Question about Maytag PYE2300AY Electric Dryer
Maytag Performance Drum wont rotate
Hi, We have a 2003 Maytag Performance drier that heats up but the drum wont rotate. It is so sealed I am unsure how to even get to the drum, Any ideas? Thanks
  • 351 Answers
If i remember right there is 2 phillips screws on the bottom....that should get the front off
Posted on Jun 26, 2009
Replace belt on maytag dryer lde8824ace
If it is a model where the belt goes around the drum rather than a separate pulley the drier must be dismantled far enough to allow the belt to be freed from the drum.
Belts need to be replaced so infrequently manufacturers make little provision for in-service replacement and generally the drier must be taken back to the stage in production where the belt was originally fitted.
This can be a rather extensive process with many models and in the absence of dedicated model information we often must resort to simply keep removing screws until the thing falls apart. By the time a belt needs replacing the drum bearings and/or seals are often generally in need of attention in addition that the extra work, though inconvenient and dispiriting, is rarely wasted.
Feb 08, 2015 | Maytag Dryer Drive Belt - Y312959
How to get to motor on hoover vhc691b?
Very rare a motor fails on a hoover drier normally its the capacitor that fails. you can hear the motor humming but the drum wont rotate to proof its the capacitor turn the machine on press start listen for the motor humming open the the door of drier turn the drum by hand fast then shut the door as fast has possible then the drum should start going around . then this proves its the capacitor fault you are doing the job of the capacitor giving the motor a start .
May 16, 2014 | Hoover HDC6 Electric Dryer
Maytag dryer drum not rotating
Sounds like the belt that turns the drum has slipped off or broken. Not sure if I would consider this a DIY project, but if this is the problem, a professional fix should not cost much.
Jun 19, 2012 | Maytag Dryers
Drier does not tumble but it still heats.
Sound like the belt being broken or slipping badly, burn out motor, or worn support parts.
  • Dryer have a belt that rotate the drum, If the belt worn out or broken, it can not move the drum then you just need to replace it.
  • You can check motor by hearing buzzing sound, if the belt has the problem. If you do not hear any sound from the motor then you may have to replace it.
  • Try to move drum manually (by hand), if it is hard to turn then problem with the idler pulley, glides, or drum rollers.
I hope this will solve you problem
Good luck and have a nice day
Rating the solution is highly appreciated.
Jul 05, 2010 | Asko T701 Electric Dryer
My maytag model no.mav4755aww makes a whinning sound at the beginning of the spin cycle
Hi
Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.Since you hear whining it means that the bearing is damaged and the seals on bearing are gone too so it rotates without lubricant. It might be possible to hear whining while you rotate empty drum manually...
Turn the drum by hand and listen for loud noises. If the drum itself is split or the 'spider' is corroded, broken or has come apart from the back of the drum it will create a loud noise on every turn of the drum. When the bearings have gone bad, the noise is constant the entire time the drum is spinning.
Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing.Then replacing the bearing is suggested.
Let us know if you want something more else accept the solution.
Thanks for contacting fixya.com
May 22, 2010 | Washing Machines
Our drier is making a clunking noise, and the barrel has developed a small crack at the front.
your door seal, front drum bushing needs to be replaced it is a felt type soft unit that is installed directly at the front of the drum just behind the front cover
Apr 28, 2010 | Maytag Neptune MDE6700A Electric Dryer
I have a hotpoint TDL11P tumble drier on which the front drum seal havd worn through, i replaced this but the replacementhas worn through after just 2 weeks use. there was no obvious reason for the...
You may need to take the dryer apart again...check the drum rollers, if they are worn they will put excessive pressure on the drum as it rotates against the seal causing this problem.
Good luck
I hope this helps
Oct 05, 2009 | Hotpoint Dryers
Our Maytag gas dryer drum doesn't turn. Replaced belt. Heats up but drum isn't turning
There are three possible reasons why the drum doesn't turn.
  1. Broken belt. You replaced the so in this case it's not.
  2. Door switch. The dryer will not operate if teh door switch is defective. It is inside the drier main housing near the door frame. You need to raise or open the top or front of the dryer to reach the switch. Replace if defective.
  3. Motor. If the motor hums when the start button is pressed, the motor maybe burned-out. Check the dryer motor:
  • Check the blower fan housing for obstruction and manually turn the motor shaft.
  • If the motor is very stiff or cannot be turned manually, you need to replace the motor.
  • If the motor rotate freely, run the motor without the belt. If it runs fine, there maybe problem with the idler pulley or the clothes drum.
  • Rotate the drum by hand. If it is difficult to rotate it, correct any problem with the rollers or pulley. Reassemble the dryer and try it again.
  • If the motor hums but does not run on it's own even without the belt,but can be turned freely by hand, you need to replace the motor start capacitor or the motor itself.
Sep 25, 2009 | Maytag Dryers
Tumble Dryer Belt Keeps Snapping
Perhaps the zipper caused sleeve damage where the drum interfaces with the sleeve. Check for free rotation issues and periodic noises when rotating the unit by hand. Here are a couple of other possibilities: When old belt was replaced the belt was misaligned (not perpendicular) to the drum. When removing ore installing the drum there was a loss of sleeved material that the drum rides on. When replacing the drum into the sleeve and closing the drier up sleeve is not flush, something did not fit together quite right. Remember very small alignment problems will be magnified 3 fold on the clearances of the sleeve to drum. And lastly the motor bearings could be starting to slide in the bearing raceway which can intermittently stop the motor briefly, doing this will also snap the belt. Check to make sure that the motor turns freely when the belt is not on. Spin it in both directions to ensure that there are not any problems. Once you get it all back together check rotation of the drum by hand, there will be some tension but it should move, if not retrace your steps.
TIP OF THE DAY--
To reduce the suction draft and drying time your drier and save some cash, remove the lint catcher and take it to the sink. Run water into it, if there is excessive pooling of the water (water not runnig straight through then fabric softener is fouling the lint screen. Use a small brush and dish detergent to clean it and then shake off all the water and dry the screen. This wont really fix the main condition, but it will not hurt. Remember this tip on future driers and you will make the dryer blower motor last much longer.
Best of luck.
:?) DRRXR
Feb 08, 2009 | LG DLE2512W Electric Dryer
Rattling
Level the drier, check the drum for foreing objects, check your belt and replace if need to. Check your rear drum seal, and your drier idler pulley, and replace if need to.
Jul 05, 2008 | Kenmore 98702 Stacked Washer/Dryer
Maytag PYE2300AY Electric Dryer Logo
159 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
