  5. Check the timer or selector switch. replace if defective.
Aug 30, 2009 | GE Nautilus 24" Built-in Dishwasher
P1684 dtc code on 2001 dodge grand caravan sport.
Yah code 1684, it just tells you that battery/computer has been disconnected within last 50 starts. If it doesn't drive you nuts, give it some time, you'll be suprised how quick 50 starts will go by & light should go out
Sep 26, 2008 | 2001 Dodge Grand Caravan
Cuisinart DCC-1200 Coffee Maker Logo
236 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Marvin
Marvin
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
