Question about Frigidaire FRS23KR4AW Side by Side Refrigerator
Frigidare refrig not working
My frigidare FRS23Kr4aw seems to have stopped working. The compressor sounds like its coming on but the fans inside and in the back are not running. Any ideas?
  • 250 Answers
The fans are intermittent and are controlled through a thermal switch which is not calling for them to run. The thermal switch is attached to cooling fin on the cool end of the heat exchanger behind the outside top panel. The fin it is attached to is not making good contact with the tube and thus does not have good heat transfer to the switch. I am doubtful it will ever call for the fans to run unless that thing gets a lot hotter than it is. I am considering by-passing the switch and forcing the fans to run to see if it makes a difference. As far as the outside fans are concerned, heat rises so doing what you can to help it flow is good. Just make sure the air is going up over the outside coils. On our rig the fans are on top and pulling air through them. You can check the thermister, by unplugging a small white (on ours) connector from the card on the lower rear of the fridge. An unplugged thermister defaults the fridge to run on high. If the fridge runs colder with the thermister unplugged, then it may be a bad thermister. Most probably it might be the problem of the thermister.Or the sensor would have been knocked out during cleaning.
There's a plastic drip tray under the fridge fins. The thermometer sensor wire runs BEHIND the tray (right side).Try moving the tray a lil bit.
-ray
Posted on Jun 26, 2009
Have a frigidare wall ac (FAA067P7A). Worked 1st year we had it but problems after. Only time compressor kicks in is when we hit reset button. Then cold air comes out for couple minutes then compressor...
The compressor is stopping on overload. There is either a weak breaker or an electrical problem causing the overload to open the circuit and stop the compressor. It has to be taken apart to determine what is or is not going on.
Aug 03, 2011 | Frigidaire Compact Air Conditioner
Frigidare refrig. It seems like Freezer still working but not refrig. Temp is now 56 in refrig part. Refrig is not even 2 years old. Fan seemed to be working in refrig earlier but now not at all.
check the damper vent door between the two compartments to make sure its open to let the cold air in from the freezer then make sure the evaporator fan is operating to help push air thru this door,sometimes these doors freeze shut or if its a motor driven vent door the motor could be bad too
Jan 01, 2011 | Refrigerators
My fridge doesn't get cold or freeze.
there is no reset but can you tell if the compressor is coming on.if the compressor is not coming on the you may need to replace the start ptc and overload relay.if this does not work the you rneed to replce the compressor
Apr 10, 2010 | Refrigerators
Frigidare frs22zrg smoke inside refrigerator
There is a fan in this refrigerator between the freezer and the fridge and it is possible this fan has stopped or something has stopped it from running.You will need to get it repaired.
CHeck and see how hot the space between you fridge and feezes is and if it's real hot that's your problem.
It's either dirty or maybe a rodent got into this motor and stopped it from running.
Oct 23, 2009 | Refrigerators
Frigidare FMCB115Gc Has power won't start up
Could be a blown fuse in the HV transformer primary circuit,bad connections to the magnetron filament,open thermal protector or thermal fuse,
Sep 03, 2009 | Frigidaire Mid-Size Microwave
My refrigerator just recently started making a loud sound almost like a fan was breaking. Is my refrigerator breaking or can I fix this?
If this sound is when the compressor is cutting on or off it's the internal parts of the compressor. It can work like this till it brakes. There is no way to fix it without replacing the compressor. If you can put up with the noise just wait. Or it could be the fan behind the back cover inside the freezer hitting somthing like ice build up. Try to pinpoint the area the noise comes from.
Sep 01, 2009 | Roper RS25AEXLQ Side by Side Refrigerator
I have a frigidare model FRS23Kr4awo that seems to have stopped working. I can hear the compressor come on in the back but the fan inside never comes on. I have tried turning the automatic thermostat and...
Yes 2 common problems. 1) The evaporator is frozen due to a defrost problem, jamming the fan: Is there frost on the food side of the back panel in the freezer? Yes;defrost problem. No= 2) the evaporator fan is defective. Remove the panel and test for power at the fan WITH THE DOOR SWITCH in the CLOSED position. Power with no operation would indicate a bad motor.
Jan 08, 2018 | Frigidaire FRS23KR4AW Side by Side...
Freezer not working
compressor is faulty. clicking noise you hear is the overload for the compressor. not worth repair and not diy
Mar 18, 2007 | Frigidaire 5 cu. ft. / 142 liter Chest...
Frigidaire FRS23KR4AW Side by Side Refrigerator Logo
32 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
