Question about Uniden Cordless Phone
I need to reset the time on my phone. Not quite sure how I do this. I can set the day, but not able to change the time.
  • 483 Answers
Press "clock" and hold for a few seconds.It will say the day. If the day is wrong, use the arrow keys to move either forward or backword through the week. When the day is set press "clock" again and you will hear the hour. Press the arrow keys to move the hours. Press again for the minutes and use the arrow keys to set the minutes. Last press "clock" again and set AM or PM. By the way, the manual does not tell you how to set the clock.
Fame !
Posted on Jun 26, 2009
When switch on there appear ." configration error"
here is a simple yet powerful solution.
1. Just backup your entire phone which is quite easy these days. 2. Reset (or format) your phone to the factory settings.
This will surely help you.
Apr 04, 2011 | Sony Ericsson W550i Cellular Phone
MY PHONE SHOWS THE RIGHT TIME BUT THE WRONG DAY. THE SCREEN SHOWS - NEW CD:29?
do not really know the kind of phone you are talking about, sometimes if you but a different theme i might change the time, so you will need to reset the time again to the correct time.
You can go to the setting of the phone and reset the time and date again.
But note this, if the time is on auto-update, you will need to remove from auto-update so that you can set the time manual yourself.
Please next time, it will be much more easier if you but the make and the model of the phone on your question so that you will get a definite answer.
Have a nice day.
Mar 30, 2010 | Audio Players & Recorders
The Uniden XDECT7055 Owner's Manual is unclear regarding setting up the day/time. When I go to the MENU/SELECT function and scroll down, the date/time is not one of the functions offers to set. The only...
Phoned Uniden - durrgggh - had the same problem - simple solution - advised them to improve the manual - is totally not clear!!!!
As below:
  • Day and time must be set in 12hr times - not 24 hrs
  • Must be set from a handset - any handset that is registerd to the base is fine
  • Follow handset instructions but make sure hours are set as 01 - press menu / select to confirm
  • Then place the handset back on its base - all other handsets and the BASE will then change to that day / time
Hope this helps
Dec 06, 2009 | Uniden Cordless Phone
Need to know how to change time on Comdial GCA70-281
  1. Programming the time and date for a Comdial Impact digital phone system must be done from the attendant's station, usually the phone located closest to the Comdial controller. Go to this station before attempting to change the time.
  2. Step 2 set-clock_thumb.jpg Now the phone system's clock is ready to be reset. Without picking up the handset, press the "Intercom" button on the phone. Dial * # 0 1. The digital display2.gif should read "Set Clock"
  3. Step 3 Set the year by dialing two digits (00-99)
  4. Step 4 Set the month by dialing two digits (01-12)
  5. Step 5 Set the day by dialing two digits (01-31)
  6. Step 6 Set the hour by dialing two digits (01-23)
  7. Step 7 Set the minutes by dialing two digits (00-59)
  8. Step 8 set-clock2_thumb.jpg Comdial Impact phone with updated day and time. Pick up the handset and set it back down to set the programming changes. The new date and time should display immediately on all phones connected to the Comdial system
Nov 04, 2009 | Comdial Impact 8124S Corded Phone
Can't find my manual and need to reset the date and time
if system DK series must set at port "00"
#402 to check the port number with displayed phone
#651 DDMMYY - for date
#652 HHMMSS - for time
#653 to change the day
Apr 08, 2009 | Toshiba DKT3010SD Corded Phone
How do I set the Prerecorded Greeting?
Press delete while reviewing your announcement.The system will use the prerecorded message until you record a new one.
Setting the Clock
NOTE: A flashing
"CL"
in the message window indicates that you must set the correct
day and time at the base unit.
1.
Press the TIME button. The system announces the time and day of the week,
followed by
"To set day and time, press TIME/SET."
2.Press the TIME
button. The system announces the day.
3.Press the CHANGE
button repeatedly until the system announces the correct day.
4.Press the
TIME
button to save the new setting. The system announces the setting.
5.Press the
CHANGE
button repeatedly until the system announces the correct hour.
NOTE: Be sure to select the correct time of day (e.g., 3 AM or 3 PM).
6.Press the
TIME
nnounces the minute.
7.Press
CHANGE
to advance the minutes one at a time. ­OR­ Press and hold the
CHANGE
button to advance the minutes in increments of 10.
8.Press the
TIME
button to save the new setting. The system announces the year.
9.Press CHANGE
to advance the year one at a time. ­OR­ Press and hold
CHANGE to advance the years in increments of 10. When the system announces the correct
year, press TIME
. The system announces the clock setting
Aug 12, 2008 | Motorola Mobility E51 MD7161-2 Twin...
BIS 34-D phone - Display window blinks date time beeps multiple times/day
The display will blink if power is cut either by unplugging or if the control system is power-cycled. The cause of the power glitches needs to be located & corrected. Changing the ring tone/cadence depends on which control unit is being used.
May 27, 2008 | AT&T Merlin BIS 10 Phone
Phone does not work properly
There is some pieces on the board inside your phone you broke off when you dropped it. It will need to be fixed by a technician. Hopefully you didnt brake the flex cable. Have them check the cable before doing anything else.
Aug 19, 2007 | Motorola Mobility MOTORIZR Z3 Cellular...
Uniden Cordless Phone Logo
150 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
