Question about Dryers
MAYTAG NEPTUNE dryer takes long time to dry, notice water coming
MAYTAG NETUNE dryer takes long time to dry, notice water coming front front of dryer
  • Anonymous Mar 15, 2014
    How long will it take a quarter of inch of water to dry up
    Problem Solver:
  • 16 Answers
Your vent is very very cloged you need to take off vent hose and clean lint out of dryer.(do not use until you do.
Posted on Jun 27, 2009
I need the diagram that comes with the dryer. Maytag Netune Model MCE8000AYW
depending on the serise which is the first two numbers of the serial number here is the diagram http://lookup.bellparts.com/diagramenlarge/2/0/561302/91934
Hope this helps
Jun 18, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Dryers I have a Maytag electric Dryer, that...
you may have one of ur overheat sensors going out that wont let the elements heat uplike they should they are behind the back cover they are round and very inexpensive u can take the wires off put new one in or u may have a bad element ake the wires off and check continuity thru the element itsself if all that is good take dryer vent off and run with it off 1 load and seee if this cures the problem if it does u had the hose kinked or u have a restriction of lint in the dryer vent going outside hope this helps
Feb 25, 2010 | Maytag Neptune MDE6700A Electric Dryer
Maytag Neptune MDG4000BWW
check your door switch it might be broken. push the door switch in with your hand. does the light turn off? if no this is your problem
Aug 19, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag neptune dryer not heating up to dry clothes.
On my dryer the igniter is rt behind the front panel. Take off the dooe and a few screws and pull it off. If the igniter lights at all it is good. Try also checking the entire discharge vent hose as sometimes it gets clogged way dn line and you might not notice it. Try squeezing it all the way dn.
Mar 02, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Squeze noise, do not dry and drop water from the bottom
Replace: a110f97.jpg
These get loose and rattle make it take fifty forevers to dry the clothes. To get to it you must remove the front. Start here:
Dec 19, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune DC Model# MCE8000AYW leaks water from the right side of drying center unit while using the "Wrinkle Release Hanging Dry Only" feature. The leak happens during the steam portion of the cycle....
Stop using the water bottle because the water is overflowing the heater steamer pan and will short the heating element and the part is no longer avaliable and the top will stop drying.
Mar 27, 2008 | Maytag Neptune MCE8000AY Electric Dryer
Maytag Netune Mah4000AWW
Makes a loud humming noise. Does the machine go thru its cycles ? Is the humm ther all the time ?
Jan 06, 2008 | Maytag MAH6500 Neptune Front Loading...
Dryers Logo
146 people viewed this question
Top Dryers Experts
