SOURCE: 45 degree cut
Are you having problems with the miter or bevel ? Are you asking how to physically move the saw to that degree angle?
SOURCE: makita chopsaw when cutting angles blade is
Try going to Makitatools.com and typing in your model number on the right side of the page at the top. It will take you to another page where you can download an owners manual, I saw where page 6 and 7 would be helpful. Let me know if you need more help
SOURCE: Have a makita quick cut saw but site requirements
go to Makitatools.com and type in your model number which is DPC7311 and you can download the owners manual for this tool. If I have helped with your request would you please rate this response accordingly. Thank you
SOURCE: how to remove armature in makita 5806B
Removed the three screws to release the motor housing from the blade housing. If the the armature stays in the motor case then try tapping the edge of the open end of the housing with a soft mallet. If it still won't move hole the end of the armature in a vice using SOFT JAWS and then tap the edge of the housing to remove the motor case.
It might be that the rear bearing has siezed in the housing.
