Question about Dell Dimension 8200 PC Desktop
I cannot get tower to shut off or start up. I have unpluged everything opened up tower and checked and cleaned and sprayed unit. Put it all back together reconnect it back and still no start up just the orange light.
    Sergeant:
    Champion:
  • 233 Answers
The hard drive might be damaged. You should check with the shop.
Posted on Jun 26, 2009
    Scholar:
  • 103 Answers
More likely the problem is the power supply. What type of computer is it?
Freezer is working,but fridge is warm. Fan in back of fridge will not shut off.
If your fridge is not designed with an automatic de-icing function, then there may be an ice dam blocking the cold air from moving from the freezer to the fridge. I had a fridge once that would get blocked with ice even if the rest of the freezer was ice-free.
Unplug your unit (often shutting off the breaker is easier than digging behind the fridge for the plug).
Pull everything out of the freezer and put it in a box. Cover the box completely with blankets to insulate it so your food doesn't thaw and spoil. Prop open the freezer door and let any ice accumulation melt.
Once everything has thawed out, wipe up the water and plug the unit back in. You should be able to tell after 10 minutes or so whether the fridge is getting cooler or not.
Mar 04, 2015 | Refrigerators
I shut down my computer now I can not get it to turn on when I push the power button
Unplug the computer and hold down the power button for 15 seconds, and then plug it back in and see if it will re-start.
Jun 12, 2011 | Dell Inspiron 530 Desktop Computer
E MACHINE T5026 KEEPS LOOSING POWER DUE TO OVERHEATING. ANY SUGGESTIONS
I'm not sure if your unit is a laptop or tower but if it's a tower, check to see if the cooling fan in the power supply itself is running. If not, fix it. If it is, UNPLUG the unit and open up the power supply itself. This fan will find every speck of dust in your house and deposit it in every nook and cranny of any tower power supply. I cannot stress enough to unplug the unit and DO NOT use any metal tools, picks or probes and KEEP YOUR FINGERS OUT of the unit. These are usually what's called a switching supply and develope several hundred volts early in the circuit and, like the television, they have high voltage capacitors that can retain a charge even when unplugged!!! If this is the case, if you have a mini vacuum, use it to clean it out. You can also "CAREFULLY" use the hose and flat tipped upholstery attachment of a regular vacuum cleaner being careful not to move or bump any parts out of position as their positions are in some cases critical to keep the supply from radiating RF noise back into your computer or out to other appliances around the house. If worse comes to worse use a small wood or plastic handled artist's paint brush, close your eyes and blow it out. While you are rooting around in there, you may want to look for any electrolytic capacitors that have bulging tops, discolored resistors, transistors, diodes or other semiconductors and their associated heat sinks if any or the area under these parts on the circuit board itself. Any of these parts can cause the problem you describe.
I suggest this ONLY if you feel comfortable around high voltages. If not, DO NOT try this!!! Open the supply and run it until it malfunctions. When it does, take a can of compressed air like you use to clean your keyboard. Attach the enclosed tube to the spray head and give a short spray to each semiconductor one-at-a-time. Spray a part, watch to see if your function is restored. Spray another, watch again. Continue this until your unit is working again and this will be the faulty part. We used to be able to buy small cans of R-12 freon for this purpose until they found it ruined the ozone layer.
If it is a laptop, make sure your supply is not laying on a carpet, bed, pillow or any other plush surface. Make sure you have it on a flat, hard surface to allow air flow around it.
Good luck,
Jeff Mc.
Jan 28, 2011 | E-Machines (AMP23050N) 230-Watt Power...
CAR WILL START BUT KEEP CUTTING OFF
Possible problems to check.
Remove battery leads
Remove rotor cap and clean off corrosion with a screw driver and replace.. SIMPLE
Move over to carb and remove hose. Open Air cleaner box and check to see if filter is dirty (replace at later time if it is)
While carb hose is removed spray some car cleaner into the carb with flap closed You will notice a black hole before the flap, spray some in there too and use a rag to clean it up a bit. Now spray carb cleaner inside the carb w flap open and use same rag as far as you can push it down to clean inside. Next spray all connections on outside of carb and move them around. Wipe everything clean again and replace hose.
It could be a temperature sensor. you can't clean it but unplug it, inspect and replug back in. look part up on net so you know what your looking for..or check EBAY for a pic and price if you need one. Not a bad Idea to replace since so cheap anyway especially if car is older.
EGR VALVE...ok, here you will need a few tools. Look for video on it's removal (simple but time consuming. Remove EGR valve and spray carb cleaner in everything and try to clean with rag, cue tips pipe cleaners (wire with fuzz on it) Clean it twice as it's expensive to replace and could be problem , then put it back in after it dries out. (don't forget to spray and clean carbon out of metal tube leading to the EGR valve.
While car is off check oil. radiator and windshield fluids while you wait for things to dry. Dont spray to much carb cleaner in carb or you will flood it with **** and will be hard to start.
Turn car on take it for a spin and see if that fixed prob. Total work time for above approx. 1 hour if your slow. Total savings if fixed 3-900 dollars. Your cost..a can of carb cleaner $4.00
Once you get home whether working well or not, CHECK Trans fluid level and refill to PROPER level. Not to much. Believe it or not this can cause problems as well and needs to be at proper level.
Hope one of these helps.
Jan 06, 2011 | 1993 Toyota Camry V6
Fan works randomly....when it's not working plug
Hi, If the computer is hot near the electrical plug in the back of the computer then the power supply needs to be replaced. This will also cause overheating problems if the fan does not exhaust enough air. You should not run the computer in this condition because the power supply can short out and take other components with it. Also there is a risk that it will burn up. Power supplies are very inexpensive and can be changed by anyone with basic computer repair knowledge. Hank
Jul 26, 2010 | eMachines T5212 PC Desktop
95 Impalla wont start when it rains
clean and spray all ignition plugs will busty penatration oil , check all body gounds for good contact , clean if signs of rust should help
Jan 20, 2010 | 1995 Chevrolet Impala
Compaq presario sr1950 nx desktop - won't start
My suggestion would be to open the case and unplug everything and then plug it all back in again.
To test individual components, unplug everything but the CPU, memory, and video card to see if it starts.
Then one by one, plug the other stuff in and try starting again.
Nov 07, 2009 | HP Compaq Presario SR1950NX PC Desktop
My tower had a virus/trojan horse AND IT DOES NOT START OR REBOOT
You have loosing problem.
1. First of all check all the cable connection for loosing in your CPU.
2. Second re-insert your RAM after cleaning.
3. Check your power cable for loosing.
4. I am Hundred percent sure, your RAM is loose. Just unplug and replug your RAM after cleaning.
5. Hard Disk cable may be loose or SMPS cables are loose.
Try these steps. There is no hardware problem in your system.
Apr 27, 2009 | Computers & Internet
Tower not coming on
Check the power supply, if you don't hear any whir at all from the fan, power supply needs to be replaced.
Jan 04, 2009 | Computers & Internet
Dell Dimension 8200 PC Desktop Logo
95 people viewed this question
Alun Cox
