Question about GE S8000E
Our HOOEVER ca 230 makes loud vibrating noise when on fast spin
Our Hoover CA 230 1300 special edition is making a loud vibrating noise when spinning fast. The machine is balanced so I think it might be the drum. It still works but the noise is unbearable. any ideas what it could be?
SOURCE: Hoover CA230 1300 Special Edition Washing Machine
Should you have to use un due force to get the filter undone on the Hoover 1300 special deition washing machine
Posted on Feb 02, 2008
I had the same problem. My husband checked the carbon brushes attached to the motor and ran the machine on spin. The brushes were sparking so he assumed they were worn and replaced them and hey presto machine works fine now. The brushes cost 23.99 and were just bought from a local shop but can be bought online cheaper. Hope this helps solve your problem. Essex
Posted on Apr 08, 2009
  • 512 Answers
SOURCE: my new Ge washer is making loud and vibrating
Who installed this? Sounds like they didnt remove the shipping rod located on back of machine. If so, refer to instruction manual for how to remove rod. Usually just pulls out.
Posted on Jun 14, 2009
milten1
  • 1304 Answers
SOURCE: loud thumping noise when the drum starts to spin.
see if you shake or tilt or move the inner tub
if you can you may have a groken spinner support
dont know hold old the machine is, but if its out of warrenty, it could be come very expensive repair
Posted on Oct 06, 2009
  • 555 Answers
SOURCE: Machine making a very loud noise when it spins
Sounds like the bearings are broken and it may need a major repair. You may need to consider to buy a new washer machine.
Posted on Oct 10, 2009
LOUD NOISE AND KNOCKING ON FAST SPIN
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Feb 21, 2011 | Hotpoint Aquarius WF220 Front Load Washer
Into the spin dry cycle a loud hammering noise appears. Immediately goes away when powered off and drum speed drops. Can you please advise. Regards Geoff
Washer Problems Washer noise when spinning
heatman101
Oct 05, 2010 | Hoover H130E Front Load Washer
Very loud banging on fast spin
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
heatman101
Sep 17, 2010 | Whirlpool AWM8113 Front Load Washer
When the washer spins on it makes a loud noise. It seems to be off balance
Open the door and see if there is excessive movement on the stainless drum. Ca you move it forwards and backwards, up and down? If so then the most likely cause is the drum bearings. You need a tradsemas to chage these using special pullers.
Aug 30, 2010 | GE WSM2700W Unitized Spacemaker Washer and...
My washer wont spin
Most likely it's a motor coupling. (Between motor and transmission - brakes when you overload it.)
Kenmore washer repair in orange county, ca
appliance repair orange county, ca
Feb 07, 2010 | Washing Machines
Hotpoint VBSR2080WOWW washing machine vibrates with loud noise
hi,
this is a generic problem with top-loading washing machines. when the distribution of load is not uniform, it gives sound when spinning. if it produces noise even after equal distribution of clothes, the problem lies in the suspension. this is not a major fault, and can be put up with, rather than spending dollars on fixing it. this will in no way cause any special wear and tear for the machine.
cheers
Jul 22, 2009 | Hotpoint VBSR3100D Top Load Washer
Spining makes noise and machine vibrates a lot
its a simple solution just remove the brown colour clamp at the bottom of the machine with a screw driver
Jun 03, 2009 | Whirlpool Washing Machines
GE S8000E Logo
107 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
