Question about Motorola T5920 (7 Channels) 2-Way Radio
I can't get either radio to transmit or receive
I charged the batteries and they turn on and seem to function through the menu fine but when I push the ptt the other radio doesn't receive the message. they both seem to have the same problem. They are both set on the same channel and subchannel and all menu options are the same on each radio.
My problem is on one T5920 Motorola radio I can receive messages and on the other I can talk. What's up. I have new batteries in both.
Posted on Feb 03, 2010
  • 24 Answers
Try this get someone with a radio or scanner and see if you can be heard on there radioor try this put the radio in simplex mod and turn off the tone
Posted on Jul 14, 2009
Motorola radio seems to go to sleep when not used for a while. Battery still fine.
It is called battery save. You push the push to talk about 3-5 seconds and all the radios will "wake up". On most models, it can be turned off, but battery life (time before you need to recharge) is shortened.
Oct 21, 2015 | Motorola Radio Communications
Can't transmit signal. Only get a 2 second beep when I push the transmit button
You have a poorly charged or bad battery. It takes more power to transmit than to receive. Usually the first thing you lose with a low, bad or poorly charged battery is transmit.
Try a known good battery in the radio. This should solve the problem. If not, check your battery contacts, as you may have one which is bad or not making good contact.
Clean your contacts with a pencil eraser to assure good connection with the charger.
Best regards.
Mar 18, 2014 | Kenwood Radio TK 260 360 270 370 2100 3100...
Changed the battery in my 2-Way Radio CLS1110 and it will turn on but when you push talk it goes off
This is the sign of a low or dead battery. It takes more energy to transmit than to receive. So pressing the PTT to transmit will generally shut the radio off when you have a low, bad or poorly charged battery.
Clean the battery contacts on the battery, radio and charger with a pencil eraser and try charging once again. Be certain your radio is turned off during charging. Sometimes it will take 2-3 attempts to charge battery which has gotten too low. Exposure to cold conditions in shipping can sometime cause this too.
If these solutions do not solve the problem, try charging the battery in another radio to see if the charge capability of this radio is compromised.
If none of these solutions solve your problem try getting the battery replaced under warranty at the point of purchase. It will have a 6 month or 1 year warranty.
If the battery was not new, replace it.
Best regards.
Jan 20, 2014 | Motorola CLS 1110 (1 Channel) 2-Way Radio
The battery is bad or not charged. Check your charger and charger/battery connection. Clean all contacts with a pencil eraser and try charging again. With a new battery it may take up to 3 charge cycles to fully charge your battery.
Best regards.
Receives fine transmission is very poor
Transmit issues can be related to a bad or poorly charged battery. It takes more energy to transmit than to receive. Try swapping batteries with a known good radio to see if it solves the problem. Clean your battery contacts with a pencil eraser and if needed replace the battery pack.
Best regards.
Nov 24, 2013 | Motorola Talkabout FRS 250 (14 Channels)...
I have a problem with radio gxt1050, it was functioning correctly, but now I turn on it and the keys not response, no PTT button, but I can hear calls from other radios... tanks
  • It takes a lot more power to transmit than it does to receive. So it is possible to listen but not be able to talk. Make sure that the batteries are charged and that the batteries are holding a charge. When batteries begin to fail they won't hold a charge for long at all.
Regard, Tony
May 06, 2011 | Midland Two Way Radio
Won't transmit
First I would check the interference code on both radios to see if it is set the same. It is possible you have one set to zero and the other set to another number. This would cause the problem you describe. The interference eliminator is designed to block out transmissions from radios whose settings do not match it.
If all your settings are identical, and you have only 2 radios, it is not possible to tell which one has the problem. You either have one with no transmit or one with no receive. The only way to tell which you have is to get a 3rd radio involved, set to the same settings.
Sep 06, 2008 | Motorola FV200AA GMRS/FRS 2-Way Radio...
Transmitting
Hello lstimpson,
You may have the CTCSS privacy code function enabled on one radio and not on the other. This function keeps your radio's received muted unless it receives a signal from another radio using the same privacy code. If you have Privacy Codes set for radio A but not for radio B you will still be able to transmit from A to B but when you transmit on radio B your signal will not be heard on radio A.
Make sure that both radios are set to the same privacy code or that the function is turned off on both radios.
Best Regards,
Ken
"Go Ahead. Use Us."
Jul 19, 2008 | Cobra MicroTalk PR 1100 WX (15 Channels)...
Keewood Protalk 2 way radio xls receives , but doesn't transmit
Hello jf1111,
It could be a low battery. Does the screen go completely blank when you attempt to transmit? Two way radios draw a lot more power when transmitting then when receiving so a low battery might cause the radio to cut out when you press the Push-to-Talk and then the radios might appear to turn back on when you release the PTT. If this behavior persists even after charging the battery then the battery or charger (or both) might be defective.
If the battery isn't the issue then the radio could be programmed incorrectly. Does the problem occur on all channels or just one? The Kenwood ProTalk requires dealer programming with a software kit to set the frequencies for each channel. A channel that is programmed for an out of bounds frequencies would generate an error when the PTT is pressed. You might need to have the programming checked out by your local Kenwood Two-Way radio shop.
Best Regards,
Ken
"Go Ahead. Use Us."
Jun 20, 2008 | Kenwood ProTalk XLS TK-3131 (15 Channels)...
FR60 intermittent transmission
Hello snorker,
It could be battery / power issue. Two-way radios draw much more power when transmitting then receiving. If the batteries are weak the radio might work perfectly fine on receive and then cut-out when you depress the Push-To-Talk.
Best Regards,
Ken
Go Ahead. Use Us.
Apr 30, 2008 | Motorola Talkabout FR60 (14 Channels)...
Motorola T5920 (7 Channels) 2-Way Radio Logo
249 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
