Question about IBM Office Equipment & Supplies
How to install a ribbon in an IBM selectric II typewriter
  • 46 Answers
Pull the orange lever located on the carrier to the side. Make sure the ribbon passes through the ribbon lift guide next to the platen. The ribbon should go behind the the thick part of the guide and through the fingers to the inside on the outside of the guide. There is a wire (usually with a white platice roller on it) sticking up from the carrier. Maker sure the ribbon goes aroung the outside of the wire. Snap the ribbon down on the carrier then close the orange lever back in place.
Posted on Jun 26, 2009
I have a IBM Model 5651 Memory Typewriter (Selectric II carriage), and I cannot make the ribbon advance while typing. If I turn the ribbon it will type until the ‘ink’ runs out. It’s just not advancing. ...
If this takes a selectric II ribbon the Spiked driver may be gummed up. Remove the ribbon,
find the latch that holds the ribbon mech. open, release it the ribbon drive should swing freely to the right, if not spray some WD40 on the pivot point, above and below the arm then work it back and forth it should free up.
DickyO
Oct 25, 2010 | IBM Office Equipment & Supplies
I need to know how to install a ribbon on an IBM Selectric III typewriter.
Go to lexmark.com and click your way to publications there you can get instructions and pictures of installation. Remember there are 2 different ribbons for Selectric III,s.
DickyO
Sep 19, 2009 | IBM Office Equipment & Supplies
I have an IBM Selectric II. It types but does
The tab tensioner on the R. side is probably broken, not a bad job but you have to know how.
DickyO
Sep 12, 2009 | IBM Office Equipment & Supplies
IBM Selectric II Ribbon Not Advancing
First check to be sure that the ribbon is on the left of the shock wire where it comes out of the cassette, if that is OK then check the ribbon driver it should move freely and swing to the ribbon take up spool. Some WD40 will free it up. Also be sire the ribbon is winding in the direction of the arrows.
DickyO
Jun 15, 2009 | IBM Office Equipment & Supplies
IBM Correcting Selectric II; correction ribbon frozen in front of typing ribbon.
Move the grey lever on the R. side of the carrier to the R. and remove correction tape, try the machine, if it seems to work OK install a new correction tape.
DickyO
May 28, 2009 | IBM Wheelwriter 30 Typewriter
Changing typewriter ribbon in the IBM Selectric
You haven't told what model of Selectric. If it is a selectric II or III, there is an orange lever on the carrier that you must pull to one side. The correction tape has a silver lever next to the take-up spool that you must pull outward.
Mar 11, 2009 | Office Equipment & Supplies
Don't know how to load and string the ribbon on an ibm selectric
Selectric III has two different ribbons the selectric II ribbon tha the ribbon guides are part of the macine and the "bicycle" ribbon that has the guides bilt into the ribbon. to replace the "bicycle" ribbon move pull the red lever on the right toward you, drop the ribbon in turn the knob a few times in the direction of the arrows, move the red lever back done.
The other style move the lever, drop the ribbon in, be sure the ribbon is left of the slacker finger sticking up on the left,thread it tru the guides, turn the knob inthe direction of the arrows, move red lever back,done.
DickyO
Feb 24, 2009 | IBM Wheelwriter 30 Typewriter
IBM Selectric III - ribbon won't turn
Make sure the ribbon cartridge lever is closed and that the ribbon is on the outside of the shock wire (where the ribbon exits the left side of the cartridge)
Jan 20, 2008 | Lexmark Wheelwriter 15 Series II...
1,040 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
