Question about Jack Lalanne Power Juicer (Stainless Steel)
The cap that the blade screws down on split in half. The blade can not screw down to stay on. How to replace this?
  • 13 Answers
Http://www.powerjuicer.com/power-juicer-parts-accessories.html This is the site for ordering parts and instructions for replacing them.
Posted on Aug 01, 2009
My lid doesn't seem to fit properly. When I put the top on to cover the screen, it doesn't seem to fit together properly-- the bottom of the chute that you throw the fruit and veggies down butts right up...
Is this a new cover? There is an adjustment. On the bottom of the machine, dead center,
there is an adjustment screw with a locking nut. Unlock the nut and the turn the screw
counter clockwise, this will lower the motor shaft and consequently the blade. Once you
have clearance and install the cover, turn the screw clockwise until the blade contacts the
chute, back it off a half turn and lock her down. This will establish the correct gap between
the chute and blade. Also if your chute is ever chipped or scored by the blade because
of excessive vibration, you can file the chute level and readjust the gap.
Mar 13, 2011 | Omega 1000 Juice Extractor
Just received replacement Latch arm for Omega 1000. Old one is removed. Can not put the new one. Top part does not slide in. Also noted the old part and new part look different. Base is longer in the...
Believe it can be done. You might have to file or shave the new arm a little then seat it as best
as possible and tap it in place with a screw driver and hammer. If you do manage to attach
the new arm and the fit is a little too snug when you latch down the cover, file the upper tip
of the arm for a little more tolerance. Also, believe it or not, a worn blade will produce less
vibration. There is a set screw bottom center. With the juicer fully assembled, unlock it,
turn it clockwise until feed chute contacts the shredder blade and back it off a half turn.
You now have the proper gap between the chute and blade.
Jan 30, 2011 | Omega 1000 Juice Extractor
When we juice, it turns and moves across the counter
Both the Omega and Acme juicers vibrate no matter what you do. I found a worn shredder
blade actually produces less vibration. However this involves filing the cutting burrs down
and resetting the blade to chute gap. If you're up to it, take the blade out and file each row
of burrs about halfway down. Then with the juicer fully assembled, unlock the set screw on
the center of the bottom, turn it clockwise until the chute contacts the blade, and back it off
a half turn. The set screw actually raises and lowers the motor spindle. Both companies
would not agree with this, but this solution comes from operating my 21 year old Acme.
I recently replaced the blade and the juicer immediately began tap dancing. Went back to
the old blade.
Jan 16, 2011 | Omega 1000 Juice Extractor
Excessive vibration and rattling when I have less than a cup of juice extracted.
I've had an Acme for 21 years and I don't care
what anyone tells you-they vibrate. After years
of trial and error I found mine vibrates less with
a worn blade that I sharpen with a drill. With
a new shredder blade you actually have to file
down the cutting burrs about one third and
adjust the blade to chute gap by unlocking
the adjusting screw on the center of the bottom,
turn it clockwise until blade contacts chute, and
back it off a half turn. Apparently with a slightly
duller blade, smaller gap, the produce goes through
more slowly and evenly. Also severe vibration will
cause the blade to jump up and chip the chute.
Dec 24, 2010 | Acme 5001 Supreme Juicerator Juice...
Hi I have an older acme supreme juicerator, model # 11je23. Do the newer baskets & lids fit this older model? Or can a guy get original parts?
Believe the basket is the same. The newer lids have a flange
around them which can be filed down. Takes time, but file away
tapering it until it fits in the juice bowl. With a new lid you may
have to adjust the chute to blade gap. On bottom loosen center
locking nut and turn adjusting screw clockwise until chute contacts
blade, then back it off a half turn and lock it down. A few older lids
are around, but it's hit and miss.
Nov 05, 2010 | Acme 6001 Juice Extractor
Cutting Blade won't come off
I do not have a tool so I used two pen tops, turned the blade counterclockwise while ensuring the filter basket stayed put. It worked well
Apr 16, 2008 | Jack Lalanne Power Juicer 250 Watts
How to dissassemble Jack Lalanne Power Juicer?
After about a half hour I finally figured it out. I'll go through all the steps.
1. Remove pusher from chute.
2. Pull the locking bar down over the spout.
3. Remove lid.
4. This part is tricky. Stick the orange crescent tool into the blade holes and while holding the filter basket steady with one hand, turn the blade couterclockwise while pulling up.You do have put a little muscle into it. And remember, if you don't hold the filter steady, the whole damn thing just spins.
5. Remove the receptacle.
Good juicer, but it seems unnecessarily complicated.
Jan 01, 2008 | Jack Lalanne Power Juicer 250 Watts
Screw that holds down the blade in cwnter
try here, not sure if it's listed or not though: http://www.healthnutalternatives.com/acme5001.htm
Sep 02, 2007 | Acme 5001 Supreme Juicerator Juice...
Jack Lalanne Power Juicer (Stainless Steel) Logo
398 people viewed this question
Top Jack Lalanne Juicers Experts
Starnley Johnwells
Starnley Johnwells
Cory Koby
Cory Koby
Are you a Jack Lalanne Juicer Expert? Answer questions, earn points and help others
