I have a frigidare model FRS23Kr4awo that seems to have stopped working. I can hear the compressor come on in the back but the fan inside never comes on. I have tried turning the automatic thermostat and it cycles off but when the compressor comes on the fans in the back and inside don't run. TAny ideas?
ice maker quit in our Roper side by side.
water supply seems to be ok and the relay that operates...
(More)
water supply seems to be ok and the relay that operates the water for the ice maker ohms out at 200 ohms, that seems to be ok. But no ice. Thanks in advance for your time.
I have a frigidare FRS23KR4AW that seems to have stopped working. The compressor sounds like its...
(More)
I have a frigidare FRS23KR4AW that seems to have stopped working. The compressor sounds like its coming on but the fan in the back and iinside are not coming on. any ideas?
The white hose located inside the refridgerator which i believe is for the ice maker/ water...
(More)
The white hose located inside the refridgerator which i believe is for the ice maker/ water dispenser came detached from the strap and it is extremely hard to rewind. Is there any way that this hose can be shortened and is there and coupler that can be used to cut it to length and put back together?
