Question about GE JGBP28 Gas Kitchen Range
My new gas stove makes a loud humming noise when the gas burner or oven is turned on. The noise goes away if I turn on all the burners. It works great but it's driving me crazy.
jsrock516
  • 5911 Answers
SOURCE: Stove burner igniter does not work.
Your problem is not the igniter itself, but the burner switch that controls the igniter. All the igniters get their power from one spark module that is mounted somewhere in back of the oven. That's why you are able to get all the igniters to spark with only one burner control turned on. This is normal. That is also why you are able to light the burner in question buy turning on another burner. The spark is being provided by a switch that is working. To answer your question: the igniter is removable, but I don't think it's necessary. Cleaning them generally doesn't make them work better. I would check the wiring from the spark module to the burner switch and/or replace the switch. I hope this helps.
Posted on Jul 18, 2007
docjohn174
  • 943 Answers
SOURCE: GX XL 44 Gas Stove Oven won't Work
HI. thanks for your question. the problem you are having is with the bare igniter, located in the oven on the gas burner. replace the igniter. thanks the appliance doc.
Posted on Oct 12, 2008
SOURCE: GE spectra xl44 - Oven not working, broiler & stove-top burners fine
replace the ignitor for the oven. it's the lower one and not the one on top.
Posted on Nov 15, 2008
SOURCE: gas oven dosnt work
the pilot light is there for 2 purposes. number 1 to light the burner and number 2 to heat up the thermocouple, thermocouple is a wire that the flame from pilot suppose to surround by fire. if the pilot is to low it will not reach the thermocouple. you can take the gas line that supplies gas to the pilot and clean it with a safety pin or a small needle. you can test the thermocouple by heating it up with a blow torch on low heat, get it red hot and then turned on the oven. if the oven works clean the pilot, if the oven do not work, replace the thermocouple if separate from safety valve. if thermocouple is part of it replace the safety valve.
Posted on Dec 14, 2008
  • 126 Answers
SOURCE: GE gas stove the burners on top work, the oven won't get hot
The most common reason a gas oven won't heat is a bad igniter. It is located near the valve and burner under the oven bottom. You can usually see it glow orange just before the fire lights. Most GE ranges take a cylindrical igniter part #WB2X9154 or #WB13K21 rectangular igniter.
Posted on Jan 02, 2009
Our gas oven has not worked in over a year. The electric panel was malfunctioning. The burners work fine. We just had some work done and had to turn off the radiators and manually fill the boiler an
The hum may be a b ad regulator in the stove. Pull stove out and see if regulator is humming. It's where the gas line connects to stove.
Maybe the power was interupted to the stove which may have reset power to control board.
Oct 22, 2014 | Kitchen Ranges
Thermador Professional Oven
hey man don;t worry i have too much solution if i explain u every thing then you confused so i explain one and if u want another then e-mail me on mango4529@rediffmail.com so listen carefully
Step 1: Turn off the power supply, both gas and electric, to the range. Then remove the burner.
Step 2: Soak the burner in a solution of mild household detergent and water. Clean it with a soft cloth.
Step 3: Clear the gas ports with a pin or needle, rinse the burner, and let it dry. Caution: Do not use a toothpick or matchstick to clean the gas ports. If the tip of the wood gets stuck in the burner ports, it could cause a serious blockage.
Step 4: When the burner is completely dry, replace it, and turn on the power and the gas supply.
An oven that won't heat can occur for a variety of reasons.
and if not then open this link http://home.howstuffworks.com/how-to-repair-an-oven.htm
Nov 23, 2007 | Thermador POD301 30" Pro Series Deluxe...
The gas in the oven goes on then off
follow this instruction. God bless you
    • 1
      Unplug your unit and turn off the gas supply at the saddle valve near the unit.
    • 2
      Lift up the hood of the oven. If you have sealed burners, the lid will not lift up. Locate the ignitors near the burners of the unit. Clean any gunk away from the ignitor using a toothbrush. Test the unit.
    • Sponsored Links
    • 3
      Pull the burner dials off the front of the unit if the ignitors won't work.
    • 4
      Remove the screws at the ends of the front cover, where the gas supply knobs are located, using a screwdriver, and remove the cover from the oven.
    • 5
      Slide the wires off the burner valve switches and pull them off the burner valve by sliding the switch forward. The switch will have wires attached to it. Loosen the screws holding down the wires of the burner valve. Pull out the wires carefully. Place the wires in a new switch. Slide the new switch onto the burner valve. Replace the knob, and turn on the gas supply and power. Ignite the burner.
    • 6
      Follow the switch wires into the oven if the new switch doesn't work. Locate the module box, which is usually 2 inches by 3 inches. Slide the wires out of the module terminal by pulling on the wire connectors. Remove the screws from the old module and pull the module out. Insert the wires into the new module, using the same wire orientation as before. Reassemble the oven. Turn on the electricity and gas, and turn on the burner.
Read more: http://www.ehow.com/how_7925141_repair-electronic-ignition-gas-stove.html#ixzz2ZPuc5nad
Jul 18, 2013 | Ovens
Everytime i use my frigidaire gas stove burner, it will make a loud humming noise. when i turn on a 2nd burner the humming sound will go away..is this normal for this brand?
SOUNDS LIKE YOU HAVE A REGULATOR PROBLEM. IT WONT HURT ANYTHING ITS JUST ANNOYING. OR YOU CAN REPLACE THE REGULATOR
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Mar 07, 2010 | Frigidaire FGF366E Gas Kitchen Range
DCS 5 burner 30" oven makes loud noises as if starved for fuel
Hi; Is the oven run with LP or NAT gas. Sounds like a regulator problem not letting enough gas through. Also is this a comercial unit. If so when was the last time all burners and pilot orafices were cleaned out. The burner tubes have a air vent cut into the burner at the orafice. Make sure no debris have covered these airways.And lastly how old are the thermocouples and are they secure to the gas valves and have a good pilot flame on them...
alpharome416
Feb 23, 2010 | Ovens
Humming noise from stove
Turn the convection oven switch to the off position.
Feb 15, 2010 | Viking Stove/Oven/Range Timer Knob -...
When I use my gas range it smells like lighter fluid. Only when it is on, when off the odor goes away. It is a dual stove with electric oven and gas top. It started with one burner and now all 5 of them...
I am having the same problem with our stove in our new house. We just moved in and everytime I turn a burner on it smells like charcoal lighter fluid. Anyone know what this is?
Nov 14, 2009 | Kenmore Kitchen Ranges
My maytag gas oven model #MGR5755QDW makes a loud poof noise when first turned on. It doesn't do it all the time and it only happens when it is first lights.
You are getting a delayed ignition fom the oven burner. Either the ports on the burner near the ignitor are clogged or you have a weak oven ignitor. part # 12400035 @ $70.00
Apr 08, 2009 | Maytag 30" Self-Cleaning Freestanding Gas...
Super Capacity 465 Gas Range
my gas stove top burner will not ingnite when I turn on the gas.
I have gas supply to the house, the gas stove top makes the tick tick noise when you
turn one of the burners on, but no flame, even if you try using a match.
What all can I checK?
Sep 20, 2008 | Kitchen Ranges
GE JGBP28 Gas Kitchen Range Logo
1,779 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
