Question about Maytag PYE2300AY Electric Dryer
Was running fine then went to check on the clothes and it was stopped. The clothes were still warm. Check the breaker and nothing. Will not start.
    Problem Solver:
  • 16 Answers
The motor sounds bad
Posted on Jun 27, 2009
Was drying cloths yesterday and restarted it due to the cloths not being dry set it on the hottest setting, went outside and came back in and dryer was stopped...checked the breaker switch, thought it may...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 22, 2011 | Magic Chef Dryers
I have reddy htr 35 was running great,just stopped reset breaker lit right up then went out Pulled cover off fan and spark fine reset it lights right up can see the fuel atomizing flame starts...
Check your fuel lines and most models have a fuel filter in line. A few things come to mind one how old is the fuel? Check the screen in the nozzle assembly by removing nozzle it sits directly behind the nozzle, these corrode and affect fuel flow. While you have this tore down clean the fire-eye with windex and terry cloth rag, it may not be seeing the flame. Check the air filter at the back of the heater as well. These are common problems with these heaters.
Dec 13, 2010 | Reddy Heater-30-55,000 BTU Variable
Dryer will not run or heat
Could be the thermostat or element....Element should read around 32 ohms on multimeter..stat closed circuit.....Try to look for any overheat cut off at the back anywhere...
Apr 12, 2010 | Maytag PYE2300AY Electric Dryer
Dryer won't turn on...
Try pushing the breaker pair off, then on and re-check the dryer. If still nothing, pull the power plug and check the two slanted slots for ~220 volts AC. If you don't have access to a voltmeter, or a friend with one, call an electrician to check. If you read the voltage stated, then the problem is within the dryer. Check the back of the machine for a reset button.
Sep 14, 2009 | Dryers
Dryer does absolutely nothing
Have this guy check the wiring from the receptacle to the terminal block in the back of the dryer. The next area would be under the top of the dryer where the thermal overload switch. Have someone bypass it and see if that is it. Chances are the problem is here.
Jan 28, 2009 | GE DBSR453EBWW Electric Dryer
Magic chef dryer
hi there,
she may have tripped the house breaker. unplug the machine and check the breaker on the house electrical box. plug the dryer back in and see if that will work.
Sep 30, 2008 | Dryers
Kenmore dryer stopped working, start button does nothing
hi thanks for the question i would check the thermal fuse at the back remove back panel . by the air duct theres a small thermal fuse with 2 smaller blue wires to it check that it does cause this thanks appliance doc
Sep 13, 2008 | Maytag PYE2300AY Electric Dryer
Dishwasher stopped working..!!..!! please help
Hi crystal245,
I'm Harvey the Master Plumber.
Your problem is: GE Nautilus Dishwasher suddenly stopped working. NOTHING!! it was fine one day then went kaput the next. I checked the plug in and the circuit breaker but still NOTHING
I run into this often. Ends up being loose, broken or burnt ellectrical connection in d/w junction box most of the time. It's under the d/w behind the kick plate on the right or center. Turn the power off first and remove the wire nuts. Replace wire nuts and/or repair wire ends as nessessary. Beyond that you're looking at a bad control board or failed connection in the unit.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 09, 2008 | Dishwashers
Dryer quit working
I have a Magic Chef Clothes dryer. Model #YE224LV. Was drying clothes, went back to ckeck and dryer wasn't running. Push botton and nothing. Check circuit breaker everything ok. What do I need to check and how. Just won't start.
Thank you!!!
Nov 11, 2007 | Magic Chef CYE4000AWW Electric Dryer
Maytag PYE2300AY Electric Dryer Logo
107 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
