Question about Kenmore Dryers
Turns on and has no heat
Dryer acts like normal but has no heat
It did stick on the other night and did not go off.
  • 64 Answers
Check operating and high limit thermostats. Just check all thermostats and thermal fuse non resetable. After that is done check heating element. Good luck Be sure & check thermostats something is not shutting it off. Timer may be stuck in cycle.
Posted on Jun 26, 2009
Why does my gas dryer heat keep shutting off?
The solenoid coils on the dryer are acting up. This is a common problem. They work a little then heat up and short out. Easy fix I did some videos:
How it works
Replacement
Jul 22, 2012 | Maytag Centennial 7.0 Cu. Ft. Super...
Whirlpool supreme LER7646EQ2 won't heat up
The heating element is no good. They break after years of use as they heat up and cool down over and over, they wear out. The part is cheap and yes it is easy to replace. Turn your dryer around, and take off the screws to a short piece of metal that has "vents" in it. It should be sticking out a bit compared to the rest of the dryer back. normally 2 or 4 screws holding it there. You'll see the element. Just pull it out, take it to the appliance shop or Sears and get another element. Go home, stick it back in there and reconnect the panel you took off. Cheap part, simple fix...you'll be surprised how well it heats after that.
Jun 09, 2012 | Whirlpool LER5636P Electric Dryer
I have a Roper gas dryer (RGS7646KQ2) which is not heating up to dry clothes. The drum turns and the timer works as well. It appears to be acting normally, except it is blowing cold air instead of warm...
You have a bad thermostat, flame sensor, thermal fuse, gas valve solenoids, or the high limit thermostat. Below is a video to walk you thru the diagnostic testing and repair.
Jan 03, 2011 | Roper RGS7646KQ Gas Dryer
Dryer turns on and acts normal, but does not get hot. Product is barely 1 year old.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 18, 2010 | Samsung DV219AE Dryer
My dryer turns on just like normal, the time is just like normal, the heat is just like normal, the run time goes down to a minute about 15 minutes into the drying time, and the dryer plays it's little...
I would try a couple of things.
1. Clean the filter, the vent, and the vent tubing.
2. Clean the dryness sensor (the little prongs you see sticking out down in the filter area) with a toothbrush wet with isopropyl alchohol.
Feb 10, 2010 | LG DLE2516 Electric Dryer
Dryer ran all night now no heat
Remove back of dryer and take out the elament shield and replace element don't over strech it start at one side and work it around thank you for useing fixya rate me
Jul 13, 2009 | Estate TGDX640JQ Gas Dryer
My dryer has no heat adn will run all night
If it's sensor dryer then it's absolutely normal to run all the night, as it stops only when the load is dry. And for the heating Take the unit apart and check the heating element.
If you need more info give model detail.
Good luck
Jul 05, 2009 | Dryers
Whirlpool electric dryer ran all night and won't heat
Yes it will heat. The two are normally not dependent on the other. The element could be bad. Check the breaker first, then the connections in the back, then the element. The timer could be bad itself allowing it to run all night. This could be a blessing in disguise as the clothes would have been damanged possibly from all the excess heat.
Dec 26, 2008 | Whirlpool LER4634J Electric Dryer
Dryer does not get hot
pleas4e help my dryer is working but it won't get hot it just blows cold air please help me fix this problem
Jul 20, 2007 | LG DLE0332 Gas Dryer
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
