Question about Garden
My XR80 weedeater will not run past the initial prime into the sparkplug feeding.The tubing has been replaced as they were brittle.Local dealers tell me that part is unavailable so I am looking for the diaphragm in the unit above reed valve j/b
  • 59 Answers
Try changing the gas lines around
Posted on Jun 27, 2009
Weedeater starts but won't run for more than 30 seconds
A lot of times the line that in the tank deteriorate so you mean may need to replace the line in the fuel tank
Aug 12, 2014 | Makita Em4251 24.5cc Gas Powered String...
I just cleaned the carberator and new sparkplug it sounds like it not getting fuel when i put alittle gas in the carberator it starts and obviously stops? on my craftmen weedeater
if it is an older one, the gas lines like to rot away. you can usually tell by looking down inside the gas tank. you can also check to see if the primer is moving the fuel through the lines as you prime it
Jul 07, 2011 | Craftsman 25cc Gas Line Trimmer
I have a Poulan 3400 and when I can get it started it won't run with any power. Changed fuel and fuel filter on end of fuel line in tank but still have to "feather it" once it is running and still bogs...
OEM fuel line gets brittle and cracks, typically passing fragments to carb, which clog filter screen in carb. If in doubt, replace line with "Tygon" available at most dealers. Pvc is not suitable. Cut tube at end at an angle and feed through tank hole with needle-nose/hemostat. You may be able to open carb to clean filter, or it may be better to find repair shop to do it as part of rebuild. Don't know if you can find replacement carb, but carb kit is available, and inexpensive.
Aug 26, 2010 | Poulan Garden
Johndeere c1200 weedeater
Clean air filter and check fuel lines for trash.If that isnt the problem your carb may have trash in it.Thanks for asking and I hope it helps.
Jul 16, 2010 | Garden
Poulan bv200. will not throtle up. it starts with choke at1/2 and throtle at 1/2. new spark plug and clean air filter. when i try to zero choke it dies. and at full throtle it will not get to full speed...
The unit is lean. rebuild the carb with a carb kit and check your fuel lines. If they are brown or discolored or brittle they need to be replaced. carb kits run approx. 11 - 18 dollars from your local dealer.
Nov 23, 2009 | Poulan Garden
Replace fuel lines WeedEater FL 1500 Blower
On the FL1500:
  • The Smaller line goes on the Lower inlet tube on the carborater the other end goes to the gas filter inside the gas tank.
  • The Larger line goes on the upper outlet tube on the carborater the other end goes to a fitting that holds this tube from coming out on the gas tank .This tube is only for Air, it helps fill the primer bulb when pushed.
I hope this helps.
Mechs correct me if I have made a mistake.
Thaxs Jon
Sep 09, 2009 | Garden
I have a weedeater series 300 lawnmower. When I prime it, it will run for about 5 seconds and then stops. It burns off the gas from priming it and then cuts off. If I do this about 20-30 times then it will...
thats a common problem with those briggs motors. There is a plastic tube that goes from the back of the carb to the other side of the motor. There are two small bolts that hold the tube down opposite the carb end of the tube. They loosen over time allowing to much air to get in. Also the tube cracks but not to often. If that doesn't help you need a kit that comes with a gasket and a diaphram. you may need that because the tube warps were it meets the carb. That should fix it.
Jun 18, 2009 | Garden
Weedeater XT 85T wont run
Check to see if your feul line is cracked or it is drawing air . Check your clamps that hold the lines on . One other thing you can check is to see if any bolts are loose that hold the carb on . Best of luck Ed.
Engine dies when excelerating - more gas
check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. if that doesn't work have the carb repaired at a service center or replaced.
Nov 17, 2008 | Homelite Mighty Lite Lawn Trimmer
Garden Logo
254 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
