Question about Netopia 2247NWG-VGx Wireless Router (2247NWGVGX)
I am trying to get xbox live working on my xbox 360 console but I need to open some ports and I dont know how , how do I open the ports ? I need to open the port 3074 and I need yo use (UPnP) because I want to play online gaming.
    Problem Solver:
  • 8 Answers
Okay so Here is the very simple solution. Go to your router page (192.168.1.254) and select Custom Services. Delete every port opening service you have made. Then Define a Custom Service lets just call it Xbox A and Open ports 80 - 65535 for TCP with the base host port 80 Do tthis twice for both TCP and UDP options. Enable the services on your Xbox (It needs to be Connected and have a static IP adress) It can take about 15 minutes to open all the ports to be patient. Your Xbox also needs to have a static IP adress. Lastly set the routers firewall on low and give it a shot. It worked for me!
Posted on Jul 08, 2009
Something wrong with the wireless conection thing
Try this. Plug an Ethernet Cable directly from your 360 into the modem and try playing on Xbox Live. If it works, then it's a problem with your router. Either you're entering the wrong security key or your router isn't letting the 360 access the Internet. (AKA your ports need to be opened.)
Information on opening the ports for your 360 can be found at http://www.portforward.com.
Jan 06, 2011 | Microsoft Xbox 360 Console
My ports are not open and my internet say you nat type is moderate
If you have a firewall or network hardware, such as a router, you might need to make a configuration change in order for your Xbox 360 console to communicate with Xbox LIVE. This configuration change is sometimes called “opening ports” or "port forwarding."
Xbox LIVE requires the following ports to be open: • TCP 80 • UDP 88 • UDP 3074 • TCP 3074 • UDP 53 • TCP 53
Jul 01, 2010 | Microsoft Xbox 360 Elite Console
I have a Cayman 3347w wireless router and I am trying to use one of the wired slots to connect my xbox 360 to the internet. the xbox will not connect. is this router xbox compatable?
Please try the following steps below;
To make a router connection to Xbox LIVE:
  1. Before you connect any cables, turn off your router, modem, PC, and Xbox 360 console. (Unplug your modem from its power source to turn it off.)
  2. Connect one end of an Ethernet cable to the Ethernet port on your modem and the other end to the Ethernet input port on the back of your router.
  3. With another Ethernet cable, connect one end to one of the router's Ethernet output ports. Connect the other end to your PC's Ethernet port.
  4. With the third Ethernet cable, connect one end to another of the router's Ethernet output ports. Connect the other end to the Ethernet port on the back of the Xbox 360 console.
  5. Turn on your modem, then your router, then your PC.
  6. Make sure your PC can access the Internet. If not, you may need to configure the router for Internet access. For help configuring the router using your PC, check the instructions that came with the router.
  7. Turn on your Xbox 360 console and sign in with your profile.
  8. If this is the first time you've turned on your Xbox 360 console, see Create Your Gamer Profile to get started with both the Xbox 360 system and Xbox LIVE play.
If you're unable to connect to Xbox LIVE, you can try to diagnose the problem right on your console. Go to My Xbox and open System Settings, then select Network Settings (setup XBOX using Automatic Configuration DHCP), Test Xbox LIVE Connection.
Hope this helps!
Mar 28, 2010 | Netopia Cayman 3347W-Ent Wireless Router
Xbox nat setting
Mar 07, 2010 | Microsoft Xbox 360 Controller
XBOX 360 strict NAT problem
Make sure you also open the ports on your router. IF you have all the appropriate ports open and still have strict NAT, it's more than likely your ISP and you should give them a call.
Jan 07, 2010 | Microsoft Xbox 360 Elite Console - Black
Connecting xbox 360 live
if you plug the computer into the usb port a box will come up and you register it as for the adapter get the one for the xbox plug it in and go to the dashboard then console setting then xbox live connection then test connection and if it doesnt work try the linksys one or the wired one.
Jul 12, 2009 | Microsoft Xbox 360 Console
Why isnt my xbox connecting? i plugged the cble into the rouder and then put the other cable into the xbox and its not letting me connect.
To make a router connection to Xbox Live:
  7. Turn on your Xbox 360 console with no disc in the disc tray.
  8. If you've already used your Xbox 360 system for offline play, the Xbox Dashboard will open to the Xbox Live area. Select the Xbox Live banner. When you see the Xbox Live Marketplace you'll know you're connected to Xbox Live.
Jul 02, 2008 | Video Game Consoles & Games
Xbox live connection: My NAT
its likely your router needs to have port forwarding setup on it, or you could try setting up your Xbox ip address as a DMZ on your router.
however some routers simply wont work, I had a voyager 105 using port forwarding but it still never worked till i changed to a Draytek
post more details of your router and what you have tried.
also you cant go far wrong visiting here
http://www.xboxlivetheguide.co.uk/XBoxLiveTheGuide2.php?department=Home
Mar 10, 2008 | Microsoft Xbox 360 Console
Cannot sign up for xbox live
have you tried running the troubleshooter (if so, wat did it say?)
Apr 13, 2007 | Microsoft Xbox 360 Console
Netopia 2247NWG-VGx Wireless Router (2247NWGVGX) Logo
351 people viewed this question
Top Netopia Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Elise Lacoursiere
Elise Lacoursiere
Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
