Hi Friend, thank you for your post!
It appears your Frigidaire washer has power, but has no display. Let's try resetting your washer by either unplugging it or flipping the household circuit breaker to the off position. It is good to wait roughly ten minutes and then turn on your washer. Confirm that the door is securely closed and select a cycle. If resetting the power does not correct the issue, it could potentially mean a number of things: a potential wiring failure, faulty door latch assembly or control board. Because it could be a number of any one of several underlying causes, I would personally contact a professional to accurately diagnose your washer to determine the root cause to reduce the risk of unnecessary parts. Hope this helps! - Z
I appreciate your inquiry, friend!
I see that you would like a list of Frigidaire Affinity washer error codes. I was unable to locate a full list of codes. Are you currently experiencing an issue with your washer? What error code is being displayed? With more information I will be able to assist you further. -Matt
Hello rdketo - Typically error code E70 indicates that the water temperatures are wrong. Often this is caused due to the hoses are wrongly connected to the valves. Check the hoses and make sure they are located on the correct faucet and valve. Confirm that there aren't any restrictions or kinks in the drain hose as well. If issue persists, it will be advisable to contact an experienced appliance repair tech to assist further.
Hi - Could you please press and hold the start/pause and cancel button together at the same time for approximately 30 seconds? What error code does it display? With this information I can assist you further with the issue that the washer is having.
Hello Tony bent - What issue is the unit experiencing exactly? Can you tell me if it is displaying any specific error codes? If I know more information on what the issue is, I can try to better assist you further.
