Question about Acer Aspire 5315 Notebook
Display has got binary codes like 0's and 1's all over the screen and display works fine on BIOS, Dont have External monitor to check with
  • 3,600 Answers
Re install your driver and download windows defender you have a virus. Did it to me a month ago.
Posted on Jun 26, 2009
I have a dell e5420 on booting it brings a white screen display but when connected to an external monitor it display properly what can i do cheers
Hi omovik,
Good observation on the external monitor piece. Check if the notebook display works fine when you enter BIOS (F2 during start-up) or during diagnostics (Fn+Power). If the issue persists on these steps then it's a faulty LCD. Do keep me updated on the status.
Thanks and Regards.
Kiran Kumar.
#iworkfordell.
Oct 21, 2013 | Dell Latitude E5420 Notebook
LCD Monitor isn't recognized
it is an issue with the LCD on your laptop as you get a fine display on external monitor
either get it repaired from a local technician
or get the LCD replaced
Jun 07, 2008 | Compaq Armada M700 Notebook
Screen will not load just white lines
Does external display work fine? If you have not checked, connect an external display like desktop monitor or a LED TV which has VGA connector to your laptop's vga port. You may have to use some fn keys combination to switch from laptop display to external. If external display works fine then check the display cable connecting laptop motherboard to laptop display. And also check laptop LCD/LED screen. You may have to try another with another screen in such scenario.
Sep 17, 2012 | Pavilion g7-1219wm Notebook PC
Screen displays low illumination.dvd drive not functioning.tv ok, av in ok.
Screen Display Issues:
Go to the BIOS. Once you power on the laptop immediately hold down the F2 key then BIOS will show up. Try to check in BIOS if the display has low illumination if yes then try connecting your laptop to an external monitor then toggle the display to the external monitor. If the display from the external monitor is fine then it means the LCD has issues and needs replacement. But before going into any LCD replacement try to update the BIOS version first.
DVD Issues:
Check first the DVD icon in My Computer window. If missing then kindly do this:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318
Delete the upper and lower filters.
Uninstall the DVD device driver from device manager.
Restart the computer.
Check BIOS if ODD or DVD is present. If yes then F12 boot to DVD if failed replace DVD drive.
If the DVD not present in BIOS replace DVD.
May 28, 2011 | Computers & Internet
The display on my ibm thinkpad r40 is black after initial dim ibm screen. External monitor works fine though. This happened immediately after I used my ibm with a projector this morning? Fn F7 does not...
The problem youve discribed does seem to point to your back light has failed on the laptops lcd display, i dont know exactly how this would accure just using a projector though, go into bios again and try loading factory settings.
This problem could also be the inverter if you cant make out even a slight image on the screen.
let me know what happens. thanks
Jan 19, 2010 | IBM ThinkPad R40 2681
Blue lines on dell lap top inspiron
Check whether blue lines are present in bios screen, if Present then Hardware issue
If Blue line not present in bios screen, Software issue = Restore system back to factory settings
Connect External Monitor, use Fn + F8 to extend display on external Monitor ,
if display is fine on Ext Monitor = Replace LCD Kit
if Blue lines are displayed, on Ext Monitor = Replace Motherboard
Jan 09, 2010 | Dell Computers & Internet
No display, only grey screen
>You can check the display on external monitor - if the external monitor comes up fine it could be an issue with Display panel of the notebook
> If the external monitor also not coming up- if could be an issue with the system board.
>You can also check the display on BIOS- if the display fine on BIOS- It could be some virus issue or some issue with the OS
Jul 01, 2009 | Apple (661-2795) for iMac Motherboard
Monitor does not display picture. If i turn off and turn back on it displays screen for only 2-3 seconds then goes black?
Plase update Display/graphics driver.
If you have a external monitor try plugging into notebook, if the external monitor works fine, you can replace the display.
>Check in safemode>If its stays for long time, it could be an issue with Virus.
>Check in BIOS as well
>If the external monitor is also acting in a same way, you may have replace the system board
Jun 30, 2009 | Computers & Internet
My Inspiron 6000 screen is blank. I can get an image on a monitor through the serial port, but when on its own, the notebook screen is black. I have noticed that there is a brief flash when booting up, but...
Hi ,
1. You can check the display on external monitor>If the display is blank on external monitor also, its pretty clear that there is an issue with system board
2. If the Exernal monitor comes up fine, it will be an issue with the display of the laptop, you can cross check the issue by booting the computer to BIOS, IF you get same response on BIOS as well. Its an issue with the Display itself you can replace the display panel.
Hopefully, its covered under warranty ;)
Jun 29, 2009 | Dell Inspiron 6000 Notebook
Screen goes blank (white), sometimes screen display will get big
You can update graphics driver, if that does not fix the issue check the display on external monitor. If the external monitor works fine you can isolate checking the display in BIOS Setup scree (Restart your computer and keep tapping F10 to getinto BIOS). If the same issue in BIOS, you may have to change display of the unit.
Jun 26, 2009 | HP Pavilion TX1320US Tablet PC
Acer Aspire 5315 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
