Question about Toshiba Satellite A105-S2001 Notebook
Toshiba A105 S2001 laptop does not recognize 1GB memory chip
In slot 1
  • David Shulman Jun 26, 2009
    The memory has been determined by Toshiba, and
    Crucial and Memory-up to be correct. The chip runs correctly in slot 2. The only way the laptop runs is with the original 512 chip in slot one. The bios is up to date.
    Sniper:
  • 68 Answers
Is 1 gb is you ram, if it is ram then your ram is not compatible with your laptop.
Posted on Jun 26, 2009
  •  Dave Burrows
    Dave Burrows Jun 03, 2013
    The Toshiba Satellite A105 S2001 does support 2 x 1GB memory modues, but Crutial no longer sells 1 GB sticks that the most recent BIOS recognizes.
Trying to upgrade memory in a toshiba satellite a105 s1013
Pls Check this link, in reference to your memory upgrade...it seems that your laptop could only accomodate max 1Gb of RAM
http://support.gateway.com/s/Mobile/Q106/Magic/5948sp2.shtml
Feb 14, 2010 | Gateway MX3215 Notebook
Dell M60 only recognizes 1GB of ram; used to see 2GB.
Is the memory the same size ?and belive it or not some machines don't reconize ram even thought it is installed ,if it is running good and your os reads the ram
don't worry about it if not let me know
Dec 24, 2009 | Dell Precision M60 Notebook
I have a Toshiba Satellite A105-S4004 and one of the memory slots seems to not be working/doesn't recognize a memory module. It's the correct module for it.
There could be several problems to cause this. I would like to start out by giving you some somple steps. If the Ram you are trying to install is larger than the first ram, then place the larger one in the first slot or slot A. Some computers are very finicky when it comes to this. 2. swap new memory module with existing module and see if it is recognized then. If not then your module is bad.
Oct 29, 2009 | Toshiba Satellite A105-S4004 Notebook
Adding memory, new total not recognized: IBM Thinkpad R51e-1844
Ram should always be paired. Same type, speed and size in each slot. You may have 1 SIMM/DIMM/DDR that has 2 sides of chips and the other with 1 which will do exactly what you state. RAM reads across the chips simultaneously. So if you have a different one in each slot it can go bonkers and do goofy stuff on you.
Jun 14, 2009 | IBM ThinkPad R51 Notebook
Can't upgrade memory past 1gb when max is 2gb
I have the same issue with my laptop. I have not been able to get the laptop to accept 2gb of memory yet, but I did find something that works. If you put your 512mb memory that works in the laptop and then add a 1gb stick in the second slot it works. Or at least it did for me. It's better than nothing. I am still trying to figure out how to get it up to the 2gb max. Will add a solution if I figure it out.
Feb 08, 2009 | Toshiba Satellite A105-S1712 Notebook
Memory Problem
Sounds like the memory chip is either the wrong frequency or it's bad. The frequency or type of memory for your machine is PC4200 or 533mhz, make sure the new chip is a PC4200 chip. If it is, then the chip may be bad. They are very static sensitive, and I've had a few bad chips straight out of the box. I've also ran into a couple of chips that were marked wrong and not the frequency on the label. This is definitely an issue with the memory chip and not your machine.
Jul 16, 2008 | Toshiba Satellite A105 Notebook
Toshiba Satellite A105-S2001 System
check to make sure the ram module is properly seated.
May 29, 2008 | Toshiba Satellite A105-S2001 Notebook
Toshiba a105-s101 memory install boot issue
Check your owners manual to see if the laptop will support 2GB of ram. If not you will need to use 2 512mb sticks to get to 1 GB
BPCS
Dec 27, 2007 | Toshiba Satellite A105 Notebook
Can I add another 512MB of memory to my A105 satellite toshiba
i dont know as much about laptops but you should be able to get the 512MB. to replace it look on the bottom on the laptop there should be somewhere down there that you can open up the to put it in.
Nov 22, 2007 | Toshiba Satellite A105 Notebook
Toshiba Satellite A105-S2001 Notebook Logo
310 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
