Error codes SC545 for Ricoh Aficio 1045
Hi there...my ricoh problems is about the code of error SC 545 (Ricoh Aficio 1045...my i know what is the problem's about?
  • 313 Answers
Yes you may it refers to a temp error int eh fuser... you may have a faulty thermistor or thermo fuse.. if you go into teh service mode by presssing teh yellow clear butto and then press 107 and then hold down the stop button the sreen will change turn the machine off and turn on again see if the errpr goes if it does it could have been just a temp error if it warms up then comes back on again you will have to look at the fuser.. you can check the fuser by touching the casing and see if it is warm after you have turned the machine back on..if it is warm the error could just be due to a build up of toner on the thermistor.. if you know about machines you can take the fuser out by opening the front of the machine up look to top right where fuser is there is a screw under the blue dial on the fuser take that out the fuser slides out put it on some paper and on the right hand side is the thermistors held inby a small screw if you take them out you may see some build up of toner on the resistor carefully clean this off.. put back together and turn on .. hopefully it will run ok.. good luck A
Posted on Jun 26, 2009
RICOH AFICIO SP 4210N SERVICE MODE SC 545 Power Off On How Solve it this error?
SC545 fusing lamp remains on. reset fuser error in service mode. If it still reoccurs. Possible bad thermistor or power supply board. To go to service mode press up and down botton for about 5 sec and then press enter. In service mode engine fuser reset SP5810 execute
Sep 30, 2017 | Ricoh Office Equipment & Supplies
Ricoh 1045 error code sc 395
fix copier is a youtube channel
fixing error in videos
this is a video see you how to fix sc 395
https://www.youtube.com/watch?v=cI6o6mYOqow
Oct 07, 2012 | Ricoh Aficio 1045 Black and White Copier
Sc 545-00
SC545: Fusing overheat error 2
-Definition- [A]
The fusing lamp stays on at full power for 30 seconds while in the stand-by
condition after warming-up is completed.
- Possible causes -
· Fusing thermistor out of position
check/clean the thermistors
and ull need a service engineer to reset the code
Nov 25, 2010 | Ricoh Aficio 450 Copier
Error 545
The error code SC545 means the following:
Fuser lamp overheat error 2.
Fuser ready temperature abnormal.
Hot roller ready temperature abnormal.
Hope these answer your question.
Nov 25, 2010 | Ricoh Aficio MP 1600 Black and White...
Ricoh 3045 printer stopped printing error code SC545
Hello, you´re found problem in the fusion unit. Clean the thermistor, and try again. Before try it, most reset the Sc code with service code....Good Luck!
Feb 08, 2010 | Ricoh Office Equipment & Supplies
Ricoh 1045 showing code SC545. First was SC 546 and now SC 545 can somebody help?
SC545 and SC 546 are fuser temperatyre error. pls. check thetmistor/ thermostats, connectors if thernistor are deffective replace thermistors. after replacement or checking of this parts do the SC reset. 107 # turn off copier then on after 5 sec.
Jan 26, 2010 | Ricoh Aficio 1035 Copier
Ricoh 1045 error code sc 672, 961
Controller to operation panel comucation error at start up.Check the controller stall,controller board installed correctly operation panel connectors.Enter im the service menu ,press the SP mode,open the front door,turn off the copier,unplugged the machine.Wait 10 seconds,plugged on the machine,close the front door,turn ON the copier and make a copy.
Dec 28, 2009 | Ricoh Aficio 1035 Copier
This is the code on the mach sc 545
Hello sir; The code sc545 means fuser unit temperature too low it can be reset;
press "clearmode" "107" and thenpress and hold "clear/stop" key untill display "copy sp" show up, then turn power off and back on.
Apr 09, 2009 | Ricoh Aficio 2022 Black and White Copier
Ricoh 3006
go to service program 5-810 ( sc reset) press on, turn off the machine an the turn on again. The service code should be gone, if it come back again check for a paper jammeed or wrapping the upper
fusing roller if this is not the case replace the thermistor;
Good luck
Vittorio
Dec 21, 2007 | Ricoh Aficio Colour 3006 Color Copier
2,599 people viewed this question
k24674
jasbo
jasbo
