Question about Brother HL 1430 Laser Printer
HL1430 printer wont print
Hi, i have a HL1430 printer and have just replaced the drum unit and for some reason it will not let me print any stuff off, i have the following lights on alarm is red and data is orange, do you know how to fix this problem?
Parts of paper are stucked inside our HL-1430
Posted on Jan 05, 2010
  • Per Fynboe Jan 05, 2010
    how to open the printer and remove the paperparts?
  • 526 Answers
According to the error, your toner cartridge needs to be replaced.
thank you
Posted on Jun 26, 2009
I HAVE REPLACED TONER WITH THE CORRECT BROTHER TONER CARRTRIDGE AND THE MACHINE KEEPS TELLING ME TONER ERROR AND REINSTALL DRUM UNIT..HELP
Below are instructions that I have found from the internet. Hope that they will help.
  • Open the front cover of the printer.
  • Hold down the Go button for 4 seconds until all the LEDs light up. Then release the Go button
  • Remove the drum unit and toner cartridge assembly.
  • Replace the drum unit and toner cartridge assembly back into the printer.
  • Close the front cover of the printer
  • Your drum unit should now be reset
  • MFC / DCP PRINTER SERIES
    1.Remove the drum unit and toner cartridge. Wait 1 or 2 minutes.
    2.Replace the drum unit and toner cartridge into printer.
    3.The error message "Change Drum Soon/Drum end soon" will continue to appear if the drum counter was not reset when you replace the drum unit.
    4.To clear this error message, you need to reset the drum counter as instructed below.
    5.Make sure that the machine is turned on.
    For MFC users: To confirm you are installing a new drum, press 1. For DCP users To confirm you are installing a new drum, press the Up Arrow key
    7.When the LCD shows Accepted, close the front cover.
    8.Your drum is now reset.
    Resetting the drum unit will not improve print quality. It only resets your drum and allows you to continue to print. You decide when to replace the drum unit not the manufacturer!
Feb 24, 2015 | Brother MFC-8860DN Printer
PRINTER DRUM ERROR
The drum unit needs to be replaced as it has reached maximum prints for the drum.
The drum unit is the carriage part that the toner unit sits in before it is put in the machine.
Aug 29, 2014 | Brother HL 1440 Laser Printer
Hi, I have had my CLX-2160 printer for 3 years now and its started to print with a fade on the left side only and have just under half black ink left. Is it worth changing the black toner cartridge or does...
Hello.
There are two reasons the fade happens. Running out of toner and the drum not responding correctly. The Drum is the unit that transfers the toner to the paper. if it gets damaged or dirty inconsistent print is usually the result. Try taking the toner out, shaking it and replacing it to see if it affects the print quality. if it does not price a replacement drum and toner, compare it to the price of a new printer and this will answer the second part of your question!!!
I hope this helps Regards GM
May 27, 2011 | Samsung CLX-2160N All-In-One Printer
New toner but printed output is too light and faint. What can I do?
Hi there !
You need to replace the drum unit of the cartridge and i believe that the part life had ended. you can view this on the LCD monitor of the printer. Go to menu and choose LAN setting. Choose machine parts and check the drum unit is it says life ended. You need to replace that drum unit.
Another way for temporary purposes, set your print quality setting to PHOTO setting. It will print darker than before but not on taking photocopy.
Feb 09, 2011 | Brother MFC-7820N Laser Printer
Replace photoconductor unit
take all paper out. check to see if any paper is jammed in the rollers
go to application folder for your computer, dbl click icon for make of printer, for settings, check to ensure everything is order.
lastly, check make of printer trouble shooting web site for more information
hope this helps, good luck.
Apr 29, 2010 | Gestetner DSm725 All-In-One Laser Printer
How do I reset the drum counter on the a Brother MFC-7840W???
open the front cover of the machine then press clear back it will say replace drum? press ok
the quality will probably start getting pretty bad as you will be using the drum passed it's life
Mar 22, 2010 | Brother MFC 7840W Printer
HL-5240 Appears to need new toner but that didn't fix it.
If the marks on the page appear to repeat three or four times down the page regardless of what is printed, it could be the drum unit ( the unit the cartridge fits into) You can test this by taking the cartridge out of the drum and looking at the cylinder in the drum unit. If has light coloured bands, or looks very black, then it is at or past its life cycle ca20-25k pages. If it has clots of toner stuck to it but is otherwise ok, you could carefully clean it with alcohol and a cotton ball to remove the toner clots. Steady and patient is more rewarding than trying to grind the stuff off. If the drum looks reasonably clean, open the flap at the back of the printer and look closely at the fuser. If there are clots of toner stuck to the orange pressure roller or to the grey/tan fuser roller, then the fuser will need to be taken out and cleaned also with alcohol, cotton ball and much patience.
Feb 13, 2018 | Brother HL-5240 Laser Printer
Dell 3100 CN replace drum cartridge
No. There is no reset as there is with some units. This unit actually knows via a smart chip in the drum unit if it has reached EOL ( end of life ).
Jun 19, 2008 | Dell 3000cn Color Laser Printer
Brother HL 1430 Laser Printer Logo
450 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
