Question about Xerox WorkCentre C2424DN All-In-One Laser Printer
System error 39,012.40:49875
The above system error message pops and requests that the printer be rebooted. This was an ocassional problem but now it is consistent. It indicates that it is a problem with the scanner or document feeder. What is odd is that if you let the unit sit for 5 to 6 hours without doing anything it will turn itself back on and run for a few hours.
Can this be repaired without buying an expensive scanner unit or document feeder or both?
    Director Badge:
    Uploaded 100 video answers.
  • 160 Answers
If after cycling the power to the machine and this problem still exists you may need to replace the ADF assembly. Here's a video that shows you how
Posted on Feb 14, 2011
    Problem Solver:
  • 6 Answers
Xerox Protechy says; depends how good you are with tools, the infamous 39,012 error is caused by the shutter on the adf unit sticking to the frame of the scanner assy, Xerox used a glue that breaks down due to the heat of the lamps and sticks the scanner shutter. I've repaired over a dozen of these and its always the same fault. No procedure in the book for this and it generally takes 2 hours to strip, clean of the adhesive and rebuild.
Posted on Oct 29, 2009
    Novelist:
  • 125 Answers
Hi gfaust560:
Here is you problem.
39,012.41 Document Feeder Optical Test Failure Troubleshooting Procedure
Step Questions and Actions Yes No
1 1.
Cycle power to the system to clear.
2. Did this correct the problem? Yes Complete.
No? Replace the document feeder.
Hope this helps
Posted on Jun 26, 2009
Canon PIXMA iP4600 error message string-USB002
issue with registry uninstall the driver remove the entries from registry . reboot the system try again
skype id :johnwalker800969
Sep 09, 2016 | Canon PIXMA iP4600 Color InkJet Photo...
Tip
How to fix No Bootable Media Error Message
FAT (File Allocation Table) is one of the most widely used file systems used now-a-days with various versions of Windows operating systems and memory cards. Every logical partition contains a FAT that consists of file allocation information and the information of free allocation units that need to be assigned to files. Although the FAT file system is reliable, corruption still occurs due to various reasons. In such situations of FAT corruption, your system becomes unbootable, resulting into inaccessibility of data saved in FAT based hard drive. To access the data after FAT file system damage, an easy way is to restore the data from an updated backup. But, with inaccessibility of data backup or backup falling short to restore the required data, an ideal option left is to use an advanced FAT Data Recoveryapplication that can recover the lost data.
To illustrate the above scenario, consider a practical case the below error message pops up when you attempt to boot your system:
“No Bootable Media”
As the above error message appears at the time of booting the system, you wont be able to access the data saved in the hard drive.
Cause:
The above error message because the FAT file system has been corrupted. Few main causes for file system damage are improper system shutdown, human errors, and virus attack.
Resolution:
To isolate the above error message and to access the data after the above error message appears, you will need to follow the below steps:
Run CHKDSK utility to repair the FAT file system. If the problem persists, format the hard drive.
While the latter resolution resolves the above error message completely, it also deletes the data saved on your hard drive. In such cases, if the backup is not available, then you can only recover your formatted data by using an advanced third-party FAT Data Recovery software.
A FAT Partition Recovery utility thoroughly scans a FAT based hard drive and recovers almost all data, even after formatting. The data recovery utility can be downloaded from the Internet.
Stellar Phoenix Windows Data Recovery is an efficient FAT Partition Recovery tool that recover lost, deleted, and formatted data from both FAT (FAT12, FAT16, FAT32, VFAT) and NTFS (NTFS, and NTFS5 ) based hard drives. The detailed help manual attached with the tool allows even a new user to perform recovery easily without any technical knowledge. It supports Windows 7, Vista, XP, 2003, and 2000.
on Jun 30, 2010 | Computers & Internet
Tip
Xerox system error
If you are using a Xerox printer, you might have faced a system error problem, similar to "System error 09.038.46:113334" or something within that line.
I faced a similar error message like this a few months ago and i solved it using the following steps.
The ink count sensor flags were stuck.
Verify that the ink is correct and genuine and then reset the system and error message by performing the following steps:
1- Turn on the printer
2- Wait for the xerox logo to begin moving across the display
3- Before the logo is centered on the display (stops moving) press and hold the "back" and "help" buttons on the control panel.
4- Hold both buttons until the display reads "beginning service mode initialization".Release the buttons and the printer reboots into service mode with the "Service Diagnostics" menu displayed
5- Then scroll until you find function menu then click "OK"
6- Scroll until you find "Clear ISC" fault and press "OK"
7- Click back several times and then reboot the machine.
If you follow these exact steps your problem should be solved.
Thank you for using Fixya,
Kenneth.
on Apr 07, 2010 | Office Equipment & Supplies
Error- im32fax.dil not found. Pops up on every start up
This occur most probably you install and uninstall a printer/fax software ie not remove correctly or the software uninstaller is useless!
Need to know whether you have done the above?
Jul 19, 2010 | Microsoft Windows XP Home Edition
Fatalerror message keeps popping up that printer hasnt loaded aaa
Completely uninstall the software then reboot and reinstall. This message is usually the result of a failed or incomplete install, and while it won't affect the drivers, it WILL affect the additional software bundled with the printer. Remember to reboot.
Mar 07, 2010 | Computers & Internet
C:\PROGRA~1\MYWEBS~1\bar\1.bin\MP3PLUGIN.DLL
Click on start, then run. In the box type msconfig. Click on the startup tab. Uncheck the box that has the above entry in it. Click okay, then reboot. When the box pops up on reboot about the system configuration utility, check the box then click ok. It shouldn't come up any more.
Sep 29, 2009 | Intel Motherboard
Print head error message
hi
if yr printer is under woranty u need to do company services system coz i think that u do what as u abov say that u do a initial stape or if yr printer not on woranty and if u know a normal clining system do cline pritner otherwise u need to replace head...
if yr printer show red light blink do press 5sec. then print it..may be it's help u if u have any quary tell me feel free...
thanks
jo_chinmay
May 04, 2009 | Canon PIXMA MP760 All-In-One InkJet...
HP Designjet 800 with a 'system error 81:01'
i have hp dnj Plotter 500 Printer Is Redy But Self Test & Computer Print Than Error 81:01 Papar Jam
Feb 23, 2009 | HP Office Equipment & Supplies
My system problem
Could be a variant of XP 2008 nasty
1) Try downloading "Malwarebytes" install and update it then run it
See if it cleans it up
2) go to windows explorer right click C:\ go to properties / tools / error check.and D/click it when new box pops up tick little box to repair errors and reboot.
on reboot windows will check system files and fix any errors then restart
Doing either of the above may fix your problem
Dec 05, 2008 | Computers & Internet
Initialization Error
hi friend,
there are few steps to stop the message in the start up. i tell you the step by step.
  1. Goto Run type msconfig
  2. Goto startup tab and see all the files that are in the startup files and unselect the Hkdrv files in the startup
  3. it will ask you to reboot the system.
  4. After reboot the system and in the begin of the system it ask you to the accept the changes in the start up and choose the dont show this message again in the start up and click ok.
  5. After this it ask you the same thing .please inform to fixya.com
bye thanks,
Jun 14, 2008 | Computers & Internet
Xerox WorkCentre C2424DN All-In-One Laser Printer Logo
213 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
