Question about Pioneer DEH-P6900UB CD Player
How to install a dual xdm6350 - Pioneer DEH-P6900UB CD Player
My radio whas take of to change my car. Wen i trial to used it the light on the select it is red. I have trial to reset but the select still red and not blue. I am not able to listen cd or radio. The...
not everyone working in the car audio installation is good. not pointing any fingers here. has this problem recently occurred or was it like this since it was installed?
Sep 27, 2013 | Dual XDM-6350 Car Audio Player XDM6350
MY USB port says reading when i connect a USB drive. WHy?
ANSWER: The USB is not going to work with your iPod. It is intended to be used with a flash drive or external hard drive with a folder structure containing either .mp3 or .wma files.
REASON: The way the USB works on the system is that it reads all the files and folders on the entire device and will say "reading" until it reads all the files and folders. This should only take a few seconds but if there is tons of files it may take longer. Main problem: An iPod contains much more than just music files and folders - it contains an entire operating system. Worse, the operating system which the iPod uses is protected, keeping other devices except for iTunes from reading the music files.
SOLUTION: You will need to use a flash drive or external hard drive with your USB. This device can only contain music, and the music must be organized into folders. Your iPod will not work. However, you can use Auxiliary input using a cable which both ends are 1/4" headphone jacks, one end going to the iPod and other plugged into your stereo.
Good Luck! - Chris Proia
p.s. Here is the User Manual for your XDM6350 : http://www.dualav.com/support/manuals/xdm6350.pdf
Jul 15, 2011 | Dual Electronics XDM6350 Car CD/ MP3...
When connecting iphone in usb port, display stays reading and nothing happens on dual xdm6350
ANSWER:
REASON:
SOLUTION:
Good Luck!
- Chris Proia
Mar 23, 2011 | Dual Electronics XDM6350 Car CD/ MP3...
Trying to install an XDM6350 Dual Stereo system into a 2002 F150.....need a wiring diagram.
Here is the User Guide for the XDM6350:
Go to the "Installation" section and there is a wiring diagram there.
Jan 29, 2011 | Dual Electronics XDM6350 Car CD/ MP3...
My dual xdm6350 won't read or charge itouch... It just says reading. Any suggestions?? Thx
ANSWER:
REASON:
SOLUTION:
Good Luck!
- Chris Proia
Oct 13, 2010 | Dual Electronics XDM6350 Car CD/ MP3...
When I plug my iPod into the XDM6350's USB jack, it keeps saying "Reading," and never goes any further than that. I've given it a really long time, though I don't have that many songs on my iPod, but it...
ANSWER:
REASON:
SOLUTION:
Good Luck!
- Chris Proia
Aug 03, 2010 | Dual Electronics XDM6350 Car CD/ MP3...
What does the yellow and white wire do for a radio in a 1987 Chevy S10 pickup truck
your yellow wire is your constant 12v sorce which acctually allows your radio to hold its memory your white wire is for your left front speaker positive
Mar 06, 2010 | Dual Electronics XDM6350 Car CD/ MP3...
Car stereo not working and dimmer lights went out
Where is the switch so i can dim down the blue light from my stereo? and, how do i turn on the stereo beep?
Oct 22, 2009 | Dual Electronics XDM6350 Car CD/ MP3...
Pioneer DEH-P6900UB CD Player Logo
342 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
