Question about NorStar M7310 Corded Phone
How do I turn off the ringer on my extension so that everytime a call comes to the main switch I can't hear it -- I only want to hear the intercom rings
  • 1 more comment
  • Anonymous Nov 09, 2007
    turn off ringer
  • Anonymous Nov 19, 2007
    Please show me step by step how to turn ringer on . when outside calls, my m7310 will ring. thanks in advance .
    please email . thanx again
  • JonnyTech Jan 15, 2008
    I know it can be done, but the manual doesn't say how to turn off the ringer for external calls.
  • 3 Answers
No where have I seen this answer documented in the user guide. LUCKILY someone from our company in past did document the procedure. Feature **266344, PW: 266344 (this is different from the listed PW of 26346). Press the top arrow on the right. Enter the extension you want to turn off. Press the top right arrow again twice until you see Line assignment and press the top right arrow again. Enter the line you want to change (001) Then hit "change" until you see the status you want to achieve (appear only). Scan through all the remaining lines in your trunk. Don't worry- only took me an entire day to find this configuration!
Posted on Mar 18, 2008
How do I turn off the ringer on my Panasonic Telephone base?
It would help if you add a comment with the model number of your phone. For the KX-TG6572R, to set the ringer to off on the base, press and hold the Down button on the base until the phone beeps when the phone is in standby mode. Note: if the phone has an intercom mode, the ringer for the intercom is never silenced.
I hope this helps. If this procedure doesn't work for your phone, please add a comment with your phone's model number. Then, I will try to find additional information about the ringer volume control for you. (I know some phones have a physical switch on the base for the ringer volume.)
Jul 08, 2015 | Panasonic Lands Phones
Old Norstar phone-one line seemingly tied to one extension
You most likely need to call in your tech who looks after the programming there.
Needle in haystack, sticky button, bad programming, glitch in system, answer dn etc.
Dec 10, 2012 | NorStar M7310 Corded Phone
NEC Dterm80 phone, Model DTH-16D-2. We have an Extension that rings as a back-up to the main attendent/receptionist in the event she cannot answer an incoming call. I need to disable the incoming ring at...
Hi if you just want to silence the actual unit, most often you will find a small switch on the unit, that switches OFF the ringer, or often one can turn it down, via a control on the unit. Other times one can set it Off or down in volume via the settings, use the manual in these case to ascertain what to do. -
Above is a manual so you can check exactly what and how to do what you want.
If this cannot be done, then take the phones case OFF, locate the "Ringer" and disconnect it from the board, problem solved.
Apr 19, 2011 | NEC Dterm DTP 16D-1 Corded Phone
My phone is ringing but cannot hear the sound only blinging the light. So how can i return back the ring sound?
Only 3 things make it not ring, there's a switch for the ringer on the left side of the phone, it needs to be programmed to ring in the 40x's, or the ringer is defective. If it rings on the intercom (with the AUTO ANS) turned off, it must be programming.
Jan 24, 2011 | Panasonic KX-T7730 Corded Phone
I need to set the ringers to only ring at the two receptionist desks and not everyone else's offices. Please help! We have Avaya Partner 18D phones.
Partner ACS systems come with Centralized programming instructions. Most of them starting with Feature 00 Left Intercom twice and Right Intercom. When you dial an extension, the lights will be solid or blink according to how it's programmed and you press each button to turn on or off or delay ringing.
Your system administrator should have a book.
Sep 28, 2010 | Avaya Corded Phone avaparp18d
Change intercom ringtone
There is no way to change the ultra-annoying intercom ringer tone.
Suffer through, or just tell the wife there will be dire consequences if she continues to use.
Sep 04, 2010 | Vtech DECT 6.0 Cordless Phone with Digital...
My kx t7730x doesnt have a ring but its receiving calls outside.
I'm guessing this is connected to a TA series system.
There is a ringer switch on the left side of the phone. Does it ring on intercom calls with the Auto Answer button not lit?
The 2 things that control the ringer for outside calls is the ringer switch and programming. Intercom calls ringing is controlled by the switch, Auto Answer button, and programming. If the switch is set to medium or high and the phone doesn't ring, try it at another extension. If it still doesn't ring, it's broken, if it rings, then you have programming issues.
Sep 11, 2009 | Panasonic KX-T7730 Corded Phone
Go back to that original 7433. Beg, borrow, or steal one of those phones from someone else and plug it back in. Have someone call you on the intercom and make sure the AUTO ANS button is not lit. Does it ring? Now plug in your 7453 and do the same thing. Does it ring?
I think I only had one or two of those models and the ringer is a two step switch (3 positions) OFF LO HI on the side of the phone. Make sure it's set to something besides OFF.
If the phone rings on intercom but not on the outside lines, that's a different problem.
Sep 05, 2008 | Panasonic KX-T7453 Corded Phone
Phone does not ring or show caller ID
From extension 10 or 11.
Press feature 00
Press left intercom twice
Then right intercom once.
enter your extension number
You will see the lights blinking green on the phone, where your lines are. Touch them until they are solid green. If you want to program another extension, press the right intercom button again and enter the new extension number.
Once done, press feature 00 to exit programming.
As far as the caller ID, there is no way to turn it off on the Partner system. My guess is the provider isn't sending caller ID.
Jan 04, 2008 | Lucent PARTNER18 Corded Phone
RCA 25450RE3 - Incoming Call Ringer Setting
try turning ringer speaker volume down. if that does not work, then remove battery for 10-15 minutes and replace and try again.
Oct 12, 2007 | RCA H5450RE3 Accessory Handset For -25450...
NorStar M7310 Corded Phone Logo
3,017 people viewed this question
Top NorStar Lands Phones Experts
Oloyede Monsuru
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
