Question about McCulloch Garden
Need guide on how to install rewind on a McCulloch 14 inch gas chain saw,someone started it now I have to finish
  • 11 Answers
SOURCE: need owners maual for mcculloch power mac 6 chain saw
try my answer to the post on McCulloch pro/mac 10-10 chainsaw owners manual... posted by denniswick on Oct 03, 2008
Posted on Feb 13, 2009
  • 42 Answers
SOURCE: I have a McCulloch 10 10 Automatic Chain Saw. What is the oil to
40:1 of two stroke oil roughly 2..5% 40 parts fuel to 1 part oil mixed Good Luck the Yeti
Posted on May 17, 2009
dnewcombe1
  • 1564 Answers
SOURCE: I just bought a used McCulloch Electric chain saw
Just type the model number in your searchbar, NOT the brand name, beside this type"pdf." without the quotes,then the word manual. After filtering through all those pesky sponsored sites watch the links for your brand of chainsaw with the "pdf."manual in the link and thats it as long as you've got Adobe reader you're all set. P.S. Don't forget to save it to your documents . Thanks, Dana
Posted on Aug 30, 2009
  • 4088 Answers
SOURCE: just got a homelite 33cc
Yes you do! The ratio is 50:1 fuel to oil. Be sure to use a modern synthetic saw oil available at home centers, hardware stores, and saw dealers. Be sure to use fresh fuel and mix the two in it's own container. Be sure to shake the container thoroughly each time just before refueling to prevent oil starvation in the engine. Don't make up more than one gallon at a time unless sawing is your business. Hope this helps!
Posted on Dec 16, 2010
  • 54 Answers
SOURCE: McCulloch 14" chain saw Model CS 38 EM It quit
Most often there is a dust-oil clog in the bottom of the bar slot which closes an oil passage between the bar slot and the hole drilled half way through the side of the bar. This provides a passage between the thin shim plate with the two bar bolt holes beside the bar and through to the oil tank or pump output. You can remove the bar and chain and punch out the blockage in the bar with a paper clip if the chain is removed. Make sure the wire can be pushed from the bar slot right through the side hole in the bar. A gravity feed chainsaw should leak right out into the slot of the shim plate, a button pumper should squirt out there with the bar removed. With a button pumper you may have a tiny check valve in the line or the push button to take apart, replace the spring or unstick the ball inside the check valve. This is why they went to the gravity feed oil system which just leaks in there and gets picked up by the bottom of the links as the chain races past the passage between the bar side hole and the chain slot.
Posted on Mar 24, 2011
Testimonial: "I checked as you suggested and I removed the pump from the crank shaft and the plastic gear is stripped. Now I can not find a pump. Thanks Jim"
How many drive links does a McCulloch MCC1635A 16-Inch 35cc 2-Cycle Gas-Powered Chain Saw bar have ?
I recommend contacting your local authorized service center for assistance.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
User manuals McCulloch Service
I trust this information proves beneficial.
Sep 02, 2014 | McCulloch MCC1635A 16-Inch 35cc 2-Cycle...
Powermac pm 145-14
Please restate your answer in the form of a question.
Contact us
User manuals
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
Sep 30, 2013 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
What type of gas do i use for my McCulloch 16 Inch Gas Chain Saw
If using an oil other than McCulloch, the ratio is 40:1. Brand Specific McCulloch two cycle oil is 20:1.
Jul 02, 2012 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
I need the oil to gas ratio for a McCulloch Mac 3216 chain saw
Refer to the provided links:
Contact us
User manuals
McCulloch Service
Oct 13, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Can i upsize my chain from a 14 inch to a 16 inch i have a 14 inch mcculloch and i want to put a 16 inch bar and chain on it. it is a 35 cc engine
There will be a 16" option, however things to remember, you will have a drop in power, so you need to keep the chain sharp, the oiling system will probably on its limit.
Apr 19, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Need a manual, for McCulloch, FR2=0, 14"
what is the fuel / oil ratio for McCulloch 2.0 14"
Aug 04, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Fuel mix
Quick check with mfg (DAGS mcculloch) yields: 40:1 with their 2-stroke oil and 87 octane.
I've run one (with 14" bar) for years on same 50:1 mix I use in other saws with no problems- synthetic oil and regular gas. One of these saws is now 30 yrs.old. And ... no smoke-cloud, nor port/muffler mung.
With new saw, you might want to use more oil for first few hours. Just remember that doing so leans the fuel mixture.
Aug 02, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
McCulloch chain saw
check the plastic tubbing in the gas tank might need to be replaced or the primmer bulb has a pinhole in it.
Jun 21, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Garden Logo
50 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
