Question about Dell Dimension 4600 PC Desktop
No sound when pluged into the green jack on computer
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 381 Answers
Make a separate a sound card the board has defective or try to uninstall the old sound card drivers then install a new but if this not work totally the on board sound card is a have a problem so you need make put a new PCI sound card..good luck and have a nice day...
Posted on Jun 26, 2009
The audio jack green piece broke off in the green audio jack in the back of the computer. i have other audio jacks but am not receiving any sound what should i do really need sound
Depending on your Sound Card in your computer and depending on your driver you've installed you could configure that audio-output (normally green jack) is changed to the Blue jack.
You could try to change the audio config from 'Stereo' to 4.1 or 5.1.
Aug 07, 2013 | Dell Dimension 8300 PC Desktop
Front inputs? (green and pink not working)
I thought the front was for a microphone and headset. I don't think those are speaker jacks. Look closely at the icon that is next to the pink and green on the front, does it show the icon of a microphone and headset?
Normally the speaker jack will show and arrow going out which means sound going out. If you look at the speaker port in the back of the computer it is normally the light green port. Notice the icon on it. Does the icon on the front look the same as the one on the back? Is the color on the front the same as the one on the back? I think you're plugging into the wrong port.
Make sure you have the volume up in your Audio/Sound properties and make sure you don't have the speakers on mute. Also make sure you turn the speakers on and turn the volume up on them.
Mar 04, 2012 | ASUS Computers & Internet
I JUST bought a insignia speaker 2.1 (model # NS-PCS21) and the speaker plug ins are pluged right, power are plug in, the green and the red cord plugged in... i see blue light comming up. my computer sound...
Greetings - The setup (as you already know) is simple. If you have the a/c adapter plugged in, the power on and the green speaker cable in the audio out at the back of your PC and and the red cable plugged into the subwoofer and the volume knob on the the right speaker turned up that's all it takes.
The one possible gotcha I can see is if you have something plugged into the jack at the BACK of the right speaker (an AUX jack for things like MP3 players, etc.) it will override everything else.
If that's all good you have a bad set of speakers.
Regards,
Mikeywaf
May 30, 2011 | Insignia 2.1 Speaker System (3-Piece)
Well we pluged the cables up it shows up on the tv but its like green and puple the poeple
Are you using component cables for the video? If so make sure the colours match up between the plugs and the connectors on both the TV and whatever you are using as the video source (DVD player, digital cable or satellite box).
The green plug on the cable must go into the green jack on the TV, blue plug into blue jack etc. It sounds like you might some of them mimatched.
May 05, 2011 | Samsung LE37R72B 37 in. HD-Ready LCD...
Green light on speakers and sub. No sound - only hissing noise
open volume control & remove check from mute button.
start-program-acessories-entertainment-volume control.
Sep 17, 2009 | Audio Players & Recorders
JOANERM
You need to clarify a few things. Does it have sound? Also, is there a green light on the front of the PS3? Has it ever been played on the HDMI jack and then moved to the A/V jack?
Thanks,
Ced
Jul 12, 2009 | Sony Playstation 3 (PS3) Console
No sound from external speakers system
Look into your monitor settings and computer settings and see if you can reverse the "input" and "output". If both are set to line in or line out then they pretty much cancell themselves out.
May 23, 2009 | Televison & Video
Sound
Hi...there,
Are you sure you pluged the audio cable from the monitor to the Computer green color output jack???
Oct 25, 2008 | HP Vs17 17" LCD Flat Panel Monitor
Trying to reconnect a set of Harman Kardon candlestick computer speakers to a Dell Dimension E520 computer. I got three plugs and dell has 6 holes...what the heck goes where? Nothing I seem to try works...
Hi rjlevesque
For the speakers, you need only connect to the GREEN jack at the back of your computer. It's OK to leave the others blank.
Your two HK speakers will, with one wire, connect to each other and, w/ another wire (usually having a GREEN connector on the end), connect to the computer.
I'm not sure what the 3rd wire is unless it's (1) the power connector or (2) for connecting to a sub-woofer.
Does the speaker set include a sub-woofer? Or does it include a "surround sound" or 3rd speaker?
You can find pics & symbols (the symbols are helpful if your sound card jacks are not color-coded) for (3) of the most common audio connections HERE.
Usually the color of the connector on the wire is matched to the sound card jack w/ the same color. (green to green; pink to pink; blue to blue).
green = speakers
pink = mic
blue = line in
Make sure you are connecting to the active sound connectors - the ones you used b4 the HK speakers.
If you have "integrated audio" (audio that is built into the motherboard) and you have an audio expansion card installed on the computer as well, one may be disabled or not selected in your computer's audio configuration.
If that's the case (that you have two sets of audio jacks to choose from), try connecting the speaker wire from the HK speakers 1st to the green jack (or the jack marked w/ the symbol of a speaker) at the bottom of your computer. (There'll only audio jacks here if there is an audio expansion card installed on your computer.)
If that is the case, there'll be other (usually) colored jacks running horizontally next to the speakers jack.
If you still have no sound, connect the speaker wire to the GREEN jack that is (usually on Dells) up by your PS2 (round - one purple and one green) keyboard and mouse connectors (also at the back of your computer). The other jacks in that set (of audio jacks) will be situated vertical to one another and on the left-most side at the back of your computer.
Please, let us know if this response was helpful for you or, of course, if you have any further questions.
Thank you
BJ
Apr 03, 2008 | Computers & Internet
Speakers
may be you have not installed the audio drivers.... if not then so install it & then try it will work..
if it is installed then check whether the audio cable from speakers to the cpu is correctly connected to audio jack in the cpu..(u must connect to green audio port)
check whether the power supply of the speakers is given r not...
check whether the power button of the speaker is on ....
if the same problem persists then there may be miscontact inside the speaker (if the speaker is showing green light when it is on means then there is no power supply cable problem else there may be power supply cable problem try changing it )
else
may be the capacitor inside the speaker is gone
if the problem persists then
take the speakers to technician ....
Feb 10, 2008 | Audio Players & Recorders
Dell Dimension 4600 PC Desktop Logo
97 people viewed this question
Alun Cox
