I have changed the batteries several times - so I don't think it's the battery as it is fully charged
I can get as far as logging on but then the screen then says logging off.
Any help or suggestions try?
Thanks
Well, You can easily isolate the issue
>If you have a diff laptop, try swapping this battery with that NB and charge it and see.
>If you have a diff battery, check that in this NB> If that works fine, it could be an issue with the battery and you may have to replace that .
>If the defective battery works fine with the diff NB>That could be an issue withe original NB.
Finally you can calibrate the battery by charging the battery till 100% and work on unit without plugging into adapter and drill down to 0% and charge it again and check, It should give better battery back up
Let me know :)
This is your windows problem. Pls take your data backup and format c drive & install windows again your problem will be solve
