Question about SMC EZ Connect g SMCWUSB-G (SMCWUSBG) 802.11g/b Wireless Adapter
PC wont recognise SMC Wireless adapter!
Hi
i bought a new Vista32 HP Pavilion a6260d home pc and i needed to buy an adapter for wireless internet. i bought a SMC ez connect g 802.11g wireless USB2.0 (SMCWUSB-G) Adapter and installed it.
after installation i opened the program to setup the connection.
at the top of window, it should say the name of my wireless adapter, instead it says wireless card not found even though its already plugged in the USB port.
i dont know how to fix this. ive tried re-installing it already.
Right now im using a wire for internet but need wireless.
just incase you need this my specs are.
Processor: Intel(R) Core(TM)2 Duo CPU E6550 @ 2.33GHz 2.33GHz.
Memory (RAM): 3071 MB (Previously 2GB, upgraded to 3GB).
System Type: 32-bit Operating System.
Help Appreciated. Thx
beeveez
  • 167 Answers
SOURCE: why does my D Link 802 11g Wireless Router WBR
Make sure your computer has the ability to get online wirelessly.
Posted on Mar 09, 2009
SOURCE: SMC EZ Connect(tm) g 802.11g Wireless USB Adapter doesn't work
Try this site
http://www.smc.com/index.cfm?event=downloads.doSearchCriteria&localeCode=EN_USA&knowsPartNumber=false&productCategory=5&modelNumber=585&partNumber=3203&downloadType=0&os=0
If that doesn't work go to SMC.com click the support tab and follow the instructions.
Posted on May 01, 2009
redhaze89
  • 854 Answers
SOURCE: I have a Ranklink 802 11g wirless ubs Adapter with
maybe this can help
http://download.cnet.com/802-11g-Wireless-Lan-Driver-10-1-0-11-zip/3000-2112_4-162293.html
Posted on Mar 29, 2010
  • 198 Answers
SOURCE: SMCWUSB-G 802.11g adapter will not renew IP address.
you should be able to configure the setting in the utility for the adaptor to auto renew the ip address
Posted on Apr 22, 2010
uzi9mmauto
  • 17 Answers
SOURCE: how do i install my 2wire 802 11g usb wireless
The Link im giving is for WIn 98,2000,XP etc and Vista.
Both Version of 2wire 802.11g USB Wireless Adapter Drivers are Here:http://www.youtube.com/watch?v=pgGovtiQp3g
Video Explains,Links you and comes with Installation Pdf manual.
Take care
Posted on May 25, 2010
I have installed a SMC2862W-G wireless usb adapater on my pc. it is recognizing my wireless router and it is showing a decent signal strength in the SMC utility. However, my wireless connection icon on my...
You need to install the driver disk that came with the USB adapter. Your PC correctly pointed out that the internal WI-FI adapter is not working but the USB adapter should be showing on the taskbar of the driver is installed correctly.
Mar 08, 2018 | SMC EZ Connect g SMC2862W-G 802.11g/b...
Can't enable wireless service
Unfortunately HP laptops have a history of wireless cards frying. If your machine is still relatively new (1-2 years old), you can talk to HP to have it repaired by them. Otherwise the best option is to buy a USB wireless adapter from Best Buy or Newegg.
Mar 05, 2011 | HP Pavilion dv7-1132nr Notebook PC
Does my hp pavillon s7310n slimline PC have wireless internet capabilities
Not built in, but you can pick up a USB adapter such as this one for cheap: moz-screenshot-1.pnghttp://www.walmart.com/ip/CNet-CQU-906-Wireless-N-PicoUSB-Dongle/15571889?sourceid=1500000000000003142050&ci_src=14110944&ci_sku=15571889moz-screenshot.png
Mar 01, 2011 | HP Pavilion s7310n (EN996AA) PC Desktop
Can the HP Pavilion 763n PC Desktop use a wireless router?
Your computer has a "built-in" 10/100BT network connection integrated on the motherboard but to go wireless you'll have to add either a PCI (internal) or USB (external) wireless network adapter to transmit/receive the signal from your wireless router. Think "walkie-talkie" here with the wireless router installed AFTER the modem (phone line outlet needed) located in a central area of your home and transmitting/receiving to the individual wireless network adapters that must be separately installed in each computer.
Oct 19, 2010 | HP Pavilion 763n PC Desktop
I hava a hp 13" laptop that wont show wireless option in the internet properties. I have a wireless Lan Mini PCI card, but it is not being detected. Is there away to re enable the wireless?
Hi. Please check first if your computer was able to detect the device. You can look for this device in control panel then click system then click device manager. Your wireless adapter should be present under network adapters. f computer was able to detect the wireless adapter. Try to turn off/on the wireless switch. Usually, wireless switch is located infront of the laptop or on the side. You can also try pressing Fn + F5 key to disable/enable wireless network card.
Jun 13, 2010 | HP Pavilion TX1000Z 12.1" Touch Screen...
How do i set up wireless internet on my hp pavillion a330n desktop? Do i need a wireless card or is it built in? and where do i put the wireless card if i need one?
Yes you need a wireless adapter.
Solution one : Get PCI wireless adapter which you will insert in an empty PCI slot inside your computer.
Solution 2. Buy a USB wireless adapter, which you plug in a USB port.
However, if my memory serves me right, that particular HP pavillion is 5 or 6 years old, and it does support USB 2.0, just USB 1.1
My advice to you is to buy a USB 2.0 PCI card to be installed in an empty PCI slot )or in the one occupied by the firewire )if not needed). This card will provide 4 or 5 USB 2.0 adapters. Then buy a USB wireless adapter, which you will be able to use with other computers.
Hope It helps.
Rate this solution if it helps you.
Aug 29, 2009 | HP Pavilion a330n (Refurbished)...
WHAT PCI CARD TO GET WIRELESS INTERNET ACCESS ON
You can get this adapter from Linksys its WMP54G so you can make the computer wireless, but you can also check some adapter from Ntegear , Belkin and Dlink...
Aug 16, 2009 | HP Pavilion 734n PC Desktop
Cant connect my SMC to other home computer and have a netgear router, how do i connect my smc adapter
Most hardware like an Network Adaptor you install the software CD 1st. Then plug in the hardware.
Then if you configured wireless (wifi, 802.11) settings on your SMC - you should fine the network NAME when you try to connect. You will be asked for the security key for WEP or WPA or WPA2 that you used in the SMC.
SMC should... then assign IP Settings automatically. If the SMC has Internet, you should have Internet.
Jul 07, 2009 | SMC EZ Connect g SMC2862W-G 802.11g/b...
HP Pavilion dv9000 17" (Windows XP) lost my wireless internet
Hi there.
If your using Vista or XP, what i want you to do is right click "computer" select "manage" and then "device manager", then click on the + sign next to "network adapters" and right click on the wireless network and "un-install" the device, reboot the PC and wait for windows to detect the wireless card and install the drivers for it, this will appear in the system tray (bottom right hand side) when its done try to connect again
keep me informed please
Good luck and thanks for using FixYa!!
Apr 03, 2009 | HP Pavilion dv9000z Notebook
New pc, with wirless adapter,
look in your manual, turn off your internal modem, wifi. and then plug in your new adapter. restart and see how that works. if not then best buy has a great tec department
May 13, 2008 | Computers & Internet
SMC EZ Connect  g SMCWUSB-G (SMCWUSBG) 802.11g/b Wireless Adapter Logo
346 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
J John
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
