Question about Sony Playstation 3 (PS3) Console
Same promlem same promblem
  • 19 Answers
There's too man different variables and things that could be causing your problem to diagnose it and simply say "You need to replace x part of the machine"
You would need to disassemble the machine and physically test multiple things to find the problem and THEN replace the part.
Nobody online can do this diagnosis for you.
Use the troubleshoot menu.
Hold the Power on button while it is in standby.
You will hear 1 beep.
After 5-10 second you will hear a second beep.
1-3 seconds after this you will hear 2 more beeps.
You will then be asked to connect your controller via usb and press the ps button.
This will give you the troubleshoot menu. One or more options in these screens may solve your problem.
I suggest sending it to sony support and have them repair/replace it for you, however this will cost £80 if you are no longer within their 1 year warranty.
Any hardware sold by stores in the UK is covered by a 3 year warranty as part of your statutory rights. If you take it back to the store they will try to say it's not their problem anymore.
Point out your statutory right, and threaten to go to trading standards. This is usually enough to get a replacement there and then.
Troubleshoot menu guide:
http://www.youtube.com/watch?v=sWOrYLX01eA
If all else fails, here's a useful disassembly guide:
http://www.llamma.com/PS3/repair/PS3_disassembly_tutorial.htm
Posted on Jun 26, 2009
Auto off viao leptop
Please do following steps
1)Keep your Laptop In cold region
2)goto Mycomputers>>Right click on mycomputers>>select Properties>>Advanced>>Settings of Startupand recovery tab>>unselected Automatically Restart Option >>apply
Above steps will stop auto restart
If you like solution please Visit VikasTricksonline
Jun 20, 2012 | Computers & Internet
My promblem i want be gangster
Ur promblem - u need 2 lrn to spell!
Dec 13, 2011 | Video Game Consoles & Games
04 KIA SORENTA ac coolant fan stays on even if when car is shut off....
There has been known promblem with the 03- early 05 sorento of radiator fan staying on even after engine is turn off, it is claim to be a electrical malfuction in the engine termalstat. However you may just need to check your coolant level and fill it up as there is also a promblem to the sorento's having a leaking radiator coolant resevior too. Pretty much I own a 03 sorento, and it has been nothing but promblem, but glad I got rid of it. However like I said, check your coolant level, and fill it up with 50/50 coolant to recommended level. Should be able to solve the promblem, since it seems your engine is lacking coolant and is overheating, and the fan turn on automatic even after you have shut of your car to help cool it down.
Feb 02, 2011 | 2004 Kia Sorento
Externalseagate 250go not open how to solve
If you cannot open or see the harddrive when you connect it to your computer after it is powered on then that is the external harddrive itself. First, check if the power connection is connected and the usb cord connect correctly. Then see if any lights come on on the external hard drive. If lights does come on and still nothing showing or coming on to the computer, then your harddrive is history. Seagate makes one of the worstest hardrive. You can google this up about seagate promblem and there are thousand out there who have this same promblem. I know this because I have the same promblem you have.
Jan 17, 2011 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
My motherboard GA-8GGEM800 no display and cpu fan continus restarted .I have try with new cpu & ram. promblem not solve
my motherboard 945gs no display and cpu fan continus restarted .I have try with new cpu & ram. promblem not solve
Oct 28, 2010 | Intel Motherboard
Im haveing promblems getting parts for my bike
No surprize here ... it is nearly 30 years old. Check with your local Suzuki shop as to sources you may have locally.
Mar 09, 2010 | 1983 Suzuki GSX 750 ES
I HAVE A 1973 YAMAHA TX750 AND HAVE PROMBLEMS WITH STARTING THE BIKE I WAS TOLD THAT THIS IS PROBLEM WITH THIS MODEL I DO NOT BELIEVE THIS I HAVE REPLACED THE BATTERY AND SEEM TO HELP. BUT IT STILL TURN...
Hello. I have a 74 TX 750 and I too have had problems with it.
I bought a new battery for mine. It was sold dry and I had to add the acid, top it off with distilled water and give it a good charge.
One problem that you will have is that the push button control will oxidize and lose a suitable contact and also the casing for which it is housed will also oxidize. What you have to do is take that right hand control casing apart all the while being careful and remembering how the cable goes and then clean up those metal surfaces. I did this and it started like new afterwords.
Also, make sure that the battery ground wire is clean and connected well to the frame. Mine was corroded and had to be cleaned up.
Also, the cable connection on the starter may also be loose. Take that little cover on the top of the starter off, then remove the starter wire, inspect, clean it then put it all back.
There are few sites that house great info on these bikes, you just have to dig.
Hope it helps
Chad
Feb 12, 2010 | 1973 Yamaha TX 750
What is happening is i am trying to go online and it is a brand new game and the xbox is asking me to clean the disc every time. I have tried another game and it works fine can you help me my moden is on...
Take the DVD disk to Hastings. Tell them to clean it, it will cost you about 3.00. Bring it back. If it does not work, you have a defective disk, take it back and exchange it.
Hope this helps
Frank
Nov 15, 2009 | Microsoft Xbox 360 Elite Console
Sony Playstation 3 (PS3) Console Logo
42 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
